Question about Maytag Dishwashers
How to remove impeller from maytag dwu7400
Replace impeller
2 Suggested Answers
SOURCE: pump disassembly
I removed the impeller on my DW761UQB. The instructions were molded into the plastic pump housing. This is how I DID MINE: Remove motor mount screws. Remove the chopper screw (screw only goes into impeller, not motor shaft). Remove chopper and rotate/remove strainer. Place socket or wrench on impeller tip and place another wrench on rear of motor's plastic fan. Unscrew fan from impeller shaft ( threads are LEFT handed, turn CW). Once fan is 'backed off' of the impeller, CAREFULLY pry the motor/fan from pump housing (impeller is attached to motor shaft via splines). Don't crack the delicate plastic pump housing. Mine was stuck, but separated with moderate force. Now remove the impeller/seals from the pump housing. This worked for MY above mentioned model, I don't know what other models it applies to. I am not a pro.
Posted on Dec 16, 2010
I HAVE A MAYTAG PIHXD2-18KW4A I NEED THE IMPELLER TURBINE
Fixya does not sell replacement impeller turbines. Check with a local appliance parts supplier.
Aug 29, 2016 | Maytag M6Q10F2A Air Conditioner
Hello, I have a Maytag Stainless Steel MDBH975AWS dish washer. After water fill, it is very noisy almost like a grinding sound. Is there a common problem? Is there an exploded parts view somewhere so I...
impeller is jammed onto shaft ,remove motor with 1 bolt ,remove impeller by putting a plastic pen in bottom of motor turn impeller counterclockwise inspect for clearance or obstruction.either replace impeller or do like I did and put a spacer,poor design on keeper circlip caused my problem.I got my spacer from a scooter wheel between the bearings & cut off enough plastic on the impeller shaft for clearance,always good to have a spare scooter wheel laying around!!!!!!
Sep 29, 2010 | Maytag Dishwashers
Dishwasher - clean/replace screen on bottom
Try running a wash with vinegar in it, empty the dish washer and get it started once the water is going into it empty a bottle of vinegar into it and it should remove most of the alkaline build up.
No need to rinse before the next use as the normal cycle does a hot rinse at the end.
Regards
chris
Jan 15, 2010 | Kenmore 64802 Top Freezer Refrigerator
Dishwasher - soap dispenser won't open while washing dishes
A simple was motor is used to open that.
This video shows how to change a door latch but the dispencer basically does the same thing. HERE
Maytag dishwasher with a spray arm that is stopped up and I need to remove it and clean it.
We have a dwu7400 so i'm not sure it is the same, but above the top arm you should see a serrated ring (looks a bit like a flower petal) and that should spin off and the arm should come with it. There's a snap that holds those pieces together that if you squeeze it with your fingers you can get it out. Just reverse that to put it back together.
Nov 06, 2009 | Maytag 24 in. DWU7402 Built-in Dishwasher
Maytag Neptune purchased brand new in 2007. Tumbler won't spin and water doesn't get pumped out, all I head is a humming noise coming from the water pump. I opened the back and could feel the water pump...
There is something jamming the impellers in the pump (coin, nail, bobby pin, ect.) You need to manually get the water out, remove the pump, and see if you can find and remove the obstruction. If you find something in the pump and remove it, check the impellers before you put the pump back in. There are 3 plastic impellers, make sure none of them broke off. If they did not break off, your good to go. If one or more broke off, you will need to replace the pump, you cannot buy just the impellers. good luck.
Oct 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer won't drain maytag neptune washer MAH-3
Check the drain line for kinks or obstructions. You can take a flashlight, remove the hose from the pump and look into the suction port of the pump. Check for anything clogging the pump. (like the occasional stray sock). Also check the pump impellers for broken or missing blades and ensure that the pump impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective and will need replaced. Hopefully it is just a clogged pump or drain line. Hope this helped and best wishes.
Sep 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag dishwasher has a grinding sound during the
Hi
Many times a complaint of noises ( grinding or scraping ) can be traced to a cracked impeller in many of the common motor and pump assemblies used today. Sometimes a poor washing complaint is common after this wash impeller has cracked. Remove power first before investigating.
The motor shaft has started to rust and swells out and this swelling cracks the upper impeller. Most times a new seal and impeller kit can cure this complaint but sanding and cleaning of motor shaft is required before replacing the new seals and impellers.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 03, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Pump disassembly
Sep 25, 2008 | Dishwashers
Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Jan 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Dishwashers Logo
24 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
