Question about Salton Coffee Makers & Espresso Machines
I have been given a Salton coffee maker model Q02731/10444CS and I cant figure out where the water tank is
mirran
  • 515 Answers
SOURCE: Saeco Magic leaks water between water tank and machine.
You have to replace the gasket in the machine where the water tank goes in to the machine.
Posted on Jul 10, 2008
SOURCE: salton coffee maker,(expresso)model number ex-3 need instructions please!
HI,
I've been looking for the instructions too (thats how I found your question) anyway. I don't know if you have already found the answer but this link takes you to a page where the manual can be found. its scan of a manual an EX-3 in pdf format.
Hope it's what you were looking for,
James
http://www.contrex.ca/coffee/
Posted on Jul 13, 2008
  • 74 Answers
SOURCE: Instructions
http://www.coffeecrew.com/content/view/186/27/
http://www.coffeecrew.com/content/view/187/27/
found these two links right here on Fixya.
Sry to say it seems that most people that have actually got a manual is from Salton.
Email them and they will send you a .pdf of the manual.
info@salton.com
Posted on Jul 18, 2008
  • 131 Answers
SOURCE: Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
Posted on Feb 13, 2009
  • 40 Answers
SOURCE: my keurig coffee maker will not draw water into
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
Posted on Oct 07, 2010
How to clean as the water is not going through coffee filter system
You can get coffee maker cleaner, but I find vinegar works just as well. Fill water with your cleaner, and attempt to run the coffee maker without coffee in it.
Repeat until the cleaner/vinegar comes out like it did when the coffee maker was new.
Run with plain water several times to get all the cleaner out before making coffee.
Oct 18, 2014 | Salton Coffee Makers & Espresso Machines
I have a Salton "Three For All Plus" model EX-30 and I need a new coffee pot because I broke the one I have. Where may I buy one?
Hi, mine also broke and I managed to gets one from Krups, model. F027 item code 196402 at £14.95. Will try and send photo! This is compatible with your coffee maker. Good luck.
Jan 27, 2014 | Salton EX30 Espresso & Coffee Maker
Salton ex10 manual
I was given a Three for All, Salton , model EX10 but no instruction Manuel...could you please email me a SIMLPE INSTRUCTION ...address...nanoofh@yahoo.com...
Jul 27, 2012 | Salton EX20 Coffee Maker, Espresso Machine
Instructions
info@salton.com
Jul 18, 2008 | Salton EX20 Coffee Maker, Espresso Machine
Salton Model # 17
I think I've figured my yard sale EX 80 out. First, the way I think it works... in the tightly sealed boiler the water is heated to boiling, it must have a pressure release valve that sends the water/steam through the coffee and into the carafe. So dangerously hot and under pressure. Before opening the big round cap at the top (reservoir) relieve pressure at the steam tube valve (right side)
Here's how I made my first batch:
When opening reservoir always turn unit off, let reservoir cool a little between batches or you may get a cloud of steam in your face when pouring in water, might not be good for the heating element to shock it with sudden drastic temperature changes either.
Cleaned by running a couple of jugs of water through, cold water (4 on the supplied jug) into the reservoir all parts installed. I read somewhere online (not specific to any machine) not lukewarm water, if it's online it must be true... right?
Put coffee into filter basket/basket holder, matching amount of water in reservoir, 2 or 4 (markings on filter and jug). Espresso coffee should be very finely ground
Install all covers and the coffee basket/filter basket, close steam tube valve, install carafe and turn on the machine. Should get blast of espresso after a couple of minutes.
The steam tube (operated by the valve) seems a little cheesy on first try but I'll get better with practice. There's no steam to the tube until the reservoir starts to send steam to the coffee, the coffee kinda restricts the steam enough to send it to the tube. I was thrown a little because I didn't get steam when I was cleaning the thing, but I think that was because there was no coffee to block the flow. So I opened the valve at the start of the brew, steamed the milk, closed the valve and then the steam blasts through the coffee, tasted good.
Great $1 find.
Hope this helps.
Apr 27, 2008 | Salton EX80 Espresso Machine
Salton "three for all plus" coffee espresso maker instructions
the following site will take you directly to the salton info file. site says if you email them they will get you an instruction file. http://www.singleservecoffee.com/archives/000517.php
Sep 21, 2007 | Salton EX20 Coffee Maker, Espresso Machine
Instructions
Hello:
I had the same problem, I needed the instruction manual for Salton EX-20 Three for All. Searching the net I found the following answers:
Enjoy,
JC Contin
May 27, 2007 | Salton EX20 Coffee Maker, Espresso Machine
Coffee Makers & Espresso Machines Logo
37 people viewed this question
Top Salton Coffee Makers & Espresso Machines Experts
Angel Joseph Jr.
Angel Joseph Jr.
Gil Shultz
Jay Plesset
Are you a Salton Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
