Question about Fujitsu Siemens AMILO Pro V2000 Notebook
Troubleshooting I was listening music on my laptop when it shoot down completely (although the power cable was conected to it and to the socket). Now I can't switch it on ! The power cable works, but the computer does not turn on. What's the problem? Thanks,
  • 4 Answers
Try taking the battery out and keeping it plugged in when you try to turn it on.  If it turns on then you need to replace the battery.  Otherwise, it is most likely the power supply (which on laptops is usually a part of the motherboard).
Posted on Nov 09, 2007
do basic troubleshooting step like shuttting-down the laptop and remove all external device connected then try connect again to skype and check if still the same
Sep 08, 2011 | Computers & Internet
My labtop has got trouble. when i want to enter it is balck screen and simply says, No bootable device-insert bootdisk and press any key. I was listening music from u tube, and immidately stop it. i shut...
* no elecrical power is reaching the disk-drive
* the "data" cable between the motherboard and the disk-drive is not connected
* the disk-drive has "died"
Take the computer to a qualified technician, for professional trouble-shooting and repair.
Jul 19, 2011 | HEWLETT-PACKARD Hewlett Packard HP Black...
I am new . I don't no where to conect mix to
For the whole mix, there are two XLR (mic cable) sockets on the back panel labeled 'Main Output' Left and Right, if your amp has XLR inputs you should use these. Otherwise there are two jack sockets labeled 'Main Out'.
This is a complex desk with a lot of useful options, you're going to have to spend some time reading the manual. Have fun.
Jun 12, 2011 | Behringer XENYX 2442FX Mixer
My laptop will only work on battery although it is plugged into the mains so after about 1 1/2 hours it shuts down untill the battery has recharged how can I change it so it works on the mains all the time...
Hi Nick,
It seems to be a setting in the Power Options. Go to it through the Control Panel. Read each option carefully and select or unselect the check boxes accordingly. If you feel that all the settings are okay then the problem lies with the power socket in the laptop. (that is considering that the battery is charging using the same Charger / AC Adapter.
Make sure that the pin of the AC Adapter fits completely in the power socket in the laptop. Even the slightest loose connection will not only send you into battery mode but also drain your battery faster and also create carbon deposits on the connector pin socket due to arcing (sparking).
Hope this helps you solve your problem.
Nov 05, 2010 | Computers & Internet
My compaq laptop is not getting started. When i am conecting the charger the light is not display. May i know what will be the problem
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Feb 03, 2010 | Compaq Computers & Internet
My daughter charged her machine and can't turn it on although the light is on
hello, while laptop was being charged was it powered off?? or hibernation mode?
TRY THIS:- Disconnect power cable from the laptop, then remove the battery from the laptop with power unplugged and battery out open up laptop and hold the power button down for about 15 second and then let it go. Plug the battery and power cable back and try turning it on...
let me know if that works or need further trouble-shooting
good luck,
Amar Sondhi
Oct 29, 2009 | Dell Inspiron 6000 Notebook
Amilo m1451g the power socket gets very hot
Of all laptops I have dismantled I have found the power socket on the motherboard, although I have not yet dismantled a Fujitsu Amilo.
To get at the power socket, it requires dismantling the laptop completely.
Jul 16, 2009 | Fujitsu AMILO PC Laptops
Down loading music and pictures
just get the software from the internet and the usb cable, or if u hav a memory card on usb mode (in phone settings) go on mass storage, and connect ur usb and it shud work if dat dunt work get a memory card adapter and conect it 2 ur laptop and send it 2 it hope this helps.
Sep 16, 2008 | Samsung SGH-D900 Cellular Phone
Laptop crashes
well, one of the problems could be that you have had the laptop for a long time and a lot of dust is trapped in the computer. you can probably get this cleaned at bestbuy (geek squad) or circuit city. in my computer, it just locked up
Apr 17, 2008 | Computers & Internet
Intermitant power
You are describing the symptoms of a classic cable short. My guess is the power plug cable on the A/C power adaptor or the socket it plugs into is damaged. Try holding the plug still and wiggling the power cable back and forth, chances are that will recreate the problem. -If you have basic tools and solder experience you can purchase a replacement plug, cut the old on off and attach the new one. -If you don?t have the time or inclination to fix it you can just purchase a replacement power supply. If it doesn?t appear to be the power (or if you?re not using the A/C power adaptor) it may be the USB cable or its socket. -Try a new cable. -Try a different USB socket; they are surprisingly easy to damage. Let us know if you have any other questions and please don?t forget to rate this post.
Mar 30, 2007 | FireLite (USBFLB80) Hard Drive
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
168 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
