LG TV DU-50PX10C have sound but no picture
I tried using the flashlight but still saw no picture,there is sound and there sems to be something that leaked from what looks like a capicitor its hard and looks like dried glue resting on three of em not sure if this si the problem or not
    Top Expert:
  • Televison & ... Master
  • 74,887 Answers
Back-light inverter board fault. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Posted on Apr 22, 2014
SOURCE: Popped just like the rest
Please take the time (5 min) to file a complaint with www.consumeraffairs.com...you will see that you are not the only one with this exact same issue on this zenith plasma model Z50PX2D:
http://www.consumeraffairs.com/search.html?cx=partner-pub-0200629403145096%3Aqt7mbbqybbg&cof=FORID%3A10&ie=ISO-8859-1&q=zenith+plasma+#1124
Posted on Jul 29, 2009
SOURCE: sound works but no picture. black screen
I've had the same problem. Usually, if I turn the TV off and then back on again, it's fine.
Posted on Mar 05, 2009
jerryg50
  • 1689 Answers
SOURCE: lost half of picture
This can be on the matrix drive board, or the display assembly itself. It is possible to also have a defect in the address decoding area that will cause this.
The procedure is to swap out the suspect boards to determine where the fault is, leave the working boards in the set, and then follow up any necessary calibrations that are necessary.
Jerry G.
Posted on Jul 16, 2008
fingaz22
  • 1068 Answers
SOURCE: no picture, has sound
i have the same issue and after removing the back and doing a voltage test on cp506 and found the 24vdc that was suppose to be there lead me to the back light inverter. a very common problem for these tv's and if you can take a voltage test of vdc then you can confirm it! one problem the manufacture does not sell it seperate from the lcd panel so it is very expencive and to find them use they are hard to find because of them being a common problem! good luck and if you need help taking the voltage test let me know!
Posted on Sep 17, 2009
SOURCE: Issue with LG Plasma tv model # DU-42PX12X
Another "same probelm"
My set has encountered this magical 50/50 split screen and it seems to be quite a problem since I am not the only one researching this issue. LG was of no use because of course it is just out of warranty. Any solutions on fixing this or am I out of money in buying a new plasma?
Posted on Nov 10, 2009
LG LED TV 47ln5790 has no image but has sound. Brief flash of light when powered on and off. I can see image with flashlight.
I saw a youtube video where they replaced the led strips and it fixed the intermittent flashing screen issue
Oct 14, 2017 | LG Televison & Video
LG DU-27FB32C has picture but no sound
check in the menu first to see if someone turned the speakers OFF--that is done in some cases if a surround system or a receiver are in use.
Also check to see if sound when a DVD etc is used via rear inputs.
Jun 01, 2012 | LG DU-27FB32C TV
My LG Plasma television DU-42PX12XC had a loud pop
Your tv contains protection circuitry that would shut down the tv if the ymain was out. If the ymain had blown, you'd have no sound and just a flashing standby light. My gut tells me you need to replace the Power Supply Board (PSB). I've seen this before and after spending too much money trying to diagnose a ymain failure, I was surprised to learn that when you have sound but no picture, the psb is a gonner. Try ebay, shopjimmy.com or discount-merchant.com for a replacement.
Good Luck!
Apr 20, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
I was just wondering if I could make my LG remote, 6710V00116F, into a universal remote?
A universal remote has a special chip in it that allows it to change the codes for other devices. It should work only on these tvs: DU-42PX12X, DU-42PX12XC, DU-42PX12XD, DU-42PZ60, DU-42PZ60/H, DU-42PZ60H, DU-50PX10C, DU-50PZ60, DU-50PZ60/H, DU-50PZ60H
Mar 14, 2010 | One For All Televison & Video
DU-50PX10C
Replace the screen as the drivers are part of the screens edge.
Sep 27, 2017 | LG MU-50PX10C 50 in. Plasma HDTV
Connections
conect ps3 audio throw optical
Dec 26, 2007 | LG MU-50PX10C 50 in. Plasma HDTV
Red line on screen
The vertical line, in my case, was due to a bad contact on the flexible printed circuit. I fixed the problem by using a piece of a rubber eraser to apply downward pressure on the flexible circuit as shown in the picture. To locate the faulty section lightly push on the flexible circuit from lef to right untill the line dissapears. 9f78570.jpg
Nov 08, 2007 | LG DU--50PX10C 50 in. Plasma Television
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
