Question about Nilfisk Vacuums
Keeps shutting off
Runs for 1 minute and shuts off
  • 44 Answers
Check out your pwr lead could be faulty. just replace it
Posted on Sep 05, 2014
Oreck vaccum cleaner runs about 4 or 5 minutes then shuts down.
this means you have a blockage somewhere on the vac
Feb 17, 2013 | Oreck Vacuums
My Broan-NuTone central vac shuts off after I am vacuuming for a couple of minutes. I turn it off for about 10 minutes and start vacuuming again and it keeps shutting off. What is wrong with it? I...
Some of these units have had trouble with the motors and this is what causes them to shut off. NuTone has been pretty good about replacing them under warranty. 1-888-336-6151.
Aug 17, 2011 | Broan-NuTone VX475 Bagged Central System...
It was working fine and them just stopped it is not that old and was not making noises HELP!!
Vacuum cleaners have electric motors in them that require proper airflow to pass over them to keep them cool. Many vacuum cleaners have a thermal (heat) sensitive shut off mechanism built in. This mechanism should prevent the burn out of the motor. If you run a vacuum too long with a clogged hose or clogged filters (especially bagless vacuums) or clogged bags, that is essentially choking the vacuum for air and not allowing it to breath properly. This will cause it to overheat and shut down. Most of the big box store purchased vacuums have very thin wires in the motor windings and can only do this a few times before the motor completely fails. If your vacuum has been shutting down, then cooling off and restarting after about 30 to 45 minutes, then shutting down after only a few minutes of use, your machine is probably clogged up or the filters are compacted.
Jul 05, 2011 | Vacuums
My iRobot Roomba runs for about ten minutes, then shuts off. I can keep pushing the clean button and it will run for another ten minutes and stop again. Nothing seems to get clean.
Take the brush rolls out and you should see a copper disc. It is the dirt sensor. Clean it with Windex or some other cleaner. This works sometimes.
Sep 08, 2010 | iRobot Roomba 550 Vacuum
Keeps shutting off
You cant clean the HEPA filter.. only the blue washable pre filter.
Sounds like the motor is dead or atleast on its way out.
If you visit http://www.sparesaver.com/help-and-support/dyson-section/dyson-technical-advice-450/ they have alot of info on repairing dyson cleaners AND they sell the parts, cheapest ive seen online.
Hope that helps
Jun 28, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My Hoover runs for a few minutes and shuts off.
It's possible the thermal reset is defective. It shuts the motor off if it gets hot. Remove the bag door and take the bag off, remove both filters and then turn the vacuum on, just leave it sit there with the motor running. This eliminates the bag or filters causing any airflow resistance. If it still shuts off after a few minutes it's likely the thermal reset is bad. Some vacuums have an external thermal reset button which can be replaced if necessary but on your model it is built into the motor and you must replace the motor. If the motor runs fine put the bag and the filter under the bag back in - (make sure the filter is clean and not restricting airflow) put the bag cover on then turn it on again. If it overheats and shuts off then you may have a clog on there somewhere restricting the airflow. If so check the power nozzle area, the hose coming from the power nozzle, the extension hose and wands for clogs or restrictions.
Sep 22, 2017 | Hoover U6426-900 Bagged Upright Vacuum
We have a dyson root cyclone and it shuts off after a about 5 minutes of running. Then after about 10 minutes it will run again.
Your description is typical of a machine that's overheating. This is almost always caused by a blockage, as restricted airflow can't keep the motor cool and the automatic cut-out shuts the machine off. It re-sets itself when it's cooled a bit. Check your operator manual for how to clear blockages, and also check that your filters are clean.
Nov 28, 2009 | Vacuums
Runs for a few minutes. Loses suction the shuts
It sounds like it's draging on the motor Also heating up the thermister switch. I would recomend having this look at from a vacuum repair shop ask for free estimates if you call around. save some $$$
Nov 10, 2009 | Royal RY9200 Bagged Upright Vacuum
Shutting off due to overheating
The foam style filters they sent you go in the top of the vaccume above the canister. There is a sticker in the back of the canister compartment indicating an orange lever in the top of that compartment. This releases a plastic retainer with the foam filter in it. Mine was so caked with dirt after 1 year of use it took a while to clean it up. I thought the vaccume was done for in only a year.
Jan 13, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Vacuums Logo
55 people viewed this question
Top Nilfisk Vacuums Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Thatvacguy.com
Are you a Nilfisk Vacuum Expert? Answer questions, earn points and help others
