Question about Konica Minolta bizhub C450P Laser Printer
"Machine Status 6 / / / / - Konica Minolta bizhub C450P Laser Printer
  • Konica Minolta Master
  • 6,696 Answers
Replace the cyan image unit
try this site as start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Dec 30, 2015
Need warranty status and age on Sharp MX-M453N MFP s/n:35016835
Try going to www.sharpusa.com Under the support tab you may find what your looking for. As a Sharp technician for many decades the warranty is normally 3-6 months. By the serial number I believe your machine was built in 2013
Aug 04, 2017 | Sharp Office Equipment & Supplies
Which is the maximum duration of the calcium cleaning cycle
Hello Fellow Espresso Maker
We at Expressfix recommend you descale every 6 month depending on water quality and usage. We tell our clients every 6 month to prevent scale build up and proper operational status for normal usage(2-3 drinks daily). Poor water quality leads many future preventable service calls.
Thanks
Sep 17, 2013 | Gaggia Titanium Espresso Machine
Ihave the stairmaster4400CL and it does not have any resitance. How can I repair this
investigate the status of your battery. without proper power, you cannot get resistance. The machine has a 6 volt battery. the battery should provide a minimum of 6 volts when in an idle state. meaning without any activity on the machine, a cold battery test should provide a minimum of 6 volts.
Sep 23, 2010 | Stairmaster 4400CL Stepper
How do you reset the fuser counter on the 9440CN from Brother
This function is provided for service personnel in order to reset the counter of each periodical replacement part and count the number of replacement times when replacing the periodical replacement parts.
(1) Press the 3 and 9 buttons at the same time in the ready
status.
(2) The “Reset Menu” will appear on the LCD. Select the
applicable periodical replacement part by pressing the up arrow or down arrow button and press the OK button.
< Periodical replacement parts are indicated on the LCD >
- Drum - Belt Unit - PF KitMP - PF Kit1
- PF Kit2 - Fuser - Laser
(3) When the OK button is pressed the “1. Reset 2. Exit”
appears on the LCD. Press the 1 button if resetting the
counter. If not, press the 2 button.
(4) Pressing the 1 button accepts that the machine implements
the counter reset.
(5) If the 2 button is pressed the machine goes back to the
select part counter again. If you need to Exit press the
Stop/Exit button at any time.
(6) The machine returns to the ready status.
Oct 30, 2009 | Brother MFC-9440CN Laser Printer
Security code for my nokia mobile 1650
IMEI number: * # 0 6 #Software version: * # 0 0 0 0 # lub * # 9 9 9 9 #
Simlock info: * # 9 2 7 0 2 6 8 9 #
Enhanced Full Rate: * 3 3 7 0 # [ # 3 3 7 0 # off]
Half Rate: * 4 7 2 0 #
Provider lock status: # p w + 1 2 3 4 5 6 7 8 9 0 + 1
Network lock status: # p w + 1 2 3 4 5 6 7 8 9 0 + 2
Provider lock status: # p w + 1 2 3 4 5 6 7 8 9 0 + 3
SimCard lock status: # p w + 1 2 3 4 5 6 7 8 9 0 + 4
1234567890 - MasterCode which is generated from IMEI
Oct 23, 2008 | Nokia 1600 Cellular Phone
I have a F & P mw511 washing machine, that stops and flashes a code 56. where do i start looking.
56. (00111000) Phase 4 to 6 - Basket Check No Valid Fault
While carrying out a basket check, the machine has not been able to determine a
valid tub status and so the Display flags this fault. This fault differs from fault 40 in
that a valid tub status could not be determined. The first two areas to check are the
clutch and pressure tube. If these two appear correct, then the fault could be with
the pressure transducer in the motor controller.
Primary Source: Mechanical.
Action:
1) Check that there are no clothes or other foreign objects preventing the clutch
from re-engaging.
2) Next check that the pressure tube has not come off and that it is not kinked.
Secondary Source: Motor Controller module. (Phase 4) Rotor Position
Sensor (Phase 5 and 6)
Action:
Replace the Motor Controller module. (Phase 4) Rotor Position Sensor (Phase 5
and 6)
Sep 16, 2008 | Fisher and Paykel Washing Machines
XEROX workcenter M20i prints codes at bottom of page
someone has gone into diagnostics and enabled Status Print Engine
Fix
1. press menu/exit key
2. enter # 1931 in that order
3. engine test(diagnostic) should be displayed
4. use arrow keys to scroll to, then select engine test(status print)
5. press enter
6. press the "2" key on numeric keypad to disable (status print)
7. machine will revert to Ready to Copy
8. power off and then back on the M20
9. Your done.
May 02, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Fax Mode "Status:Standby"
go to the fax option from the menu and check the status option .
The setting had been changed to standby ib your fax machine
Apr 29, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Konica Minolta bizhub C450P Laser Printer Logo
19 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
