Question about Brother MFC-9120CN Multifunction LED Multifunction Laser
Brother MFC 9120 print unable 28 - Brother MFC-9120CN Multifunction LED Multifunction Laser
Mix-it-up
  • 832 Answers
SOURCE: Cleared printer jam, message Unable to print 30
...and 50? Is it toggling between those two error codes?
Anyway, see here what to do:
http://www.fixya.com/support/t211210-brother_mfc845cw
Posted on Mar 11, 2008
  • 583 Answers
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Posted on Jul 13, 2009
Semi-Driver
  • 434 Answers
SOURCE: brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
Posted on Jan 21, 2010
pineworks
  • 4041 Answers
SOURCE: Brother MFC-465CN says 'Unable to Print 5A'
Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
SOURCE: unable to clean 50 error
I have a Brother MFC-440CN fax machine and I am receiving error message "unable to clean 50". Can anyone help me to fix this error problem
Posted on Apr 20, 2010
Print unable 71
Print Unable 71 means Polygon Mirror Failure on the Brother HL-4040, MFC-9840 and MFC-9440.
Pretty safe to say it means the same thing on the MFC-8880.
The Polygon Mirror is part of the Laser Unit, and its rpm isn't within specs.
The Laser Unit must be replaced.
Jan 08, 2015 | Brother MFC-8880DN Mono Multifunction...
Unable to init. 4F
4F is Main PCB Faulty unfortunately most likely from Power surge. Do you have warranty ?
Feb 25, 2014 | Brother MFC-J615W Compact Inkjet...
Print unable 28
Error code 28
Print Unable 28
Turn the power off and then back on again.
Drum drive motor 1 (K, Y) failure
Sep 07, 2013 | Brother MFC-9840CDW Laser Printer
I haved an error message on my Brother MFC-665CW--unable to print 51
in my printer brother mfc-7340 when i coping with machine after some time display will show print unable with error code 72 what i will do? plse tell me;
Apr 07, 2013 | Brother Multi-Function Center MFC-665CW...
I have a Brother MFC-9120cn. when I send a test page the Green led /Data light flash but not print ever comes. I have reloaded drivers and firmware. It also say Offline and the is no print job in the...
If you send me an email to LBrown18062@hotmail.com, I will send you the user manual and the software installation guide. please put "brother mfc 9120 user and install" as the subject.
Sep 12, 2012 | Brother MFC-9120CN Multifunction LED...
Brother mfc-290c print unable 73
hi
try to make hard reset
or download the latest drivers/ program from the site of brother .
some times they apdate automaticaly your programs - and some times it makes problems !!
bernard
http://www.rylwy.com/
Jul 07, 2011 | Brother MFC-290C Multifunction Color...
Unable to clean 50 error
Jan 13, 2010 | Brother Office Equipment & Supplies
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
Brother MFC-9120CN Multifunction LED Multifunction Laser Logo
281 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
