Question about LG Cell Phones
Lg ip address unavailable
Cannot connect to wifi, authentication problem
SOURCE: Can't Access Web configuraton for Cnet CWR-854 Wifi router
Have you try to update the firmware by any chance?
Let me know
comier957
Posted on Aug 10, 2008
  • 13 Answers
SOURCE: netopia 2247NWG for smarttelecom
Sorry if my writing is not clear I dont have best english.
If you move your router from eircom to smartelecom you have to change security protocol from "chap" eircom to "pap" smarttelecom.
Now Do this few steps.
Go to start menu on windows find and click run.
type: cmd and press ok
When you will see black screen that will be command prompt.
Now you have to type your defaul ip adress. To check your defaul ip adress type ipconfig in command prompt and press enter.
Default Gateway is your default ip adress. Now when you know your ip type in command prompt:
telnet yourip 23 and press enter, for example:
telnet 192.168.1.254 23
If you didnt setup any password to login to the router you will be loged automaticly and you will see "Netopia-2000/18861188>
But if you have setuped login and password to your router you have to first type your login and press enter,then password and press enter to have acces.
next is easy type:
configure and press enter
ppp and press enter
set and press enter
now you have to pressing enter about till you will see line:
option <chap-only> [ off : on : pap-only : chap-only ]:
on this line type pap-only and press enter
now start pressing enter till you see:
Netopia-2000/18861188 <ppp>>>
then type save and press enter.
When you see line:
Configuration data saved you can close command prompt window.
From this moment your router will be work with smarttelecom.
Posted on Feb 06, 2009
imransyed
  • 87 Answers
SOURCE: i cant connect to WiFi with my blackberry bold. it
Hi, this issue is caused when message authentication code (MAC) address filtering is enabled on the Wi-Fi network, and the MAC address of the BlackBerry smartphone is not accepted.
To resolve this issue, add the MAC address of the BlackBerry smartphone to the accepted MAC address list for the Wi-Fi network.
I hope this information may help you to resolve the issue.
Posted on Nov 15, 2009
SOURCE: EVERYTIME I TRY TO CONNECT MY LG OPTIMUS T TO MY
i went into the wifi set up on the optimus s and went to the bottom of the menu that shows what networks are available and clicked on add network. From there I entered the SSID from my router, then put in the password for the router, (password will depend on whether or not you have yours password protected) I hit enter from there and it connected and stayed connected.
Posted on Jan 07, 2011
SOURCE: will not connect to my
i cant connect to the wifi i have a rooter on my android acend it connect to my labtop but my cruz reader wont even make the wifi pop up its not found
Posted on Mar 25, 2011
We are getting an Authentication problem when we try to connect to our wifi.
The wifi code is usually on the bottom of the router on a label. You can change the code, or remove it by connecting directly to the router and entering the IP address of the router using a browser.
Dec 05, 2017 | Tablets & eReaders
Mac-address wifi unavailable and bluetooth address unavailable.
- go to data/misc/wifi (required root)
-backup file wpa_supplicant.conf in this folder which contains usename and password wifi
- delete all file in this folder
- turn on wifi ( if you careful, you can reboot )
- now you can connect to wifi
- recovery file wpa_supplicant.conf
Sep 12, 2016 | Huawei P8 Cell Phone
Why doesn&#39;t my netgear extender ask for name and password when I try to use it to connect to internet. It tells me that there is an authentication problem
Hi there! smile.gif Please note that the Tenda 150mbps Wireless Range Extender A3 uses a default IP address of 192.168.0.254 - you must set your IP address to the 192.168.0.* range (* = any number between 2 and 253) to login.
The default access username / password (if required) are admin and admin.
Once you've logged in, you can configure the access point to route through your existing wireless router as the default gateway (eg. if your wifi router is 192.168.1.1, then you would route through that, and set your Repeater (Extender) IP to 192.168.1.2 so that you can connect to it and then "relay" your connection through the repeater. It doesn't mirror the connection details for the existing wifi router, it simply creates an "additional" access point to connect through to your existing wifi router - creating a bridge, essentially.
The extender can be linked to the existing wifi router via LAN cable or WDS. For WDS, you will need to set the IP's 1 digit apart in the last segment (see above IP difference), and switch them both in the Wireless menu to ""Wireless Networking Mode: Network Bridge (WDS), but the SSID must remain the same (eg. "Tenda1") for both of them (it doesn't cause a network loopback), and any wireless security authentication must be identical (password / pass phrase / key + encryption algorithm) on both devices. Again, as with the above point, remember to set the gateway of the extender / repeater to that of the primary WiFi router.
For extra information and disambiguation (if required), see the following page, and scroll down: http://www.enjoypad.com/wireless-access-point/96-tenda-...
Oct 26, 2014 | NetGear N300 Essentials Edition Wi-Fi...
Authentication Problems
wrong settings entered on tablet, try again.If possible connect tablet first via usb cable to computer or router to try connecting it , to determine the actual fault on connections.
Dec 28, 2013 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
Wifi connection/ IP address unavailable
I would guess your wifi broke.. but you can always ... try wifi elsewhere to verify... if it works then you need to manually connect to your wifi... I would attempt to get your Ip off the working one and copy the same IP and DNS for your wifi... since it's a tablet I would just reset it to factory settings if it just is stuck... you can back up your files VIA google or BUMP app
Nov 28, 2013 | Mach Speed Trio Stealth G2 Tablet -...
Lg motion will not connect to network, only thru wifi, i can make/recieve calls. Also no 4g, 3g, 1x by the signal bars.
When this happened to me it was user error. Under system settings/Data Usage, the mobile option was turned off. I must have turned it off when I was checking my usage at some point.
Apr 19, 2013 | LG Motion 4G for MetroPCS with new service...
Motorola mc55 wifi problem
Hi Chris,
Pls check in wireless settings>> security settings.
Whether any MAC authentication is enable with the AP (Access Point).
If yes, kindly add the MAC address of your device which you want to connect to the AP.
Aug 28, 2012 | Motorola MC55 Handheld Mobile Computer PN...
LG KS360
Internet settings are usually found under the Phone Settings – Internet Settings.
- Connection mode Connection orientated / permanent / continuous connection
- GPRS APN live.vodafone.com
- Homepage URL http://live.vodafone.com
- GPRS ID username "none required"
- GPRS password "none required"
- Port (if required by device) 8080 (some older handsets may require you to enter 9201)
- PPP authentication type PAP (default)
- Proxy authentication name "none required"
- Proxy authentication password "none required"
- Proxy login type automatic (default)
- Security Off
- WAP gateway IP address 172.030.038.3 (your phone may require 172.030.038.003)
If you phone is a Vodafone NZ supported handset you may be able to have this sent automatically to your phone.
Mobile settings for sending and receiving PXTs (MMS messages)
The PXT settings can usually be found under Message Settings - MMS setting. You also need to send a message before you can receive one.
- APN live.vodafone.com
- MMS server address http://pxt.vodafone.net.nz/pxtsend
- GPRS ID username
- GPRS ID password
- MMS automatic download On (Automatically downloads full MMS)
- PPP automatic download PAP (default)
- Proxy authentication username
- Proxy login type Automatic (default)
- Security Off
Dec 22, 2009 | LG KS20 Smartphone
Cell Phones Logo
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
