Question about Shop Fox W1702 3 HP Shaper
Spindle vibrates and shakes - Shop Fox W1702 3 HP Shaper
What much be done to fix the bad veberation?
Steve, if your mower is vibrating or shaking bad. you need to check the blades. if you have hit a tree root or big rock that has damaged the blade it will do this. also check to see if the deck belt is not damaged. ripped a chunk missing or frayed. try to wiggle the blades underneath, if the wobble you may have a bad deck spindle bearing.
Apr 22, 2016 | Garden
My washer is making vibrating, squealing and scraping noises. Recently we purchased a pedestal drawer by Frigidaire and installed it
Hi Stephanie,
The higher you raise the dryer, the more pronounced the vibration will be. This can be a result of worn bearings or spindle the allows the drum to spin around its center easily. This is not really a DIY project unless you've got tools and a fair amount of mechanical ability.
The scraping sounds may be from these same bearings and spindle parts - but can also be the result of worn out drum glide pads on the front of the dyer that supports the spinning drum. You can purchase these as an entire set (model specific part) and replace these fairly easily with a few simply tools and modest amount of mechanical ability. You can see the process in this video:
Dryer Repair Replacing the Dryer Drum Glide Whirlpool Part 37001298
You can reduce the amount of shake by slipping vibration reducing pads such as "Shakeaway" from Lowe's (and others). If one set under the dryer doesn't provide satisfactory results, adding a second set under the pedestal just might.
Dec 29, 2014 | Frigidaire Washing Machines
One blade on my Craftsman riding mower does not cut as good as the other one. It is a 42" deck. 05 model mower. I have sharpened the blades and balanced the deck. Could it be the spindle (mandrel)...
This may sound silly but, is your deck level? They often have adjustors 0n each side or possibly one of the deck hangers is not secured and one side of the deck is higher. Spindles vibrate like crazy if the bearings are worn. also spindle shafts will shake back and forth when you push the blade up or down..Disconnect the drive belt from the engine and spin the blades, they should spin easily and fairly quiet, if they squell loudly with a rubbing metal on metal sound replace them, it is fairly simple and not too expensive.
Feb 24, 2011 | Craftsman Garden
Craftsman 19.5hp 42'' deck lawn tractor with vibration only when the cutting blades are engaged.I have changed the blades but the the tractor still vibrates alittle. when I disengage the blades the...
Check your spindles, especially the shafts in the spindles. If one of them is bent, it'll make the blades vibrate as they spin. You can find replacement shafts and spindles at Partsbuggy.com.
Dec 18, 2010 | Garden
Mower deck shakes when PTO is engaged
An imbalance is causing your vibration. check the blades. You probably have a bent or damage blade. Could also be a bad spot on the deck belt or a damaged spindle.
Good luck.
Sep 06, 2010 | Mtd Garden
Washer drum shakes excessively during fast spin
y shaped piece that contains the spindle that attatches to the basket and allows it to spin is corroded and cracking. you can't buy just the spindle bracket, you must buy the basket too. you'll be buying the front part of the drum too, if you wait to long.
Feb 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool ghw 925 washing machine
The drum mounts to a spindle on the back. On these units, it is common for the tripod mounts for this particular design to crack and break. On every call I have had for a terrible vibration on these models, this has been the problem. The remedy is to replace the front and rear tub, as well as the basket. It is also recommended that you replace the drain pump at the same time. Most of this should be covered under at least a parts warranty
Oct 27, 2008 | Whirlpool GHW9400 Front Load Washer
Washer shakes violently
The drum mounts to a spindle on the back. On these units, it is common for the tripod mounts for this particular design to crack and break. On every call I have had for a terrible vibration on these models, this has been the problem. The remedy is to replace the front and rear tub, as well as the basket. It is also recommended that you replace the drain pump at the same time. Most of this should be covered under at least a parts warranty.
Oct 25, 2008 | Frigidaire Affinity ATF7000ES Front Load...
94 acura legend
hello first thing is you need to check your front tires for a bent rim cupped tire or busted belt missing weight if you cant tell swap front to rear drivers front to drivers rear dont crisscross try again if still there possible ,spindle bearing ,cvjoint shaft bad trannymount or engine mount goodluck
Sep 07, 2008 | 1994 Acura Legend
Shop Fox W1702 3 HP Shaper Logo
27 people viewed this question
Top Shop Fox Saws Experts
Tom Chichester
ray gallant
Are you a Shop Fox Saw Expert? Answer questions, earn points and help others
