Question about Radio Communications
How do i clean my new glasses - Radio Communications
    Master:
  • 623 Answers
Soft cloth and water with just a bit of dish soap.
Posted on Nov 07, 2014
Sharp IR 2016 platine glass dirty
The cover plate is above the glass white surface of the scanner. If this is the same dirty stains will come out on copies.
The glass must be clean.
By feeding the original documents through the ADF, the scanner lamp is no longer the path to scan, the ADF is responsible for passing the original document over the scanner, while it remains still placed on the side under a thin glass is to a large glass side. This also must be clean, otherwise you will be black lines on each point or spot on the glass.
Good luck ...
Feb 28, 2012 | Office Equipment & Supplies
The faxed copy has a big black line in the middle of the paper. A new toner and a new drum have been installed but the line is still there. Help! Ruth
Clean the scanner glass. This is the smaller piece of glass that is located just to the left of the large original glass. Or if you have an older or smaller model Brother the strip of glass is going to be located under/inside of the port where your documents are fed into the machine. This operation panel usualy just pops open and you can find the strip of glass inside. Just clean it with a bit of glass cleaner that has been sprayed on a soft cloth. Make a copy with the machine to test if the line is gone. If the copy mode comes out ok then your outgoing faxes will be ok. You can also make a copy before you start the cleaning process as the copy with the line on it can aid you in determining what area the glass needs to be cleaned.
Good Luck and Thank You for using Fixya.
May 11, 2011 | Brother Office Equipment & Supplies
How do you clean the inside glass on the oven door
You need to take the door off and apart. Glass is very hard to clean as the dirt bakes on it, so if you want it to look like new then just buy a new piece of glass.
Jun 05, 2010 | KitchenAid KEMC308 Electric Double Oven
Good morning; We have a new Jenn-Air black glass
Any proprietary glass top cleaner should be suitable. Avoid using a wire based scouring pad but the Scotch type 'plastic/foam' cleaning pads are ok.
Jan 04, 2010 | Jenn-Air Ovens
How do I replace the back window?
Remove the black vinyl trim from the edge of the glass. Remove broken glass & urethane adhesive from the metal pinchweld leaving a thin layer (approx 1/16") of urethane for new new urethane to adhere to. Vacuum broken glass. Prime nicks to the metal to protect from rusting (also insuring a good surface to bond to). Attach vinyl reveal molding to glass (unless it's a "T" shaped push in type - it would install after the glass is set). Clean and prime the replacement glass. Apply new urethane adhesive. Set glass in place.Slide the metal joint cover in place on the molding (at bottom in the center). Clean outer surface of glass. Allow for safe drive away as noted by urethane manufacturer.
Sep 25, 2009 | 1995 Oldsmobile Cutlass Ciera
How to install my back windshield in a mazda mx6 93
Easer said than done! First remove all the window trim from the inside of the car remove all outer window mouldings. Next take your special tool {electric knife} and cut the kit (rubber under the glass) all of the way around the window. Then use your handels (suction cups) and remove the glass. Clean the leftover kit off the flange then clean the flange with a good solvent. Install the new kit and place the new glass on the kit. Brush the glass sealer on the flange kit and 1/8 inch of the glass. Replace all mouldings and trim very carefully. If the glass didn't brake or leak your done. Needless to say if you don't have the experionce with glass don't try it. Instead call AUTO GLASS SPECIALIST.
Apr 27, 2009 | Mazda MX-6 Cars & Trucks
Grease in between glass on oven door
You have 2 pieces of glass that are separated by a frame then sealed. What has happened the seal has been broken and thus allowing air and grease inside. You can take it apart but the grease will come back, or you can buy a repalcement glass and be done with it. The question is, do you want to go to the trouble of cleaning the glass (1-2 hours of disassembly and assembly) probably once every 2 months depending on how often you use the oven, or buy a new one and it will always be clean. One caution, cleaning the glass periodically weakens and flexes the metal frame or band thus making it harder to properly seat the glass.
Feb 22, 2009 | Kenmore 47783 Electric Single Oven
Cleaning glass on oven door
Get a stanley blade and scrape the glass clean that way, you will not hurt the glass, better if you can fit it in a holder of some sort.
I do mine that way, and it always gets the baked on fat and grease off.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Ovens
Self cleaning caused interior glass to crack
hi there,
this is called thermal breakage. basically, when the mfg. makes the glass, they either don't cook it long enough or let it harden long enough during manufacturing. remember, the glass is supposed to withstand over 1200 degrees, which is temperature during self cleaning. have a technician replace the door glass, as warranty should cover this.
thanks
Sep 26, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
