Question about Seagate Maxtor BlackArmor 160 GB USB Hard Drive
Want to remove encryption from black armor drive
Sandisk instructions
Which operating system ?
Encryption is a method of preventing unauthorized access to computer files.
When you apply encryption to a file, the file is altered so that it cannot be read by others, unless you have given them an encryption key.
Windows XP supports encryption through EFS, the Encrypting File System.
If you have encrypted a file on your Windows XP computer, but no longer want or need the file to be encrypted, you can remove file encryption by changing the file's properties in Windows Explorer. Locate the file from which you want to remove encryption in Windows Explorer.
Right-click on the file, then click the "Properties" link in the context-menu.
This opens a Properties window.
Click the "Advanced" button in the attributes section of the Properties window.
This opens the Advanced Attributes window.
Click to uncheck the box next to "Encrypt contents to secure data" in the Advanced Attributes window.
Click the "OK" button to close the Advanced Attributes window.
Click the "Apply" button in the Properties window, then click the "OK" button.
This closes the window and completes the encryption removal process.
Open Encrypted Files
Windows XP supports file encryption through EFS, the Encrypting File System.
You can encrypt files with EFS so that only you and designated users can open them.
You open files that you encrypted just as you would any other files.
However, you cannot open files that another user encrypted with EFS, and other users cannot open files that you encrypted, unless the user trying to open the file has been added to the list of authorized users for that file.
You can authorize users to open encrypted files using the Windows XP EFS management tools.
Click the "Start" button, then click the "My Computer" icon on the Start menu.
This opens the My Computer window. Navigate to the encrypted file for which you want add an authorized user.
Right click the encrypted file, then click the "Properties" link in the context menu. This opens the Properties window.
Click the "Advanced" button in the Properties window.
Click the "Details" button in the Advanced Attributes window.
This opens the Encryption Details window.
Click the "Add" button in the Encryption Details window.
This opens the "Select User" dialog box.
Click the user you want authorize to open the encrypted file, then click the "OK" button.
This closes the dialog box.
Click the "OK" buttons in the Encryption Details and Advanced Attributes windows to close them. Click the "Apply" button in the Properties window, then click the "OK" button to close the window and complete the process.
Apr 09, 2014 | SanDisk 64GB USB 2.0 FlashDrive Cruzer...
My buffalo hd pntu3 hard disk is encrypted using the default software from drivenavigator , securelock easy manager. how to remove the encryption?
In the software Secure Lock Manager Easy is a tab "Setting the Encryption mode" Pressing "Releasing encryption mode" will remove the encryption. Make a backup of the data before please.
Nov 03, 2013 | Buffalo Technology Buffalo MiniStation...
Decrypt files on a mac
Maybe there is a version of the software you used to encrypt that is compatible with mac ?
May 05, 2012 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
How can i take the bitlocker off my PNY 4GB flash drive?
Windows version like XP.
There are 5 steps to remove BitLocker Drive Encryption from removable drive. Here are the steps.
  1. Open Control Panel then click on BitLocker drive encryption link.
  1. On the nest window, click Turn Off BitLocker link on your removable drive or USB flash drive.
  1. Next, the BitLocker Drive Encryption window will appear, click on Decrypt Drive button to start the decryption process.
  1. The decryption progress takes some minutes to finish, so wait until the process completed. Do not plug off your removable drive during the process.
  2. After the process completed, a message box appears, tell you the decryption process was completed. Click on Close button to close the window.
right click on your 4 gb usb drive select turn of bit locker in W7
hope it helps you
Mar 09, 2012 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Need to remove bitlocker from USB2.0
hope it helps you
Mar 09, 2012 | Electronics - Others
What the enter code of murloc RPG?
I assume you mean item codes
Arcane Crystal Pendant, 5 Armor. +8 Intelligence Item Level 13. Rare Necklace, 32fad4e73aacbfe603fe487dd92533cd
Assassin's Blade, 3 - 5 Damage. +3 Strength Item Level 5. Rare Dagger, 2b42fbe4e8a7786a5ede7196dda2009f
Deathslayer, Emerald Blade, 9-16 Damage +25 Strength Item Level 20. Legendary Dagger, ab6627d02488d8b2868773e723fa54c4
Dragonskull Helmet, 400 Armor. +15 Strength Item Level 18. Epic Helmet, b76096738777404b54b617450104639f
Eternium Band, 0 Armor. +35 Intellect Item Level 16. Epic Ring, 1014cb602659291e718c1e7d8ddd3e4e
Geisha's Silk Kimono, 85 Armor. +50 Agility. Item Level 17. Epic Chest, e54fa6df48764bcf9b007d5b8f994deb
Hellfire Choker, 75 Armor. +8 Stamina Item Level 12. Uncommon Necklace, a53f9c3cb5f5cfe528ef94bc3a5b71c4
Lightforge Belt, 341 Armor. +9 Stamina. Item Level 15. Rare Belt, f6ad75ef1ab32154ef5e38d98257193c
Lightforge Boots, 424 Armor. +18 Stamina. Item Level 15. Rare Boots, abe905f768246d765472c3c3011cf463
Lightforge Bracers, 261 Armor. +10 Stamina. Item Level 15. Rare Bracers, f89a8621e099077f711d851a046f3d58
Lightforge Breastplate, 657 Armor. +21 Stamina. Item Level 15. Rare Chest, c519c769d5b5f003a15d8d440f182d25
Lightforge Gauntlets, 386 Armor. +9 Stamina. Item Level 15. Rare Gloves, f0a5460aa9c3c253ff48591149ca8036
Lightforge Helm, 526 Armor. +20 Stamina. Item Level 15. Rare Helmet, 2b3f59fc332d6b41e82004b6a01b21bc
Lightforge Legplates, 557 Armor. +14 Stamina. Item Level 15. Rare Pants, d21ea2c7ea7b624304c561dedbbab993
Lightforge Spaulders, 470 Armor. +15 Stamina. Item Level 15. Rare Shoulders, f1c4d3de306f0e1c21a6ebfb87acf975
Magister's Belt, 46 Armor. +21 Intellect. Item Level 15. Rare Belt, 6f66fdf2958135180caaff47e7756acf
Magister's Bindings, 35 Armor. +15 Intellect. Item Level 15. Rare Bracers, 876dfa68b59dc748922a4f41fe5ec30f
Magister's Boots, 58 Armor. +14 Intellect. Item Level 15. Rare Boots, a6d7b08a3661918afb247faa01c7c50c
Magister's Crown, 71 Armor. +30 Intellect. Item Level 15. Rare Helmet, 539a0cd3c30117eb6c89924c326ded97
Magister's Gloves, 52 Armor. +14 Intellect. Item Level 15. Rare Gloves, 0e146b974d2af70ede16c5d9bd2e4d04
Magister's Leggings, 76 Armor. +20 Intellect. Item Level 15. Rare Pants, 2945df577062a57e79f5d503df376191
Magister's Mantle, 64 Armor. +22 Intellect. Item Level 15. Rare Shoulders, 0367078991a9f977fc83e368603be298
Magister's Robes, 89 Armor. +31 Intellect. Item Level 15. Rare Chest, 55c279a7ff3e914993c5d3bb244be07b
Reforged Katana, 5 - 14 Damage. +15 Strength Item Level 18. Rare Sword, be8f6bb0fc46d73d3d2127abd2d980b1
Rune of Duty, 20 Armor. +7 Stamina. Item Level 8. Rare Trinket, 4de0edd84a5ac30876667dfe4e4009c5
Samurai Platebody, 570 Armor. +24 Stamina. Item Level 15. Rare Chest, 233fb5eca3e8bd88b820e75964cf1472
Seal of the Assassin, 0 Armor. +25 Agility. Item Level 15. Epic Ring, 63066f40fd5b28e390db3384b212a286
Shadowcraft Belt, 93 Armor. +14 Agility. Item Level 15. Rare Belt, c803bde9e49df539aa14082ed1b94de9
Shadowcraft Boots, 115 Armor. +21 Agility. Item Level 15. Rare Boots, cd288664eba2e60d5b078d41fea5a5b8
Shadowcraft Bracers, 71 Armor. +15 Agility. Item Level 15. Rare Bracers, 6bc3f89b33af3cc59ce9ce4f5d7144fc
Shadowcraft Cap, 141 Armor. +20 Agility. Item Level 15. Rare Helmet, 95efb4c45096600b12c772e0def87261
Shadowcraft Gloves, 105 Armor. +14 Agility. Item Level 15. Rare Gloves, 9d5541f805c7a0c85b6a43a314dfcc67
Shadowcraft Pants, 150 Armor. +25 Agility. Item Level 15. Rare Pants, 7ebfeed79bc005ca4e2b06f22088a1db
Shadowcraft Spaulders, 127 Armor. +22 Agility. Item Level 15. Rare Shoulders, 5a2e5f321b4c2175e4c04e168ed1510b
Shadowcraft Tunic, 176 Armor. +26 Agility. Item Level 15. Rare Chest, b5ca348dc4291ee71084e3c3ac193c63
Shimmerweed Branch, 69 Armor. +15 Intellect Item Level 12. Uncommon Trinket 852897b7ad210cc446262732f73cb919
The Emperor's Shield, 5214 Armor. +15 Intellect. Item Level 20. Legendary Shield, 3ffcd8a5055189bc00ad45fbe275ba6e
Worn Dagger, 1 - 2 Damage. Item Level 2.Poor Dagger, 8b8ffef1a9ffa52dbf6ac9170daa2fe3
Zul'Gurub Mango, Reset Zul'Gurub. Item Level 1. Epic Special Item, f6436f5b34a934c38deef9f775d0f582
Jul 30, 2011 | Video Game Consoles & Games
My Maxtor "black Armor" 160
Beeping is a certain sign of hard disk failure.
You have no other option but to replace the drive.
Consider price rather than capacity, a larger drive may well be currently cheaper.
Feb 10, 2011 | Maxtor Hard Drive
My 120 gigabyte western digital hard drive is locked. It is readable on system and on dos but i cant access to it , I cant format, I cant fix any thing on it . and when I tried every programs on the...
It is an "armored" disk. "Government grade" disk. With encrypted codes.
This means that if you are not the original purchaser of the disk with the right software and password, There is no way you can access it.
It cannot be formated, erased or accessed.
Aug 29, 2009 | Acomdata HD500FPMM-72 500gb Mini-pal Combo...
Armored fist 2
Try finding out what drive the disk is in by going to My Computer and it should be something like "ArmoredFist(F:)" then copy what it says and go to Start, Run, and put in the information you copied. If that doesn't work, right click the "ArmoredFist(F:)" or similar drive, and click "Explore". Then look for a file called "AutoRun" or "Install". Hope that helps you.
Feb 20, 2009 | NovaLogic Armored Fist 2 for Windows
Seagate Maxtor BlackArmor 160 GB USB Hard Drive Logo
139 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
