Question about Cannon Chesterfield C60G Kitchen Range
GE gas stove ignition switch keeps clicking - Cannon Chesterfield C60G Kitchen Range
My GE Monogram Gas Cooktop model ZGU650N4DH5SS ignitor keeps sparking even after the stove is lite. What do I need to change or fix please?
Hi Ishiggs,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 11, 2011 | Cooktops
GE PRIFILE STOVE TOP KEEPS CLICKING AND THE INGITE KEEP GOING OFF ON ALL 4 BURNERS...HOW DO I STOP IT FROM DOING THIS.
Hi pauliepaul22,
Kind Regards
JEDEMEYER1
Sep 04, 2011 | GE Profile JGP636 Gas Cooktop
Ge gas stove top keeps clicking
Hello, your problem is going to be 1 of 2 problems, 1st did you spill liquid on the switch? if so the switch has shorted out, unplug the appliance for 24 hours to dry the switch out then plug it back in...if after 24 hours it is still clicking you have a bad switch (these are the burner knobs) check each one with a ohms meter, the one that is bad will read infinate on your ohms meter when it is switched off. If you have any other questions please feel free to comment. Good Luck!! Mike
Sep 22, 2009 | GE Kitchen Ranges
Pilot on GE stove keeps popping non-stop
As far a "popping" do you mean the igniter on the cook top "clicking"? Did you clean the range and use too much water? If water gets into the igniter switches they will short out and constantly click. Also if the polarity at the electrical plug you can get what is called "ghost spark" so make sure that the polarity is correct at the electrical outlet. Each gas control valve has a switch that turns on the igniter when the knob is in a certain position and they are all wired in a sequence. One of those switches may be shorted out or have a loose wire(range dis-assembly required to inspect). Do you visually see a spark at the electrodes of the burners or do the burners ignite? If you cannot see the spark then there may be a grounding issue and possible loose wire.
Sep 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE gas stove switch igniting though stove is off!
You have a bad ignitor switch. One or more of them (4) is stuck.
You need a volt/ohn meter to check the switches, one attached to each surface burner to find out which is bad.
Feb 19, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
GE Gas Kitchen sealed burner
I unplugged the wires from each end and re-attached the wires. Stove working great, no more clicking.
Dec 29, 2008 | GE Kitchen Ranges
GE profile gas stove igniter don't stop igniting
take a look at the igniter located in the center of two burners. clean the gap with a stiff brush between the eletrode and the upper plate. the distance is preset at the factory. you may have enough buildup to close the gap enough to trigger the igniter.
Oct 23, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
Stove-top burners
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
bvn
Jul 10, 2008 | Belling 27 in. CTC465 Electric Cooktop
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Cannon Chesterfield C60G Kitchen Range Logo
Top Cannon Kitchen Ranges Experts
Paul Carew
reyaazm
Level 1 Expert
Tom Chichester
Are you a Cannon Kitchen Range Expert? Answer questions, earn points and help others
