Question about AT&T GoPhone Z998 4G
Turn off startup sound - AT&T GoPhone Z998 4G
How to turn off startup sound in sansui LED
Live with it. No way to turn off startup sound of your Sansui LED TV.
Nov 27, 2014 | Sansui Televison & Video
How can I turn off startup sound
StartUp sound is good for your system because it will tell you something but if you want to turn it off then try to
press the F10 key on your keyboard to mute you Mac before rebooting or use any app for it. if you want to know the importance of startup sound than follow Apple Support Number .
Jul 15, 2014 | Apple MacBook Air
Turn startup sound
Go to control panel> Sound and Audio Devices> Sounds> Sound scheme>Windows Default> Apply>ok
Jul 05, 2013 | Dell Inspiron Computers & Internet
My screen is black with no picture
If you turn on the computer and the lights come on and the fans start but you see no picture, try turning up your volume to listen for the windows startup sound. If you hear the windows startup sound it is likely your video card or the monitor on the laptop. If you hear no sound the power could be faulty or the computer could be completely fried. Follow this link to get your laptop taken care of by HP http://h71036.www7.hp.com/hho/cache/405979-0-0-225-121.html
Mar 15, 2011 | HP Compaq nc6120 Notebook
No statup sound in system
Restore the Startup Sound in Windows 7 If you decide that you want the Windows Startup back on your computer, just follow the steps explained above, but this time, check the "Play Windows Startup Sound" checkbox and click OK. The change is saved immediately, and turns back on this sound for the next time you reboot your PC!
Sep 26, 2010 | HP Compaq dx6100 PC Desktop
Every time i turn on my laptop i get a massage. this program cannot display the webpage
You will probably need to disable something in your startup using msconfig. Go to Start>Run>msconfig then press enter. Disable all unnecessary startup items. You will also want to uninstall any unneeded programs, then do a registry cleanup. It sounds like you are just trying to connect to broken link on startup.
Jul 20, 2009 | Computers & Internet
No sound
Try this:
Click Start, select Run, type "services.msc" without the quotes and press Ok. Services window will open up. In that window, select the Windows Audio Service and the status and startup type of the same. In case the startup type is disabled, double click on it and select the startup type as Automatic. After that right click on this service and click Start. In case the Start is greyed out, click on Restart. Now check for the sound.
Jul 07, 2009 | Compaq Keyboard
Can't turn speakers back on
Hi, a try would be to reset the PRAM by pressing cmd - alt - P - R simultaneously at startup untill you hear 3 startup chimes, then try to change the sound settings
May 22, 2009 | Apple MacBook Air
How do I turn off the initial startup sound
Yes, there is a way to turn this function off in the menu.
Nov 22, 2008 | Samsung LN32A450 LCD Monitor
Turning off the startup tune.
Go to the menu, settings ,sounds.. turn off startup sounds.. you should have sounds for when you take a picture and maybe a few more.... If you can't turn the sound off you should be able to lower the volume of the sound you don't want so as you can't hear it....
Hope this helps.....
Oct 31, 2008 | Jazz DV-179 Digital Camera
AT&T GoPhone Z998 4G Logo
90 people viewed this question
Top AT&T GoPhone Cell Phones Experts
Lawrence Oravetz
J.D. Browning
J.D. Browning
Are you an AT&T GoPhone Cell Phone Expert? Answer questions, earn points and help others
