Question about Video Game Consoles & Games
It makes me type baclwards and frezzes and makes a clicking noise when i try to type why ?
    Problem Solver:
  • 13 Answers
You might have a problen with your laser lens, umd drive or umd its self. do any other umds work?if not and you still have a warranty i strongly recommend you get a new one before your warranty expires, if youd hate to send it back to sony because they might give me you the new PSP that cant be downgraded, you could just open up your PSP and clean the UMD drive (once you open your PSP the warranty Expires straight away,so that wouldnt be something i would do)if you still want to do it follow this simple steps.
1. How to open your PSP
Tools needed:
One small size Phillips Screwdriver, if you dont know what that is you should probably not try to open your PSP, ok its something that look like this X
On picture 1 you will see the 5 screws that need to be removed to open the PSP, marked with red arrows. If you are not going to remove the whole inside of the PSP then dont bother to remove the 2 screws marked with green arrows. There is also no need to remove the whole label inside the battery compartment. I just did it for this picture.
2. How to remove the LCD screen
Its quite easy to remove the LCD screen, just use a small flat screwdriver and put in the side like you see in the picture and pry it open. Now dont slip, you dont want to put a big scratch in the LCD screen.
Now it will look like this, and you will see the screen is attached with 2 orange flat cables. Always be extra careful when opening this type of clips, they can very easily be damaged.
3. How to fix stuck L/R buttons
This is how it looks like when you have the stuck button problem, its not very common, but I have seen it a few times. Fortunately its easy to fix. It should be noted that Sony have fixed this issue as far as I know on new productions, so new comit makes me type baclwards and frezzes and makes a - psp3.jpgldnt be worried about this.
Before you start doing this, check what part of the plastic that actually get stuck and then just use a nail file to remove some of the plastic, put it back, test again if it still get stuck. If it does then file down some mit makes me type baclwards and frezzes and makes a - psp4.jpg be careful not to remove to much or you will end up with a lose button instead.
Copyright http://www.pspmod.com/forums/hardware/14387-psp-wont-read-games-repeted-clicking-noise.html
DigitalJedi1 www.iPSPhone.webs.com
be sure to visit my site for fre Mp4 Movies & more
Posted on Jul 19, 2009
Have a ASUS M2N-E and when i boot it appear the BIOS window, then it frezze in "press DEL to enter setup", well when i press DEL it frezze with the message "Entering Setup...." and...
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
or if this does not fix the problem
Click start control panel keyboard you can change your settings there
or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers
click start control panel keyboard hardware then properties you hould see driver details and have options to,update driver,roll back driver,uninstall
click start control panel administrive tools computer management device manager scroll to keyboard you might see a yellow question mark ? right click update driver
if your computer came with a motherboard disc the drivers could be on it
diconnect the keyboard then reconnect it then reinstall the driver
make sure the lead has a secure seating if applicable or the usb device
test leads attached from motherboard to hard drive make sure connections are good and dust free
you might have to many programs running at the same time try uninstalling a few unnecessary programs also scroll to the bottom of your screen toolbar right click select task manager applications & processes you will see what is running if you see something you dont need running select end now you might have a virus freezing/slowing your computer you might need to install more RAM
click start right click on my computer select properties you will see all imformation about your computer including installed ram
if you need more help with this post a reply
hope this helps you
Sep 01, 2011 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
My computer makes dinging noise when I type.
Try This
Go to "HELP SUPPORT"
Type "on screen keyboard"
click on settings on on-screen keyboard
click on make click sound.
Jul 21, 2011 | Dell Dimension 2400 PC Desktop
When it is below frezzing my Isuzu makes a clicking sound instead of starkting but in warm weather it starts all the time ?
more then likely the battery is going bad. in cold weather it takes a good (cca) cold cranking amps, battery to turn engine over. but in warm weather the engine is not as cold and therefore needs less cranking amps. thats why you hear clicking when trying to start car in cold. it is the solinoid clicking and not enough power for starter to turn it over.
Feb 06, 2011 | 1993 Isuzu Amigo
Frezzes every time I **** it a tiny bit
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to recover bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
then you should test or replace all leads make sure they are securely seated and are not bad/faulty that are attached to your hard drive the ones from your motherboard
hope this helps
Jan 06, 2011 | Computers & Internet
MY 1984 BUICK REGAL SWITCH TO INGINATION TURNS BUT CAR WILL NOT CRANK UP
If the car dose not make any type of noise when you try to start it is is a power issue and you should check your battery and wiring to make sure there is no lose wires. if it dose make some sort of noise please respond with what type of noise it makes and I will do my best to point you in the correct direction.
Thank you hope this helped.
Thank you,
Norse
May 16, 2010 | 1984 Buick Regal
It frezzes in my games it frezzes in the opening ds thing and some time when i turn it on the thing dosent come on even after i charged it
This problem generally occurs if the ds card or sd memory card corrupted.
try to turn it on without ds card ...
maybe you need to reformat the sd card, do not forget to make backups first.
May 15, 2010 | Nintendo DS Lite Console
My xbox360 is frezzing
Try cleaning the vents on the console with a vacuum cleaner with the xbox OFF
Then try playing without your hard drive
if it doesnt freeze without the hard drive youve got a problem
ring up xbox
Dec 16, 2008 | Microsoft Xbox 360 Console
Frezzer not frezzing
if you have a old refrigerator it is probaly dying this happened to my parrents fridge a couple years of ago so they got a newer frigde and it works good but if you by a fridge make sure you by name brands
Jun 23, 2008 | Refrigerators
Computer making noise
Monitor clicks, pops, or makes other noises. Issue: Monitor clicks, pops, or makes other noises.
Cause: This issue could be caused by any of the below possibilities:
  1. Monitor degaussing.
  2. Monitor changing resolution.
  3. Monitor syncing with the video card.
  4. Monitor warming up.
Solution: Noise when turned on or off It is normal for standard computer CRT monitors to make a click, pop, crackle, hum, buzz, or other type of noises when they are first turned on or turned off.
Noise when monitor goes into standby mode When the monitor enters a "standby mode" or "power savings mode" this is similar to the monitor being turned off. It is completely normal for the monitor to make a noise when the monitor enters this mode.
Noise when opening Microsoft Windows or other operating system or when opening a game When a computer opens its operating system, for example, a computer opening Microsoft Windows or when a user runs a computer game it is very common that the monitor will need to switch its resolution of the operating system or game. When switching resolutions it is normal for the computer monitor to make some type of noise and/or for the computer monitor to flick or flash.
Noise during normal operation If the computer monitor click, pops, or flashes while it is being used this is not normal operation. It is very likely that the monitor may be failing or a component within the monitor has already failed and could also potentially be a fire hazard. We highly recommend that the monitor be repaired, replaced, and/or looked at by a qualified technician.
Additional information:
  • See document CH000302 for additional information and other noises that may come from
Jan 16, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Video Game Consoles & Games Logo
118 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
