Question about General 13hp Honda Belt Drive 4000 Psi Ts4040 Pump
While spraying i feel a slight studdering
Feels like a bump bump bump then goes away and come back the same
How do i fix the vibrating noise/feeling especially on the left hand side of the nissan bluebird sylphy?
If the noise gets worse making a right turn, then goes away or close on a left turn. It is a wheel bearing. If it an engine mount. Put a jack under it and lift the engine slightly. If the vibration goes away. I suggest you replace all the other mounts.
May 14, 2016 | Nissan Cars & Trucks
****? studder or miss?
Do you have a tow hitch on your truck? Does it rattle when driving on bumpy roads? I had a truck same year and make when on a certain road the timing would ****** problem traced to knock sensor.
Mar 02, 2012 | Cars & Trucks
We recently purchased a 2007 gmc enoy denali with 30k and we have had a few sensor / electronic issues and the warranty has covered everything and these issues have been resolved. However, recently we...
Why would you have a lot of carbon build up on
a 4 year old vehicle. I wouldn't listen to anything a dealer tells you.
You can not tell if a cam is out of balance.
Those issues are designed into and taken care of
when the cam is made.
Start by asumming the original owner did nothing
Change all fluids,brakes,power steering,trans,coolant,
spark plugs,fuel & air filters,etc,everything.
Now you have a base to work from.
Remove the ducting and shine a light into the intake beyond the
throttle plate. If it is clean the dealer is full of it.
Spray the Throttle with CRC and the MAF Sensor,with CRC MAF Cleaner
Strip all 4 brakes,clean off all rust,machine rotors or file off ridges on rotors,and put anti-seize
on pad and caliper sliding abutments.
Check drive shafts for u-joint play
Do not trust a pro to do any of this correctly,do yourself.
Then get back with more on the clunking and bumping.
Stay away from dealers!
Nov 25, 2010 | GMC Denali Cars & Trucks
I have a bump feeling in my front wheel when riding slow
Chances are the brake rotor has a slight warp in it. What you are feeling is the warp rubbing the brake pad.
May 26, 2010 | 2006 Yamaha Roadliner
I have a 1997 volkswagon golf, an it feels like the back end floats everytime I go over a bump. Doesn't feel very stable to me. Could it be a suspension problem?
push down hard on back end then release suddenly,should bounce up then level straight away,if it continues to bounce,one side or the other then replace both shockers(match pair) easy job.
Mar 19, 2010 | 1997 Volkswagen Golf
2000 buick regal, abs studdering noise.
If you are braking hard and one or more wheels lose grip, the ABS system will modulate brake pressure in pulses to the slipping wheels. That is a normal feeling when this is happening. If you have a pulsation under light braking, it is likely that you have brake rotors that are no longer true and and need to be replaced or machined.
Mar 07, 2009 | 2000 Buick Regal
Noise when driving
it sounds like a bad main and thrust bearing
Feb 28, 2009 | 2008 Nissan Rogue
General 13hp Honda Belt Drive 4000 Psi Ts4040  Pump Logo
21 people viewed this question
Top General Plumbing Experts
ka4iup
ka4iup
Gil Shultz
Marty Shuman
Marty Shuman
Are you a General Plumbing Expert? Answer questions, earn points and help others
