Question about Samsung RS261MDBP Side by Side Refrigerator Ice and Water Dispenser -
Ice maker and water won't switch. don't know which buttons to push
Never had a users manual or shown how to go from ice to water.
No ice
If ice is formed but will not drop just pour hot water over the cubes. Or the teeth that push out the ice are getting stuck, in that case hold down the on switch to advance the teeth manually.
Apr 27, 2013 | Freezers
Won't make ice but will dispense water.
the gear assy in your ice maker is proably bad, it is less expensive to replace ice maker as a complete unit. 10 minute fix
Mar 03, 2013 | Freezers
Hoshizaki km-900mah ice maker won't start the freeze process
cycle is, fill cycle for 1 minute first. If there is not water entering the unit when first turned on, look for that issue. Water turned off, water valve not working or some restriction, clogged water filters, etc. That is got to happen first. Don't over look the bin stat being bad. Nothing happens if teh bin stat is bad. It sends voltage to the control board that runs the unit.
Jul 28, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Ice maker is not making ice
Subzero ice makers arent all cut and dry. You could have an intermittent issue with either the ice maker itself, or the solenoid valve. SZs also often utilize a door switch which prevents the ice maker from operating if the door or the basket which the ice bucket sits in are not closed or in the proper position. If you have had other what would seem minor problems, that you have lived with, they can inadvertently affect different things. Most sub zero ice makers you can start manually by rotating the ejector comb clockwise as you look at the front of the icemaker, when the icemaker completes its cycle, do you get water to the ice maker, and do you get enough water, usually 140-150 ccs. If the ice maker continues rotating on its own after your initial start up, and receives the proper amount of water, either you have a cooling problem, a door or something is not in the correct closed position, you have a bad switch, or the ice maker is bad. If you receive little or no water at end of cycle, you have a bad valve.
Mar 25, 2010 | Sub-Zero 15.3 cu. ft. / 433 liter Upright...
Ice machine just hums
First off, you cannot use a bucket of water and a line to get the ice machine to operate. Ice makers don't have a suction pump in them, they rely on having a water supply line with pressure to push the water into the machine.
You can connect the machine to a water line and see if it will cycle, that is, take water into the unit without leaking.
Beyond that, in order to check out the unit, you will need to provide the Brand and model number in order to find a user's manual, which will provide all the details on operation and installation for it.
The good news is you might have a nice ice machine for free.
Hope you find this Very Helpful and best regards!
Sep 09, 2009 | Freezers
Ice maker is overflowing
Older icemakers have a bar that drops from above your ice bin; once the bin is full the bar is raised and trips turning the ice maker off so that it won't dump. If your's is this style, try manually pushing the free end of the bar upward so that it locks in the upward position. Newer ice makers with the ice bin in the door have a small panel that moves to the open position when the door opens and closes when the door closes. Mine also includes an optical sensor that is visible when this panel is in the closed position. Try placing a non-clear tape over the optical sensor (don't know if that will work or not but worth a shot). If effective in stopping the ice flow then call a repairman. If none of this works, turn off the water supply coming out of the wall to your freezer.
Sep 08, 2009 | Kenmore Freezers
Ice maker is not working. Our freezer fridge side by side is about 8 yrs old...and now the ice maker is not making ice cubes. It is as if no water is getting to the machine. I have turned the...
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 29, 2009 | Freezers
The ice maker has stopped working
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 24, 2009 | Freezers
Water does not seem to be flowing into ice maker.
Hi and I hope this will help. You can manually turn the timer and see if any water is dispensed into the ice cube tray . If no water is dispensed check if the valve is any good . A solenoid in the valve opens to allow water in to the ice maker. Sometimes timers stick too.
Jul 05, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
Samsung RS261MDBP Side by Side Refrigerator Ice and Water Dispenser - Logo
Top Samsung Freezers Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
ray gallant
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
