Question about Microsoft Xbox 360 Console
My disc in my xbox 360 is not spinning
I opened the xobx up and I saw the the motor is trying to spinn but it can't
    Sergeant:
  • 220 Answers
You can try to oil the motor with a "drop counter" instrument.
I think you should send your console to microsoft or replace it yourself if you cant oil it
Posted on Jun 20, 2009
My xbox 360 will not read disc. What do I need to do
common problem with your disk drive you need to clear your cache to do this go to system setting then memory then hover over your hard drive then click y then click clear system cache call 1-800-4my-xobx if this does not work
Dec 19, 2010 | Microsoft Xbox 360 Console
My xobx keeps saying open tray then close tray then again open tray....it wont read any of my discs
Open tray error is very common for Xbox 360 users, it could be a permanent or temporary issue to check
You can check the Open Tray error troubleshooting tip i have put on FixYa, check the link here
Happy Gaming, please do take time to rate my solution
Regards
KreativeGeek
http://gamingbox.wordpress.com
Oct 26, 2010 | Microsoft Xbox 360 Console
Xbox 360 not reading discs
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1. Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser. The laser is the part that actually reads the disc. The reality is... with all the hours and hours of gameplay, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3. Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything, including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock. The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
Nov 17, 2009 | Microsoft Xbox 360 Console
Open tray error
Nov 11, 2009 | Microsoft Xbox 360 Console
Free repair help
XBOX 360 games have security codes embedded within. The motor is going out or likely filled with dust and debris that will not allow it to spin the game fast enough for the XBOX to recognize the security codes therefore telling you ''Please insert the disc into an Xbox 360 console''. Keep in mind, these DVD drives are nthing more than that. I am sure you can order a new motor online for a few dollars.
This is a guide to open your XBOX 360
http://www.youtube.com/watch?v=Uj2A7mGGjuY&feature=fvsr
ALL YOU NEED IS THE MOTOR (found on ebay, etc.) and the DVD drive will tell you the brand name right on the top of it once you have opened the console.
Good luck
Nov 04, 2009 | Microsoft Xbox 360 Console
When i put an xobx 360 disc in it says to open tray
Follow the steps below, Hope this helps
1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
2. Remove the hard drive, turn on your xbox 360 without the hard drive.
3. Re attach the hard drive and turn on your xbox 360
4. If the steps wont resolve the issue, your console needs to be serviced. Contact Xbox Customer Support to check the warranty status of your xbox 360.. Good Luck!
This issue occurs when there is a problem with the lens on your 360 disc tray..
Apr 05, 2009 | Microsoft Xbox 360 Console
Xbox 360
Listen to your dvd drive to see if it spins up or not when you put the disk in. If it does spin normally then you will be need a replacement laser.
If it does not spin correctly. The motor is stuck, sometimes if you open out the tray and stick something into the drive and give it a spin it will free the drive.
Check out this link if you have the Hitachi dvd in your xbox360
Link
Mar 18, 2008 | Microsoft Xbox 360 Console
Non playable discs
Hi i had the same problem on my 360,
so i got a new laser off of ebay,
and that didn't fix it so then i read some fourms,
and found that my drive motor that spins the disc was broken,
so i replaced that and now the xbox is working like new again :)
Jan 04, 2008 | Microsoft Xbox 360 Console
Xbox 360 Disc drive
no that's not good the motor is working over time you need it looked at quick or the moter will give up and then it will be a bigger job more money try thhttp://www.gamevania.com/XBOX_360/repair.phpis site first.
Jan 03, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
81 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stu Morris K
shaun taylor
mitch_3020
mitch_3020
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
