Question about Dyson Vacuums
Interchangeable parts Do dc 35 parts work on a dc56?
My dyson keep pulsing and I have taken it apart and cleaned everthing
hi Janet.
this link should show you step by step on what to check.
https://www.dyson.com/support/dc56/dc56-dyson-hard/my-machine-is-not-working/machine-makes-a-pulsating-noise-dc56/not-resolved-blockage-checks-dc56
found this on the internet.
I would suggest that this is a blockage of some kind as the pulsating is caused by a lack of airflow (the motor is protecting itself by pulsating and then ultimately cutting out).
I would recommend looking at the following video which will take you through a methodical way of checking this. The model in the video is a DC59 but applies to most cordless models: https://www.youtube.com/watch?v=fdnu4yk-5vI
Furthermore, I would check the bin inlet to make sure that the one-way door/flap is not jammed as this also can cause the problem.
If you continue to have difficulty, please give the Dyson Helpline a call on 1-866-693-9766 (US), 1-877-397-6622 (CA), 0800 298 0298 (UK). Our experts will be happy to talk you through some further diagnostic checks when you have your machine easily to hand.
if need to try and find more out go to this link.
why does my dyson keep pulsing Google Search
Nov 23, 2017 | Dyson Vacuums
Tip
Dyson Hard DC56 or DC57 cordless vacuum cleaner - Getting started
How to assemble and use your new Dyson Hard DC56 or DC57 cordless vacuum cleaner. Our video also shows you how to attach and remove the wet wipe, and how to use the Double edge floor tool without the wet wipe for general hard floor vacuuming.
on Oct 04, 2013 | Dyson Vacuums
My dyson dc 35 is not working green light comes on bur nothing happens
If your Dyson DC 35 is battery powered, the battery may be unable to charge/recharge.
Jul 13, 2017 | Dyson Vacuums
Can I leave the battery charger plugged in my Dyson dc 44 animal after it is fully charged?
Hi, I have a Dyson DC56 with a lithium battery for about 18 months and I leave it plugged into it's charger when not in use. I do notice the Dyson charger seems to switch off automatically when charged. I don't have any problems so far. It you have a Genuine Dyson Lithium battery and the genuine Dyson charger it should not be a problem. That is because Lithium batteries have very precise requirements for their charging cycles and therefore the correctly designed charger required to make them work safely is a somewhat intelligent design and needs to be of good quality in having to meet those requirements. So use the original Dyson Charger. Also most high current Lithium Batteries will also have a protection circuit built in further increasing safety and reliability. Just don't use cheap cloned Chinese made Lithium chargers, because you will never know if they have been designed or even will operate correctly.
Now if you have old technology Ni Cad (Nickel Cadmium), LA (Lead acid) or NiMH batteries with basic cheap chargers they should not really be left connected to a charger full time.
Dec 07, 2016 | Dyson Vacuums
How do I remove the battery from a Dyson DC56. There is no push button.
hi lisa, it's jack at dyson.
dc56 does not include a push-button to remove the battery - instead, the battery is fixed securely in place with two screws. this brings it into line with the other cordless and handheld vacuums in our range.
the battery is not intended to be removed on a day-to-day basis. however, if the battery ever needs replacing, it can be removed by undoing the two screws which hold it in place.
i hope this helps, but if you need any additional advice on using or maintaining your dc56, you're welcome to get in touch. you can reach our experts directly on 1-866-693-9766 (us).
Jan 22, 2015 | Dyson Vacuums
How do I get a user manual for Dyson DC56?
Hi there, it's Jack at Dyson.
You can download a .pdf copy of the Dyson Hard DC56 user guide directly from our website: http://www.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/dc56_Manual.pdf
You might also find our Getting started video guide useful when using or emptying your machine:
I hope this helps, but if you'd like any further advice you're welcome to contact our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 28, 2014 | Dyson DC56 Hard Cordless Hard Floor Vacuum...
I have a dc56, will the new tangle free turbine tool, part No 925068, fit it?
Hi Lyn, it's Jack at Dyson.
DC56, the new Dyson Hard vacuum cleaner, is engineered for quick cleanups on hard floor surfaces - wood, laminate, lino, tile etc. It also converts into a powerful handheld vacuum for dusting tasks around the home and inside the car.
The Dyson Hard is not designed for use on carpeted floors, and we do not manufacture a motorised head for this machine as it lacks the wiring and connections needed to supply current to a motorised head.
Airflow-driven Turbine heads, such as the Tangle-free Turbine tool, are engineered to work with the performance characteristics of our mains-powered vacuum cleaners, and are not compatible with Dyson cordless or handheld vacuums.
However, we do have a range of accessories which are compatible with DC56, and you can find these on our website: http://www.dyson.co.uk/accessories/variant-accessories.aspx?pid=DC56-dyson-hard
Apr 02, 2014 | Dyson DC56 Hard Floor Wet/Dry Bagless...
Pipe valve on dc07 same as one on dc 17
Hi there, the parts are not interchangeable, but you can purchase a replacement valve pipe for your machine via our website at www.dyson.com.
Kind regards
Darran
Dyson Customer Service
Apr 11, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
26 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
