Question about Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Remove front panel on frigidaire affinity dryer "faqg7111lwo
How do I remove the front panel
  • 172 Answers
SOURCE: error code E4A on my
This is a board communication problem, you need to replace the control board. If you send me the model # I can tell you what the part number and price would be.
Mike Anderson
Anderson Appliance Repair
(865)945-3808
Posted on Dec 02, 2008
  • 104 Answers
SOURCE: Our four year old frigidaire gallery series dryer stopped drying.
knackered
Posted on Feb 01, 2009
dragonsthatk
  • 547 Answers
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
Posted on Feb 18, 2009
SOURCE: Frigidaire Affinity Dryer (model LEQ7000ES0)
right now i took the whole bottom apart from the main brain and so far is working good is not turning off now it may work on your too
Posted on Jun 22, 2009
Cant open the front door seems like its locked
My frigidaire affinity dryer displays LOC - Fixya
www.fixya.com/support/t4561247-frigidaire_affinity_dryer_displays_loc
my frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please - Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer question. ... Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its ... Open Questions:.
Nov 23, 2015 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
How to replace the start button on a frigidaire affinity dryer aeq7000ego?
There will be screws along back at the top holding the top panel. Using the appropriate screw head screw driver you will have to get these screws out, lift the top panel slightly and push out towards the front. This should disengage the panel from the notch on the main body and come out. That will get you access to the console.
For an assembly view refer to parts manual you can download from this site
Frigidaire AEQ7000EG Parts Catalog
Aug 16, 2014 | Frigidaire AEQ7000EG Affinity Series...
How to unstuck a key on frigidaire affinity dryer
The front panel keys are floating, much like your TV remote, but always vertical; an easy target for grime and build-up. The best solution is to remove the top panel (screws are in the rear) then carefully remove the correct screws for the front panel. The control board can then be detached and you can sit at the table and clean thoroughly with a proper solvent. Reassemble and punch away.
Jul 11, 2014 | Frigidaire AEQ6000ES Electric Dryer
My Frigidaire Affinity dryer has and error message of E68 I have tried to reset and so far this hs helped what makes this happen and how do I stop it in the future? Thank you Sue Andrews
This is a fault code for a stuck key on the board. You may have to remove the control panel and check the keys. If this does not work you may have to replace the panel or control board.
Aug 01, 2011 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Model LEQ6000ES Affinity Frigidaire electric dyer purchased 5-29-06: tumbles but won't heat. Cleaned all air ducts and lint trap and still won't heat. Error codes not obvious. What else can we check?
you will need to check the main power and make sure there is 220 volts at the termianl block if that is goor then you will need to check the heating element an all thermal fuses.
remove the small panel in the back of the dryer so you can get the belt loose.
then remove the lid.Take out the four screws that hold the control panel in place.
then remove the screws that hold the front panel on and then remove the drum lift up on the back of the drum to get it loos e from the carrier bearing holder thenyou can get to the heating element and thermal fuse on the back wall of the dryer and the side wall of the heating element can.
Jan 08, 2011 | Frigidaire Electric Dryer
How to clean a affinity frigidaire front load washer drain pump filter?
remove the toe kick panel just below the front door and its located right below the drum
Oct 01, 2010 | Frigidaire Affinity ATF6000F Front Load...
Effinity front panel removal
remove top, remove control panel, then remove door boot, then remove front,
i normally tip machine back and access from bottom
Apr 18, 2010 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity Electric dryer E68 error. dries clothes fine, then error light comes on later- after dryer has been off. Will not start unless unplugged for period of time.
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Sep 15, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Access to burner on Frigidaire Affinity AGQ6000 series dryer
you do have to pull out the unit and use the rear access to unscrew those screws accessable from the inside.
Feb 18, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer Logo
109 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
