Question about Acer Aspire Ethos 8943G-5464G50Bnss Notebook
How to open acer 5950G to replace keyboard - Acer Aspire Ethos 8943G-5464G50Bnss Notebook
I have a acer 5950G and it has acer arcade deluxe on it. it will not allow me to play my music. what do i need to run this program
first try updating the program:
  1. In the Arcade Deluxe program, click Advanced and, next, double-click Live Update.
  2. Click Yes to confirm and, then, Update Arcade to install the update.
normally that should fix the problem if not try to check your sound card as well as your speakers.
Jul 14, 2011 | Acer Computers & Internet
Just a quick question, I need to replace my keyboard on my acer 5534 laptop, found a new one, have it ordered, how easy is it to replace the keyboard or should I let someone else do it?
pretty simple turn off the pc flip it over take ur battery out then there will be holes with screws with little keyboards beside them indicating the mounting screws positions remove them open the laptop pop the key board out some models will need another piece of the bezel to be removed to achieve this if it seems to daunting get some help and good luck with this
Dec 19, 2010 | Acer Aspire 5500 5570-2609 Laptop
Replace keyboard on acer 8100 series laptop
Replace the inside of the keyboard with a new piece. One of the major problems with Dell keyboards is that the plastic pieces holding the keys in place become loose or broken. You can find a cheap keyboard from Papatek.com or an electronics store. Simply take apart the new keyboard, pull the keys off your keyboard, lay the plastic piece on top and replace your keys.
http://www.papatek.com/Acer-Keyboard/Acer-Travelmate-8100-keyboard.html
Jul 23, 2010 | Acer Ferrari 4000 Notebook
I need instructions for installing Acer keyboard a2797.001
I'm not sure which model Acer you have but the pic of the keyboard looks simular to the Acer Extensa or TravelMate series laptops. If so, there's a plastic cover just above the keyboard, but under the screen that covers the display hinge. Open the display fully and gently pry up on the hinge cover. Then slide the horizontal bar next to the opening about a quarter of an inch and lift it off. You should then be abl to pry up on the keyboard to remove it.
Sep 08, 2009 | Acer KB.A2707.001 Keyboard
I need to replace the keyboard on an Acer Aspire 3680 series laptop
Hi there.
Remove the laptop battery and the AC power supply, open the lid as far back as you can take it.
Get a small flat headed screwdriver, now, you have to take off the keyboard bezel, this is the strip of plastic above the keyboard with the power button on it, the best way to remove it is to start by the on/off button by gently prying the bezel up from the lid hinge, once you have one side out gently pull it up using your fingers, it will unclip and lift away.
Next you have to remove 2 screws from the top of the keyboard, these should be visible to you, once the screws are out carefully lift the keyboard up, you will see a ribbon cable that is connected to the motherboard, gently pull the tab up on the connector that the ribbon cable sits in and it should release it and you can now remove the keyboard and replace it.
To re-assemble just follow my direction in reverse.
Please post back with the results and for any additional advice if needed.
Good luck and thanks for using FixYa!!
May 22, 2009 | Acer Computers & Internet
Acer laptop keyboard repair. I spilled coffee in my keyboard and now some of the keys dont work. The computer itself works fine. How do i get the keyboard out to clean or replace it? Thanks Abe
ok here u go u havent given me model of ur notebook but it is almost the same procedure normally all casings are same to open
see this link for details
http://www.cyfinity.com/2008/07/acer-aspire-5315-keyboard-removal/
pls rate me FIXYA fo rhelp
Apr 11, 2009 | Acer Computers & Internet
Acer Aspire 1652 WLMi keyboard replacement
dear sir.
if u need to replace keyboard as my sujetion is perchase from otherise center they replace yr keyboard and plase it to yr laptop. and there no need to seen eny videos or guide it's simple stape to replace it just open frunt LCD panel downln plastic part then it's show 2 sckru just open it then safly remove keyboard and same as put new one but be safe a wair of keyboard is very scancitive it's help u....;)
Thnaks
please vote
jo_chinmay
Jan 01, 2009 | Computers & Internet
How to replace keyboard on Acer Aspire 5570 notebook
remove two screws on the back of the laptop where the screen opens and close. then open the cover and use a flathead screw driver to pick the top portion of the keyboard screen. unscrew two more screws and u can slide the keyboard out.
Sep 17, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire Ethos 8943G-5464G50Bnss Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
