Question about Homedics Ss-5010 Soundspa Premier Am/Fm Clock Radio
External temperature sensor
Find repacement
1983 Delta 98. How do I clean a low coolant sender?
if it bad need to replace it cleaning it not going to work
Aug 28, 2015 | Oldsmobile Cars & Trucks
Why does my dashboard external temperature display not work, I have checked the bulb and changed for a new one, but the problem still persists?
external temperature display is this the external, ambient air temperature, option?
sure , bad sensor, bad wires or connection to it.
the FSM book covers these test. (buy one?)
Factory service manual.
sold at all Citroen dealers.
Jul 04, 2014 | 2007 Citroen Xsara Kombi
Acadia error external temperature
the FSM shows the tests.
they connect a scan tool and see if the sensor works.
id bet you can do that.?
so that leaves guessing, bad wire,/conn,or bad sensor.
Jun 08, 2014 | 2008 GMC Acadia
Citroen C8 2.0 HDI external temperature always wrong!
It\'s a small probe inside the passenger mirror. Look underneath for a little lump, looks like a water droplet. My C8 reads 58 degrees! Probably a similar fault. Removing the mirror is not bad, tilt to extreme to reveal metal spring clip inside. Putting back is a real pain.
Feb 09, 2013 | Cars & Trucks
Do you need to replace the thermostat housing if only the sensor is bad and telling the conputor to turn on the service engine light?
How do you know the sensor is bad? Have you checked the coolant temperature using an external temperature gauge?
Best bet is to replace both the thermostat/housing and the temperature sensor, they are not that expensive, and are located in the same area of the engine.
Aug 04, 2011 | 2003 Chevrolet TrailBlazer
I just replaced the bake element and now it is overheating and trips the internal settings and turns off (termostat?)
Yes , it sounds as if your temperature sensor is stuck as well, allowing the oven to overheat. Repacement is quite easy, the attaced link is useful. www.fixitnow.com/2003/03/appliance-tip-of-the-day-oven-temperature.htm
Jan 08, 2010 | Ovens
What is actual name of external temp sensor
it's called an "in-vehicle temperature sensor" it's located behind the center of the dash
Robert
Please take a moment to rate this solution... thanks
Apr 16, 2009 | 1997 Buick LeSabre
Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Homedics Ss-5010 Soundspa Premier Am/Fm Clock Radio Logo
32 people viewed this question
Top Homedics Audio Players & Recorders Experts
Gyula Lacz
ray gallant
Are you a Homedics Audio Player and Recorder Expert? Answer questions, earn points and help others
