Question about Kenmore 74602 Gas Dryer
Gas Dryer isn't producing any hot air or heat
Gas Dryer no warm heat? Model # 97273100. what part could it be and how much $$$ would it cost to fix it??
  • marlasmobile Jun 20, 2009
    Is there a service tech on this site that can give me an idea on what they think it might be?? Sears doesn't seem to be able to help me unless they schedule a service call. I would like to get an idea first on what the expense might be first
  • 999 Answers
Sears will not tell you before they come. It will be over $150 when they come out. There are several possible parts, Thermal fuse, ignitor, thermostat, coil on the valve. Verifying voltage to the valve will tell you where to look next. If it is a thermal fuse then what caused it to blow needs fixed or it will just go again.(over heat due to restricted air flow or stuck thermostat). You should be able to get the parts for under $50.
Eric
Posted on Jun 20, 2009
WHIRLPOOL GAS DRYER MODEL LFI 5801 PROBLEM= WARM AIR, NOT HOT LIKE BEFORE. CK THE VENTS ALL CLEAR. PLEASE HELP
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 16, 2011 | Dryers
I have an LG model DLE2532W dryer that is taking forever to dry our clothes. I have checked the continuity on the coil and it seems to be fine. I have also replaced the cycling thermostat. The heating unit...
heatman101
Aug 04, 2011 | LG DLE2532W Electric Dryer
All of a sudden, my 18 year old Kenmore gas dryer is not producing hot air. The motor is working & the barrel is revolving. What can I do short of spending $500-$600 for a new comparable Kenmore gas...
It sounds like your heating element has given up the ghost and broken OR you have a bad thermostat that isn't telling the heating element to work. I would suggest you find the tag on your dryer with the model number on it and then go to www.searsparts.com and look it up and find the heating element and thermostat and decide if you want to spend that much.
NOTE: Usually, on older models, I always recommend that my client replace both so that I don't have to come back again in a few months to change the other. They seem to both fail close to each other.
Jun 18, 2011 | Kenmore Dryers
I have a Kenmore Residential Dryer Model # 97273100 (11097273100?). The dryer starts but does not spin. I assume it is the belt, but how do I access it?
I smell gas and can't find where the door panel is on my Kenmore You : Model:97273100 serial: MB3313988
Jan 16, 2011 | Dryers
Tumble dryer does not produce hot air on hot mode, do I need a new heater element?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 02, 2010 | Zanussi Dryers
Gas dryer dosn't heat properly
The problem is the dryer coils are failing. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jul 07, 2010 | Maytag MDG3600BW Gas Dryer
No hot air
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 11, 2010 | Whirlpool LER8648L Electric Dryer
Model DBSR453GB1WW bought around 2004/2005 - Dryer runs but will not heat up?
This model uses an ignitor, you can replace the ignitor for about $80
May 12, 2009 | GE DBSR453GBWW Gas Dryer
GE Profile Gas Dryer - Heat goes on and off
The operating coils get hot and quit. They only cost 20 bucks. Read more about it here:
Gas dryer works then quits then works some more
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 31, 2009 | KitchenAid KGYS850LT Gas Dryer
No heat in kenmore 97273100 72731 front load gas cloths dryer
check the ignitor under the door panel on the left side of the burner if it gets red when you turn the dryer on.if yes than see if gas shoots out and yes than how long it stays on if in few minutes it turns off than need thermal fuse checked so let me know up to this point if it works or not .
Nov 02, 2008 | Kenmore 73952 Gas Dryer
Kenmore 74602 Gas Dryer Logo
273 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
