Question about Garden
Honda f800 throttle cale
How do i fix a idle goes up and down all the time and no check engine light?
is a valve that gets stuck!, is caled a IAC valve, you can clean it but the problem more sooner than later will return, better to change for a new one, is a common problem.
is located behind the intake manifold.
http://ecomodder.com/forum/showthread.php/honda-iacv-explained-967.html
Aug 08, 2014 | 1993 Honda Accord
Cannot find a throttle cable for '97 Chrysler
you could try getting one made it would be the same as a peddal bike break cale could also try ebay or on line salvage companys who will post one to you hope this helps
Oct 20, 2012 | Cars & Trucks
WHY DO I HAVE A HIGH IDLE ON MY 1992 2.8 THROUDLE BODY ENGINE
First check to make sure the throtle cale is moving freely. do this by taking the throttle and making sure it is fully closing. it is very possible the cable is sticking within the cable housing. next you should clean the throttle body and make sure it closes with no cable attached. then check for any codes related to the idle air control motor.
Mar 04, 2012 | 1992 Chevrolet S-10 Blazer
Xl700 waverunner will lose throttle power after a good start
THIS HAS WORKED FOR ME MANY TIMES ,,,, RATHER THAN CLEAN YOUR CARBS THERE IS SOMETHING YOU CAN USE TO DO IT FOR YOU ITS CALED SEAFOAM,,, ITS A FUEL ADITIVE AND IT WORKS TO CLEAN THE WHOLE INGINE ,,,TRY THIS YOU CAN GET IT AT ANY PARTS STORE ,,,LET ME NO IF THIS WORKED,,THAKS.GOOD LUCK.
Dec 26, 2010 | Boating
La Cie Biggest F800 is down
Try hitting the reset button, on some raid arrays I have had the motherboard go to sleep mode and do the same thing so if you hit the reset button it should bring it back up. if not you will have to unplug and leave unplugged for 5 minutes before static power dies out then try rebooting. you may have to do a flash of the bios and have you done any updates of late?
Apr 20, 2010 | LaCie Biggest F800 (300942U) 250 GB Hard...
Accelator cale playing up on yamaha majesty 250.
The correct term is Throttle Cable. use needle nose pliers to remove it from the grip, take your new cable and run it the same way the old one was ran. follow the old one, then take the old cable out after installing the new cable.
Oct 20, 2009 | Yamaha G5 Motorcycles
Clutch
on the firewall there will be a small cylinder which will have fluid in it if not you will see a cable coming from there and running to the gearbox
May 24, 2008 | 1993 Honda Prelude
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
