I used my dryer a few days ago now it will not come on. i bought it not even 2 years ago from sears
Hi, When you turn the timer to a cycle, do you here it clicking at all? Make sure there is voltage to the dryer. The first thing you will want to check is the fuse. Since I do not have a mode# here is how to check the fuse on the rear blower style.
UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
If the fuse tests ok, let me know and I can give you more instruction.
Please let me know if this help or if I can assist you further.
Thanks
Vic
