Question about Honeywell Heating & Cooling
Repairing honeywell sv9501 - Honeywell Heating & Cooling
My honeywell HFD-015C air purifier wont turn on
Hello, this is Ava with Think Crucial.
You may check to make sure that the power cord is correctly connected to the outlet. Test the outlet is functioning properly using another appliance or lamp. Also, check the fuse or circuit breaker. The outlet may be overloaded if other appliances are also in use. Establish and correct the cause of the overload. If none of these works, then there is something wrong with your purifier unit and contact the store where you purchase it or Honeywell for replacement. It is advised not attempt to repair the unit yourself.
You can purchase a wide variety of high-quality Honeywell replacement parts for your Honeywell air purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=honeywell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
May 31, 2014 | Honeywell 17000 Air Purifier
Honeywell air purifier won't turn on
Ava B.
Apr 23, 2014 | Honeywell UV HEPA Clean Antibacterial Air...
Do you have a replacement on/off switch for a honeywell hz-725
Unfortunately, we do not sell any parts on the this website. Just information on how to solve and repair appliance problems. You will need to contact the manufacturer (Honeywell) for any replacement parts you may need.
Mar 20, 2011 | Honeywell HZ725 Electric MidSize Heater
Have a Honeywell M847D1004 Actuator for my zone damper. Only will stay in the closed position. Are there any parts inside that can be repaired so it will open when the zone is to be getting heat or a/c?
No, more than likely it is the plastic wheel and I have found no available replacement parts for that. Honeywell did an amazing job with providing a quality product that will fail after 3 years
Oct 19, 2010 | Honeywell Heating & Cooling
Have an approx 20 year old Honeywell ducted air conditioning unit in my just purchased villa. It is not working. Am having trouble finding someone to quote to repair it. I live in the southern suburbs...
If its 20 years old it would benefit you much more to replace it, see the energy star website and it has information on when replacement is the best solution. Over 10 is the general rule of thumb if it over 10 then replacing the equipment will benefit you so much more than a repair. Also honeywell doesn't make equipment anymore and i cant say vie seen one but that doesn't mean its not out there, vie seen Chrysler air conditioners in houses and honeywell dose make controls but not equipment anymore (in fact this is the first honeywell unit vie heard of).
Oct 01, 2010 | Honeywell Heating & Cooling
Heating & Cooling Logo
16 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
