Question about Refrigerators
Kenmore elite refrigerator 106.56684502 control panel not working
SOURCE: bad electronic control
Replace it if it is defective.
Posted on Sep 28, 2007
SOURCE: kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out.  IT costs $200/yr.  They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit.  He said that a new motherboard and the labor alone was going to make it $498.  Anyway,   he had ordered a new motherboard. Apparently the motherboard wasn't working.  It is located in the back bottom left side of the refrigerator behind the panel.  There is a compartment on the lefthand side that slides out and houses the motherboard.  He put that in and also had to fix the fan that is in the back of the freezer.  That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all.  So at least take a look at the fan in the freezer.  Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover.  Maybe that's the problem with your refrigerator, the fan.  Hope that's all it is. Good luck!
Posted on Jun 25, 2008
tech master
  • 120 Answers
SOURCE: Sears Kenmore Elite Refrigerator model
need model number even though it says kenmore we need to know the model will tell us the maufacturer but start by checking voltage at the outlet to see if you have proper ground
Posted on Oct 17, 2008
  • 13 Answers
SOURCE: kenmore elite trio 596.76539500 control
On a Kenmore Trio 78729 made by LG, open left door and push the Ultra Ice and Refrigerator button simultaneously for 5 seconds. The display will change from 0 OFF to temperature settings.
Posted on Feb 15, 2009
Bothcoasts
  • 10 Answers
SOURCE: kenmore elite refrigerator temperature controls
I am sorry I am not a top refrigerator expert. It sounds like there is a way to reset that. You most likely hold down two buttons for a period of a few seconds.
Sorry I don't have the time to search the net for that particular manual or way to reset that board. If you have no luck by tomorrow try me then.
Posted on Jul 27, 2009
My kenmore elite side by side refrigerator control panel is giving us a ph. Does not dispense water or let you use the setings.
What is a ph, pray tell?
If not dispensing water, does the water solenoid get activated? Is it working? Check
Aug 28, 2017 | Kenmore Refrigerators
Kenmore elite refrigerator is not cooling, but the freezer seems to be working fine.
Kenmore Elite refrigerators come in several styles, including units with a freezer at the top and units with freezers at the bottom. The top and bottom of the fridge work on different systems. Sometimes the freezer may function perfectly, while the fridge performs poorly. Most issues with the fridge cooling are due to incorrect settings or poor cleaning practices. Checking common problems with the refrigerator will help you diagnose the situation and keep expensive repairs to a minimum
1. Check that the Kenmore Elite refrigerator is plugged in. Inspect the circuit breaker of the home if the refrigerator is plugged in but not running.
2. Pull the unit out from the wall and vacuum the condenser coils at the back of the unit.
3. Turn the temperature control in the Kenmore Elite refrigerator to the "On" position.
4. Turn up the temperature on the temperature control, located inside the unit on the wall.
5. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the Kenmore Elite fridge door.
6. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the fridge door.
7. Move food away from the vents inside the Kenmore Elite refrigerator.
I hope i solve you problem.
Have a nice day : )
Sep 04, 2011 | Refrigerators
I have a Kenmore elite 13102 dishwasher touchpad that has begun to crack around the start button. Does this necessitate changing out the whole electronic control pad or is there a part that is the...
You will need to replace the touch pad assembly. You can purchase the part from the link below.
Kenmore elite Dishwasher Parts Link
You can read an article that explains how to make this repair yourself at the link below.
Appliance & Refrigerator Repair
Mar 22, 2011 | Dishwashers
Kenmore bottom freezer control panel error ER FF
it is probably the defrost controller and the board on the back. The code means your freezer fan is not working
Nov 11, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
INVENSYS CONTROL FOR KENMORE ELITE SIDE BY SIDE
Hi, you can purchase replacement part on amazon, here: Amazon com KENMORE ELITE INVENSYS CONTROL I hope this was helpful. Cheers
Apr 27, 2009 | Kenmore Refrigerators
Kenmore elite trio 596.76539500 control panel says OFF.
Dec 10, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite Trio
dh means there is a defrost problem with unit you need to repl the controler in evaporator. you will have food loss if not taken care of asap if is under a year old call the tech out there
Oct 14, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite refrigerator Model 596.76533500 temperature control panel locked?
I have this problem also my control panel is not working. It has an Er If on the panel.
Oct 08, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice and water dispenser lock light stays on and comes back on quickly after pushing and holding. No water or ice dispensed while light on. Kenmore Elite 23.1 ft side by side refrigerator
I resolved the problem on my Kenmore Elite model 106.55616400 by removing the drip tray, taking out two screws that hold the panel, and disconnecting and reconnecting the wires from the panel to the board. Unplugging the refrigerator did not work.
May 28, 2008 | Kenmore 25.1 Side-By-Side Refrigerator...
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
