Question about Daewoo DWDWD3011WW Front Load Washer
Door won't lock - Daewoo DWDWD3011WW Front Load Washer
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
Oven door won't lock, self clean won't start
this is a door lock error , you will need to replace
Feb 20, 2013 | Kitchen Ranges
The doors will not lock or unlock from the door but will from the remote?
The title suggest the door won't unlock unless the remote is used but during the summer it was the inverse. If while inside the car the doors will not lock or unlock from the door but will from the remote then you have a faulty switch.If while outside the car the key turns while in the lock but the door won't lock or unlock then the linkage at the end of the lock is faulty. You'll need to remove the door inside plate to check this.
Dec 07, 2011 | 2004 Infiniti FX45
Door won't lock..machine won't start
could be a faulty door lock as this is required to be locked before a signal is sent to the controller to start the wash cycle, try replacing the door lock, there quite cheal only a few pound
May 31, 2011 | Kenmore Washing Machines
The oven door won't close all the way. The "lock" light on the upper left is on. No amount of fiddling has solved this problem and oven is unusable. Help please!
Hi
The door lock assembly is bad and should be replaced, you can try to move it but that won't help and will have to be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
May 26, 2011 | Ovens
2006 chev.colora the door lock on the front right side won`t work
Common for the door lock solenoid to go bad and your going to need to replace it. You may hear it clicking but it's to weak for it to lock and unlock the door.
Thank you for using fixya and good luck
Apr 26, 2010 | 2006 Chevrolet Colorado
Lock won`t open
Look for a button or sensor which turns the light off or which the door would press when closed.
If you find it hold it down for a minute, then let go this should reset the lock
Aug 13, 2008 | Frigidaire FEF352 Electric Kitchen Range
Daewoo DWDWD3011WW Front Load Washer Logo
41 people viewed this question
Top Daewoo Washing Machines Experts
Owen Barnes
dweatherby
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
