Question about Raypak TUBE BUNDLE 405 RP2100
Burners wont ignite
Change transformer now pilot is igniting and staying lit but the burners wont ignite
    Top Expert:
  • Raypak Master
  • 5,080 Answers
Check safety circuit
Posted on May 25, 2016
4 Suggested Answers
  • 4 Answers
SOURCE: Burners not lighting off pilot
Sorry, no solution, but I have a similar problem, so if you could let me know how things get resolved, I'd greatly appreciate it.
On mine (a 2100 model R405A), this is especially likely to happen during or after wet weather. Not sure if the ignitor is the problem. After power on, I hear the ignotor clicking for a bit and often then I hear an odd sound and then the clicking stops. My LCD is totally gone (a whole separate issue), so I can't tell you what message is there. But, usually after a good period of drying out, the unit fires up ok.
Seems to be getting progressively more prone to this as it ages (installed 2002).
If you have any more info, please let me know @ sroche@tellink.net or here
Thanks,
_Steve
Posted on Jun 22, 2009
  • 9 Answers
SOURCE: Hello, I have an old c-405b-en pool heater that
O I SEE THANKS FOR USING FIXYA
Posted on May 10, 2010
  • 990 Answers
SOURCE: Pilot stays lit, but the burner will not light
You may need to replace the pilot assembly. Or maybe the gas valve.
Their two stages to the valve and the pilot generates two hundered milivolts (less than a quater of a volt) to open the pilot valve but it takes at least another three hundered or more to open the main half of the valve, You need to have a milivolt meter to check.
Posted on Jun 22, 2010
The pilot light will only stay lit when you hold the pilot reset button in, as soon as you let the button out the pilot light goes out and the actual burners never come on. Any ideas?
Gas line is clogged if your pilot lite goes out - They got rid of pilot stoves because the pilot was always lit and using gas.
And without a lit pilot no way you can get the burner to ignite unless you use a match, assuming you have gas going to the burner!
Nov 08, 2015 | Heating & Cooling
When I try to use my Thermolaire model SU402E, the pilot lights( and stays lit), but the main burner will NOT ignite.. any suggestions as to what could cause this if the pilot stays lit?
Bad igniter? When you 1st try it the gas valve will give enough gas that you would get the burner lit if the igniter was glowing red. If you're desperate you can light the igniter area w/ an aim n flame, but you definitely want to do that w/ caution and crank up your t-stat so the furnace stays on awhile Cuz you'll have to do it again for heat or buy an igniter($40 or so)
Jan 14, 2015 | Heating & Cooling
How do I clean or replace the pilot generator on a Jandy Lite 2 pool heater? The pilot will stay lit but the main burners will not come on. Jumpering the gas valve will ignite the main burners and the
if the pilot stays lit and main burners wont fire you don't need to replace the pilot generator! you have an open safety, poor electrical connection or a problem within the tstat controls
Aug 19, 2014 | Pool & Spa
Pilot light stays lit but burners do not ignite
check to see if pressure switch wires are tight and pressure to pressure switch then check safety circuit make sure wires to gas valve are tight
May 23, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
Janitrol GUPS075-3 Furnace burners will not stay lit
The first thing I would do is make sure the flame sensor is clean, this is a metal rod immersed in the burner flame on the opposite side of the igniter. If too much oxidation builds up on it, it will not allow the burner to stay lit. To clean, just turn off furnace and remove flame sensor and clean with steel wool and then reinstall. If this does not solve the problem there may be a problem with the gas valve.
Nov 08, 2012 | Heating & Cooling
Raypak 403A, burners will not stay lit for more than a few minutes.
i'm thinking after the main valve opens the pressure could be dropping in the pilot tube. this could be due to a dirty, plugged and sometimes spider web inside the pilot tube. rare but does happen, nice warm home for a spider. good luck. if not let me know. could also be weak pilot coil.
Jun 09, 2017 | Pool & Spa
I have a Model CGN250TE.The pilot light stays lit but when you turn control valve on it stays lit for 5 seconds and then shuts right down,even the pilot light goes out.I have tried venting the room and...
I would first check the gas pressure to your furnace. Then make sure that burners are clean and watch flames when burner first ignites. I have seen burners that were dirty cause delayed ignition that would create a suction when they came on and extingush pilot and burners.
The next thing I would do is change gas valve. Thank you
Dec 19, 2010 | Williams 2509612 Ceramic Mid-Size Heater
Pilot wont stay lit
Check the thermocouple,Its is a flame senser.It will not stay lit if it is bad.
Oct 04, 2009 | Water Heaters
Water heater pilot wont stay lit
try cleaning the top of the pilot light jet if you can get to with small brush then blow it clean with a compressor.
Aug 30, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Raypak TUBE BUNDLE 405 RP2100 Logo
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
