Question about Uniden Radio Communications
Sound on and off
Hi there, dropped scanner. Problem: Turn on and there is sound (also sound when pressing buttons), within 10 seconds there is no sound and no sound when pressing buttons. Scans fine and holds but with no sound. Thank you
    Problem Solver:
  • 16 Answers
You probably broke a solder connection on your volume control or on the main board. Look for the dark ring around a solder joint that has broken loose. A dab of solder will fix the problem.
Posted on Jul 07, 2014
shaggyrat
  • 1224 Answers
SOURCE: no sound
speaker points jared loose inside might need to soder back on
Posted on May 12, 2008
SOURCE: NO SQUELCH
I have a Radio Shack Pro 97 Scanner that I received as a present 1-1/2 years ago. It was working just fine and then suddenly there was no squelch or volume. The keys make noise when pushed, but there is no sound for the squelch or volume. The scanner scans the frequencies but does not stop and play. I went on line and found that other people were having the same problems. I went back to the store that the unit was purchased from and received no help what so ever, they said it’ s off warranty and I was out of luck, nice way to do business??. I think that something that cost as much as this should not be junk after a short period of time. I hope you can help me with this problem I do like radio shack, but I can’t afford to buy items that don’t stand up.
Sincerely
Greg Stevens
e-mail
fooyun@sbcglobal.net
Posted on Aug 28, 2008
  • 5603 Answers
SOURCE: I HAVE A RADIO SHACK PRO 97 SCANNER WAS WORKING
Check if one of the batteries MIGHT be in backwards.
NEXT check EACH cell as occassionally you get a bad one brand new.
Posted on Nov 14, 2009
  • 211 Answers
SOURCE: uniden bc145xl police scanner NO SOUND
It sounds like you have smoked the audio amplifier. It is an 8 pin IC marked "IC2" on the circuit board where it is mounted. You may also be able to see "TBA820M" stamped on the case of the IC itself. Since you said that smoke was visible from the speaker jack, it will likely be obvious which component it is once you open the scanner.
Unfortunately this scanner has no internal or external fuses.
If this does not work, go to www.mods.dk, as they have a downloadable schematic and troubleshooting manual for this model. The site does require a free registration, but does not spam or sell your address. I have downloaded several manuals from them over the years, and all were extremely helpful.
The link to the file you need is
http://www.mods.dk/downloadmanual.php?RefFil=BC-145XL_Alignment.zip&radio=
I hope this helps! Good luck!
Posted on Feb 20, 2010
BillB-SA
  • 2761 Answers
SOURCE: SCANNER SHUTS OFFABOUT 10 SECONDS AFTER i TURN IT ON
This is usually a sign of weak/worn out batteries. Make sure that your batteries are fresh/fully charged and that the contacts are free of corrosion.
Bill B
Posted on Jul 28, 2010
Security system reset
THIS IS FOR YEAR 2000 BUT MIGHT WORK FOR YOU. you did not give year!
Follow to the exact step by step in order for it to work
You must have one working remote to add one more to the system. If you do not have one working remote right now then these instructions will not work. You will have to have a Locksmith or dealership use a computer to program the first remote for you.
1. Turn ignition to run position (as far as you can go without starting engine).
2. Using any Working remote, press the UNLOCK button for 4 to 10 seconds.
3. Within the specified 4 to 10 seconds, continue pressing the UNLOCK button and press
the PANIC button for 1 second and release both buttons at the same time. A chime will
sound within 3 seconds to indicate that the vehicle has entered remote programming
mode.
4. Within 30 seconds of the chime, press any button on all remotes to be programmed
including previously programmed remotes. A chime will sound after each remote is
programmed.
5. Turn ignition to OFF and remove the key
6. Test all remotes at this time.
Aug 18, 2013 | Dodge Dakota Cars & Trucks
Remote control car parts
You may need to reprogram the remotes.
3. Within the specified 4 to 10 seconds, continue pressing the UNLOCK buton and press
mode.
programmed.
5. Turn ignition to OFF and remove key.
6. Test all remotes.
Aug 12, 2013 | Chrysler New Yorker Cars & Trucks
T & C 2001 REMOTE CONTROL PROGRAMMING
ATTENTION: You MUST HAVE one working remote to add one more to the system.
1. Press LOCK button 5 times at 2 second intervals to resynchronize remote.
2. Insert key into the ignition switch. Turn ignition to the RUN position (as far as you can
go without cranking engine). Wait for ignition chimes to stop.
3. Using the working remote, press and hold the UNLOCK button on the remote for 4 to 10
seconds.
4. Within the specified 4 to 10 seconds, continue pressing the UNLOCK button and then
press the PANIC button ( on the programmed remote ) for 1 second and release both
buttons. A chime will sound to indicate that the remote programming mode has been
entered ( allow 3 seconds for chime to sound ).
5. Within 30 seconds of the chime, press and release the LOCK and UNLOCK buttons
simultaneously then press and release just the UNLOCK button on the same remote.
A chime will sound indicating the remote has been programmed. Press and release
the LOCK and UNLOCK buttons simultaneously and then press the UNLOCK button on
each new remote you wish to program at this time. A chime will sound afer each
additional remote is programmed.
6. Turn the ignition OFF and remove key.
7. Test Remotes.
Sep 17, 2012 | 2001 Chrysler Town & Country
How to program a fob keyless remote
ATTENTION: You MUST HAVE one working remote to add one more to the system. If you do not have one working remote right now then these instructions will not work. You will have to have a Locksmith or dealership use a computer to program the first remote for you.
mode.
programmed.
Jun 17, 2012 | 2002 Chrysler PT Cruiser
How do I program an additional remote for my 2003 Durango
  • You must have a programmed FOB to program another at home with my instructions below. If you don't have programmed one then you must get the first one programmed at the dealer.
  1. Press LOCK button 5 times at 2 second intervals to re-synchronize remote.
  3. Turn ignition to the run (no start.)
  4. Wait for ignition chimes to stop.
  5. Using the working remote, press and hold the UNLOCK button on the remote for 4 to 10
  6. seconds.
  7. Within the specified 4 to 10 seconds, continue to hold the UNLOCK button and then press the PANIC button ( on the programmed remote ) for 1 second and release both buttons. A chime will sound to indicate that the remote programming mode has been entered ( allow 3 seconds for chime to sound ).
  8. Within 30 seconds of the chime, press and release the LOCK and UNLOCK buttons simultaneously then press and release just the UNLOCK button on the same remote.
  9. A chime will sound indicating the remote has been programmed. Press and release the LOCK and UNLOCK buttons simultaneously and then press the UNLOCK button on each new remote you wish to program at this time. Locks will cycle after each additional remote is programmed.
  10. Turn the ignition OFF and remove key.
  11. Try your remote.
  • Hope this helps.
Oct 23, 2011 | 2003 Dodge Durango
My alarm system went off due to wrong key ingnition...had to take a battery terminal off to stop the alarm, now I have the key and it wont start...is there a security reset?
Yes there is. 1. Press (LOCK) button 5 times at 2 second intervals to resynchronize transmitter. Attempt to function transmitter, if working as designed discontinue programming. 2. Turn ignition to run position. (Allow ignition chimes to stop).
3. Using any original (working) transmitter, press the [UNLOCK] button for 4 to 10 seconds.
4. Within the specified 4 to 10 seconds, continue pressing the [UNLOCK] button and press the [PANIC] button for 1 second and release both buttons (AN/DN release either button first). A chime will sound to indicate that the transmitter programming mode has been entered (allow 3 seconds for chime to sound).
5. Press [LOCK] and [UNLOCK] buttons simultaneously for 1 second and release (a short chime will sound for AN/DN).
6. Press and release any button on the same transmitter and a chime will sound after successfully programming the transmitter (locks will cycle for AN/DN).
Aug 15, 2011 | 2002 Jeep Liberty
How to program key fob 2003 durango
remote for you.
seconds.
7. Test Remotes.
If I've helped you, please vote!
Feb 02, 2011 | 2003 Dodge Durango
How do i program 2003 dodge carvan key fob
remote for you.
Click here to find an Automotive Locksmith in your area to program this remote.
seconds.
7. Test Remotes.
Feb 05, 2010 | 2003 Dodge Grand Caravan AWD
Reprogram 2005 dodge durango key fob
Daimier Chrysler North American Remote Keyless Entry Programming procedures
Program Method A (Customer Program Method)
1. Press (LOCK) button 5 times at 2 second Intervals to resynchronize transmitter, Attempt to function transmitter, If working as designed discontinue programming.
2. Turn ignition to run position, (Allow Ignition chimes to stop).
3. Using any original (working )transmitter, press the [UNLOCK] button for 4 to 10 seconds.
4. Within the specified 4 to l0 seconds, continue pressing the [UNLOCK] button and press the [PANIC] button for 1 second and release both buttons (AN/DN release either button first). A chime will sound to indicate that the transmitter programming mode has been entered (allow 3 seconds for chime to sound).
6. Press and release any button an the same transmitter and a chime will sound after successfully programming the transmitter (locks will cycle for AN/DN).
NOTE.- (FOR DR ONLY) A CHIME WILL NOT SOUND ON STEP #6 FOR THE FIRST TRANSMITTER PROGRAMMED, BUT WILL SOUND UPON PROGRAMMING THE SECOND TRANSMITTER.
7. Repeat steps 5 through 6 to program additional transmitters.
8. Turn ignition to OF:F position. Transmitter programming mode will discontinue after 60 seconds (30 seconds for AN/DN and RS). (All transmitter programming must be completed within time specified).
Nov 05, 2009 | 2005 Dodge Durango
How to program a new remote keyless entry for 2002
seconds.
7. Test Remotes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 02, 2009 | 2002 Dodge Durango
Radio Communications Logo
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
