Question about Cooktops
All error codes kleenmaid ivk60 - Cooktops
Kleenmaid CH600CE ceramic cooktop stopped working
U sure power is getting to cooktop ?- chances of all burners not working and/or going bad at same time is ridiculous.
Get out your VOM and start tracing the voltages back to point of inception.
Sep 17, 2016 | Cooktops
What does error code E-13 mean
Hello there
Sounds like a 'gas sensor' (whatever that is) error. I recommend calling Samsung Support or a qualified Microwave Technician
SMH2117S/XAA Microwave Is Displaying An Error Code If your microwave is displaying an error code, such as -SE-, E-11, E-12, E-13, or E-14, or any other trouble code not listed here, cycle the power to the microwave by either unplugging the unit, or cycling the circuit breaker for approximately 60 seconds before restoring power.
If the above suggestion does not work,and the error code returns, your microwave will require service.
namo_fileview.jsp?type=nfs&pid=decisiontree&did=466719&cid=5uwnecasicas@namo.co.kr&sep=%7c
Sep 21, 2014 | Samsung SMH2117S 2.1 cu. ft....
What is ge error code 0225
I have the same issue and was told by GE that it will take a technician to fix it because it is not a known error code. Most error codes start with "f", F0, F1, etc. This the second time a tech had to come out for this cooktop. Probably the last GE I buy. Definitely won't buy anything electronic. I want regular knobs on the next one.
May 05, 2014 | General Electric Ge Profile Pp975bmbb 36...
Whirlpool error code e2 f3
The error codes are in the operating instructions if you don't have it ask Bosch to email the error code page to you.
Apr 10, 2014 | Bosch Cooktops
Gas Kleenmaid cook top, one igniter continues to
the switch for the ignitor is stuck. might need to free the switch, of
> call the repair man.
Oct 20, 2013 | Jenn-Air 30 in. CCG2423 Gas Cooktop
E30ic80iss electrolux error 31
Good Morning D, I am happy to assist you. Error code E31, commonly refers to an internal generator error in the left side cooking zone and that the generator control board needs replacing. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, I would recommend connecting with an experienced appliance repair tech to assist further.
Jul 30, 2013 | Electrolux E30IC80ISS Cooktop
Electrolux E 95 code
Hello Robert - Typically, error code E95 indicates a power voltage miscommunication to the main components of the unit. You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, then I would recommend contacting a professional to proceed further.
Apr 25, 2013 | Electrolux 36" Electric Hybrid Induction...
I have the 5 element induction cooktop with no
Call 1 800 442 1111 Its whirlpool they own kitchenaid. they can find a local tech for you
Dec 12, 2009 | Cooktops
I would like a circuit diagram for a Kleenmaid CH 14 Cooktop
Hi, I too have had a problem with the dual element on the Kleenmaid CH14. Likewise I was given an Invensys M82314 which as you will know is not configured in the same way. However, I assume that what they call"phase" is the active connection, the neutral is marked and are side by side like the old one, pilot is idicated and is the wire that bridges together with the other switches....you are only left with two...."load1" and "load2" whichever way around I apply those I can only get my inside burner to run. I am baffled !! My old switch operates both burners but keeps cutting in and out.
Nov 11, 2009 | Cooktops
I want to switch my 5 burner kleenmaid CH80x8 natural gas cooking top over to LPG what size jets or injectors do I need. Regards James. Centre burner is for a wok current jets are 50. 78. 85. 62. 95
LPG to natural, natural is bigger than LPG injector exmaple LPG 50=natural 69-
LPG 78=natural 91
LPG 85=natural 115
LPG95=natural 130
PLG 62=natural 85
Sep 09, 2009 | Cooktops
Cooktops Logo
63 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
