Question about Sony Bravia KDL-40S4100 40 in. LCD TV
Flat screen control buttons caved in
Power button , vol buttons are flushed with side panel of flat screen
The screen does not turn on only the green led below turns on then star to blink
This might be cause by lamp error. Here's possible solution. Unplug AC cord for a while.
Then follow process as below. 1, Plug AC cord 2. Press Vol (-) + TV/Video Button at the same time 3. While holding above button, Power On by pressing power button. 4. Either "K" or "K123" will appear on the screen. This indicate that you enter the service menu. 5. The Press Button Vol(-) + Channel Up button to go to menu page. 6. Find Lamp Error page. 7. Lamp error data should be "0" zero, if not change to "0" 8. After changing the data, power OFF by Power button. 9. Unplug and re-plug AC cord 10. Power On to check if power resume.
Good luck Jheremiel
May 16, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a brand new Aquos 52" LED TV and I accidentally locked remote operation and THEN found out the front touch screen panel was broken. Any way to manually reset the TV or remote to gain access to...
While the set is turned on, you need to hold the power button until the set shuts off and the led in the middle of the bottom flashes once. Then quickly release the power button and press the vol - and input buttons together along with the power button. Your TV should then turn on and should show you a blue box with the letter K. Now press the vol- and channel- buttons at the same time. You should now be in the service menu. With your remote arrow up until the top line says industry init. Arrow to the right and hit enter. Screen should turn green and say factory init success. I hope this helps you.
Apr 04, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TV will not turn on. There are two lights in front at the bottom of the screen - One is the power light, one is the OPC light. When the power cord is plugged in, both lights flash twice, then the OPC light...
Sounds like your screen is broken or has been impacted. Force the television on by doing this: Unplug it and on the side of the television where the panel buttons are hold down the ch- and vol+ buttons. Then plug in the television while still holding them down. The television should come on and you see the cracks. Unfortunately it can't be repaired.
If it isn't ch- and vol + then try ch + and vol -.
Feb 05, 2011 | Sharp LC46SB54U 46 in. LCD TV
Power light blinks 13 times
need replaced A-BOARD
Manufacturer Panasonic Part Number TNPH0716ABS Description A- BOARD
After the installation of a new A board, unit has the characters "CHK" on screen. The usual reset procedures of [VOL -] and [MENU] or [OK] or [SLEEP] will not get rid of "CHK".
1. Enter the service mode by holding down the [VOL -] button on the TV (main unit) and simultaneously pressing the [INFO] button on the remote control three times.
2. Press the number [2] key on the remote to highlight [SRV-TOOL].
3. Press the [OK] button on the remote control to select [SRV-TOOL].
4. Use the [DOWN ARROW] on the remote control to scroll down to [PCTC].
5. Use the [RIGHT ARROW] button on the remote to open the box to the right, then press and hold down the [MUTE] button on remote to display Time/Count.
6. Press and hold the [RETURN] button on the remote control until the TV turns off.
7. Immediately press and hold down the [VOL -] button on the TV (main unit) and the [MENU] button on the remote. The TV should come up in the Self Check mode.
8. Remove AC power.
Jul 06, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
How do I unlock the child lock on Syntax LT27 HV/LT30 HV when the remote control does not work??
Use the buttons at the bottom of the screen right below the bezel with the ON/OFF blue light. The buttons are hidden as they face towards the floor. But you can access the OSD by using MENU and you can navigate using the CH +/- or VOL +/- unfortunately I can't check because my TV is being repaired (got the same model)
Anyway if it helps here is the order of the button left to right while looking at the screen:
[INPUT] [VOL-] [VOL+] [CH+] [CH-] [MENU] [POWER]
I hope this helps you :)
May 16, 2010 | Syntax LT30HV 30 in. HD-Ready LCD...
I turn on the T.V. and the blue light is blinking and the T.V. doesn't turn on
1. simultaneoulsy press and hold [menu] and [vol-] on TV side panel
2. press and release [power] on TV side panel
3. count to 5 and release[menu] and [vol-]
4. TV should have turned on
5. if not, unplug TV and press[power]
6. repeat from step 1 if the TV does not power on the 2nd time
Jul 10, 2009 | JVC LT42P789 42 in. LCD TV
Altec Lansing PT7031 - ''Panel Key is Locked''
With the unit turned on...
Press the following front panel buttons in sequence within a 10 second span:
[Vol+] / [Vol-] / [Vol+] / [Vol-] / [Vol+] / [Vol-]
Successful unlock is indicated when the front panel led's flash.
Apr 04, 2009 | Altec Lansing PT7031 Computer Speakers
New JVC flat screen cuts off 10 sec. after cutting on
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
Mar 26, 2009 | JVC LT42P789 42 in. LCD TV
42HDS69-INPUTS
couple of ideas ... on the TV look for the button named input you can change it to the one you cave connected to there .. I am looking up the remote press the TV button then the menu button to move through the on screen input control
Sep 19, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Sony Bravia KDL-40S4100 40 in. LCD TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
