Question about Smeg KS9XSE Stainless Steel Kitchen Hood
Fan and light not working
Lights show up on the front but light and fan not working
The fans at front of lexus/92 LS 400 don't work
1992 ls400 engine light was on replaced thermostat now lights off......fans dont work anymore,last time it worked was about 3 weeks ago now having overheating probloms
Jun 10, 2012 | 1991 Lexus LS 400
Some dashboard lights are out
Do any lights in the ac control head work for illumination ?
Jan 23, 2012 | 2002 Chrysler Town & Country
Push Button and Computer fan starts then immediately shuts off (1 Second) .Yellow light on front does the same comes on 1 second then off .Nothing else happens . It is a Dell Dual Core 2 fans.
chek your power unit or the cpu fan working or not if the cpu fan is not working computer will turnoff immediate to save it you better show you computer for technician soon
please rate this solution.....
Apr 11, 2010 | Dell Inspiron 531s Desktop Computer
Battery drain. alternator and battery ok. 30 amp fuse in front location shows arc. can't identify what fuse controls. is there a schematic which will show these fuses and their. purpose? ie coutesy lights,...
my battery drain indicator lamp is lit on my 2000 Toyota Camary. i checked the battery and have 12.5 volts when not running and 14.5 volts when running with lights & heater on. since all my other gauges are working ok i'm not sure if its a fuse or what fuse. can you help. altenator shows 14.5 volts when running.
Oct 26, 2009 | 2001 Toyota Avalon
Lights on fan knob does not work
the bulbs are made into the a/c control head and are not replaceable. the only way to get them working again is to replace the hole assembly.
Aug 18, 2009 | 2004 Mazda 6
Projector turns on the power light flashing and lamp light solid
Here's the fix: Take off the top cover of the projector. Unplug the wire leading from the two fans in the back of the unit to one of the circuit boards in front of you. Just trace one wire from fan to board. Unplug at board. Turn unit on and it will again turn on, show HP splash screen and then shut down, like it should, because the fans are now disabled. After it completly shuts down, plug the fan wire back into the board. Turn the unit back on and, presto, its working again. It will not turn off.
Try it!
Jun 12, 2009 | HP Digital Projector Vp6120 Multimedia...
Turns itself off after 5 seconds of run time. will not stay on, cooling fans work, lights up screen and shows picture, then shuts off. light flash on front right corner.
Either lamp is failing (not covered under any warranty), or the ballast has failed. Or it may be a problem with the power supply, or even the fans... What is the picture next to the flashing light? If it's only the lamp light, then either lamp or ballast, if temp is flashing (the thermometer), it will be fans, temperature sensors, main board or power supply.
Apr 22, 2009 | Samsung HL-T5675S Television
Smeg KS9XSE Stainless Steel Kitchen Hood Logo
79 people viewed this question
Top Smeg Kitchen Ranges Experts
Richard Ballard
Richard Ballard
Level 1 Expert
Joseph Mueller
Joseph Mueller
ashburton
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
