Question about Polaris Pb4 - 60 Booster Pump
My PB-4 Booster will not start today, it was working fine last night. When I turn on the booster it hums for 30 seconds clicks and then nothing. I checked to see if the impeller shaft would turn, and it does freely. I have not uninstalled and checked the impeller itself yet since the shaft turns freely. Is this problem something not involving the impeller? Your thoughts?
    Problem Solver:
  • 10 Answers
It is either the capacitor on the back of the motor or the windings of the motor. Motor capacitors.
Posted on Nov 03, 2009
My polaris booster pump just gets hot and wont run
the motor is bad overheating need a new booster pump
Sep 08, 2014 | Polaris Pb460 Polaris Booster Pump...
I have a 2004 honda accord last night i drve it with no problems out of no where today it wont start i have lights radio but it will not turn over we tried boosting with a car and a booster
If it won't start with booster cables, but the radio and lights work, that's not good.
Try putting it in neutral instead of park.
It could be the ignition switch, the starter relay, the starter, etc.
The etc is the problem. It takes a mechanic to figure it out if it's not just a moody ignition switch.
Nov 29, 2013 | 2004 Honda Accord
Today all 4 brakes locked up and the vehicle became un-driveable, and the brakes started on fire. The mechanic said my brakes looked new and rotors too. Now they are fried and Dodge dealer, since I am over...
Suspect your booster valve failed open, but not sure the ABS system is working right either. You can test the booster by checking to see if it will do it again in park. If the booster is bad, you'll need to replace it. Then, I'd see if the lights will clear. If not, suspect ABS computer is bad, but I'm not an ABS expert.
Sep 16, 2010 | 2007 Dodge Durango Night Runner New Cars
I have a Polaris PB4 booster pump, installed late July 2006, vacuum was running for an hour tonight but I noticed it wasn't moving across bottom of pool normally--wheel was skipping. I shut things down...
The click is the internal thermal overload. Since the pump wouldn't start it overloaded and opened the circuit. Either there is something jammed in the impelller locking the pump up or you have a motor problem. IF it a capacitor start motor, you could have a bad capacitor. Or if it has a starting switch it may not be operating. Start off and be sure the motor turns freely. If you replace capacitor be sure it is same voltage and MFD as the old.Check all wiring connections.
Aug 18, 2010 | Polaris Pb4 - 60 Booster Pump
I have a Polaris LR51044 pump that is not working. When I turn it on it "hums" but won't pump water. I live in Baton Rouge, La. and we have had freezing or below freezing weather for the last 2 days. The...
Usually when a polaris booster pump hums it means 1 of 2 things; either the starting capacitor needs to be replaced (its located under the black hump on top of the motor) or the pump is bad. Most likely the starting capacitor needs to be replaces. This is where you should start since the capcitor is only $20-$30. Get a new capacitor from a local pool store, shut the power off to the motor, remove two screws on each side of black hump on top of motor, remove two wires from starting capacitor and install wires on new capacitor, replace cover and turn the pump on. If that doesn't work you will need to replace the motor.
Jan 09, 2010 | Polaris Pb4 - 60 Booster Pump
Car wont start. Not turning over
sounds like just a duff battery try using a booster pack most batterys last about 5 yrs so if yours is the orginal then it's do one
Sep 09, 2009 | 2000 Pontiac Sunfire
When i step on the brakes the engine idles fast, I think I need to replace my pb booster, is it a tough job?
it should when you push the brake pedal but only for a second or 2. if idles up and stays up then yes its bad, start,push pedal, and put ear under dash and you should hear it **** air. its not too bad, unbolt the master cylinder, has braided steel lines going to abs modulator, flop forward outa the way. undo vacume hose, then go under dash, take out rod to pedal pin, 4 nuts, and pull it out of the firewall. you do not need to bleed brakes if you do not undo a hydraulic line and be delicate with brake light switch on the pedal
Sep 04, 2009 | 2000 GMC Jimmy
Yamaha dt 125 r 2004 wont start.
hi m8,, to have to put a booster on it ,,means the battery isny holdin a charge,,if they are stood 4 ages they dont last long,, u must 12v or just over to turn it over,, and while its runnin at least 14,7 volts goin in to the battery,, when it runs,or if u get it goin,, put a tester on the battery terminals,+ and - ,make sure theres 12v,, start her up,, and it should read 14v..if so then the altenater is fine ,,or if the lites get brighter as your revvin it up ,the altenater works fine, if it doesnt star again wen turned off,,,then battery has had it, and wont hold its charge..
Dec 30, 2008 | 2004 Yamaha DT 125 R
Polaris Pb4 - 60 Booster Pump Logo
923 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
