Question about Xerox Workcentre 7435 Color Multifunction Copier 35ppm Duplex 40gb Hard Drive
LPH FFC Connect Posi Fail K - Xerox Workcentre 7435 Color Multifunction Copier 35ppm Duplex 40gb Hard Drive
Can you purchase LPH unit magneta, LPH cable assembly, LPH Rear PWb magneta and MCU PWB parts anywhere other than from repairers that want to rip you off?
Try Ebay, many parts sellers there. Keep in mind that if your machine is over 10 years old, parts are going to be expensive because supplies are likely limited.
Sep 05, 2016 | Office Equipment & Supplies
Tip
DISASSEMBLING SERVICE MODE AND POWER SUPPLY CIRCUIT
DISASSEMBLING
(Follow the procedure below in reverse order when reassembling.)
1. Top Panel Unit
(1) Remove 9 side screws and pull up the Top Panel Unit.
(2) Disconnect FFC cable and Connector.
(3) Detach Top Panel Unit
Note : Do not pull out aslant to prevent FFC cable damage.
Do not fail to pull AC cord from wall outlet before disconnect the FFC cable.
If AC cord is remained plugged into wall outlet,
power is kept supplied in the unit, which may cause
danger.
For more check the following link
http://electro-medical.blogspot.in/
on Feb 24, 2015 | Denon Dn-X1500 Professional DJ Mixer...
How to fix C3100 Scanner carriage problem ?
Hi.
C3100: ISU home position error
It usually means the scan carriage can't move.
If it s a little MFP, you can unlock the scan with the yellow button on the left of the glass (under the DP). (This was only meant for transport reason).
Otherwise - Possible cause:
Defective FFC between CCD PWB (YC1) and control PWB (YC8).
- Replace the image scanner unit (ISU)
Defective FFC between control PWB (YC6) and scanner PWB (YC103), or improper FFC insertion:
- Reinsert the FFC. Also check for continuity within the FFC.
If none, remedy or replace the FFC.
Defective home position sensor.
- Replace the home position sensor.
Defective harness between ISU motor and scanner PWB (YC104),
or improper connector insertion.
- Reinsert the connector. Also check for continuity within the connector harness. If none, remedy or replace the harness.
Defective ISU motor.
-Replace the ISU motor.
Mar 16, 2016 | Kyocera Office Equipment & Supplies
Need Bendix King LPH 5142
You need to have the programming software and cable. It is an older radio and I do not think it is Narrowband capable, meaning you cannot legally transmit in the USA.
Dec 08, 2014 | Bendix King Radio Communications
I have a 96 ford mustang 3.8 v-6. what is the fuel pressure on the pump supposed to be?
fords fuel pumps are mesured in LPH (litres per hour) rather than pressure. I believe your pump should be rated for 155LPH. It is very common to upgrade these fuel pumps to something higher volume when they fail or to accommodate higher horsepower mods.
Apr 24, 2010 | 1996 Ford Mustang
Noise frm the fuelpump
Ones a 195 Lph the other SVT 255 LPH but it will work its better to have more fuel going to the injectors instead of the basic fuel pump. What kind of noise are you hearing?
Jun 17, 2009 | 1989 Ford Taurus
Need Bendix King LPH 5142 A Programming Software
If you have a numeric keypad which you should. You can program it through the keypad. Are you familar with programming this way?
Apr 08, 2009 | Bendix King LPH, LPA, LPX, EPH Compatible...
13D8
i have a prolem with of code 13D8 (LPH Download) of Minolta CF2002
Jan 15, 2009 | Canon PIXMA MX310 All-In-One Printer
Xerox Workcentre 7435 Color Multifunction Copier 35ppm Duplex 40gb Hard Drive Logo
85 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
matt
matt
k24674
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
