Question about Refrigerators
Kenmore fridge model 106.56684502 control panel is not working
tech master
  • 120 Answers
SOURCE: Kenmore 546033 Side by side Control/Display panel dead
yes the only way is to repl the control board and make sure your outlet is properly grounded but you might wan t to unplug and plug it back to see if it resets but still it has to be repl ok
Posted on Jan 19, 2009
Sea Breeze
  • 4654 Answers
SOURCE: GE side by side refrigerator model GSH25KGREWW
You said that the control board on rear of your refrigerator was replaced and there is still nothing happening? You do need to check the power behind the refrigerator to make sure there is power, yes.When did the control board get replaced and was it new?. Sea Breeze.
Posted on May 28, 2009
SOURCE: Sub Zero Model 680 - Light in Fridge and Control Panel out
Try wiggling light switch side to side kinda hard, (the light switch is the one on the left) it should come on, showing you its a bad lt. switch.if that fails install 1 new 40watt,(long) appliance bulb. but it is going to be the switch or the bulb considering there wasn't any wiring work done on unit. part# for the light switch is 3060140 make sure the back of the switch is white not black (black is a fan switch) Good Luck !!!
Posted on Mar 04, 2012
  • 313 Answers
SOURCE: i bought a used Kenmore Model # 53562201 side by side fridge. We pushed the temperature controls for the fridge side up to highest setting. Now it will not push back down and things in the fridge sid
you need a new jazz board (control panel)
Posted on Apr 12, 2012
richroth
  • 9472 Answers
SOURCE: kenmore top fridge not cooling bottom freezer working fine
Do you see ice on the back of the freezer wall?
Posted on Oct 19, 2012
I bought a fridge from liquidation a Kenmore model #59649539018 freezer works finebut the fridge is not cooling they changed the control panel but still not working
There should be a fan in the freezer that moves cold air into the fridge. The fan might not be working. The temp setting for the fridge is a door that opens and closes depending on the setting. Check to make sure it works.
Nov 19, 2014 | Refrigerators
Kenmore fridge. freezer top works, but bottom doesn't.
Either your fan has stopped working, or it is not defrosting. Take the back panel of the freezer off and see if the evaporator coil is iced over, if it is replace the deforst heater, and the deforst thermostat. If the compressor is running the fan if the freezer should be running. Also make sure both your fridge and freezer controls are centered. Putting the freezer on the coldest setting acutally shuts off airflow to the fridge.
Dec 05, 2009 | Kenmore 71192 / 71194
Kenmore model 596.72253201. Bottom freezer works, fridge does not
The most likely reason is part number 12566102 Adaptive Defrost control board. The next likely are the defrost heater and the defrost thermostat,Sea Breeze I will send you photos. below
Sep 10, 2009 | Kenmore Refrigerators
Kenmore Fridge Defrost fan wont stop running
Hi, The defrost timer is located in the control panel. There should be 2-4 screws holding the control panel. Remove the screws and lower the panel to see the defrost timer. There are 2 screws holding the defrost timer in the control panel.
Please let me know if this helps you at all or if I can assist yyou further.
Vic
Jul 21, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Need Front Control Board, Kenmore Refrigerator Model 106.4410230
Solved it through parts isolation and identification.
Apr 05, 2009 | Kenmore Refrigerators
Jan 17, 2009 | Kenmore 54603 / 54606 Side by Side...
Kenmore bottom freezer refrigerator
This sounds like the Maytag bottom mount that has a High Voltage Control Board problem. Does this have the freezer/fridge temp. display/controls on the left hand fridge door? Whats the model number and on the manufacture tag does it something on it like Code:0304 maybe? Let me know I may have an answer I do work on these for a living.
Jan 26, 2008 | Kenmore 73503 Stainless Steel Bottom...
Temperature Control / LEDs
some models had bad control moduals
Dec 12, 2007 | Kenmore 65002
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
