Question about Kenmore Dishwashers
Kenmore dishwasher 665 lockout problem
Set the lock out button and it will not unlock. Did the instructions of holding the unlock and tried numerous times and won't unlock.
Get a 3 beep flash followed by 3 flashes then a slow constant flashing.
It seems to do this on and off but now it's stuck, help!!
  • 1 more comment
  • Irene Schlegel Sep 03, 2013
    Very helpful website for trouble shooting kenmore 665 lock out
    Bought this washer March, 2006, never had any problem luck for us till I notice few months ago that the smart wash light does not come on when pressing start, just goes into normal wash but continue washing OK. Then 2 days ago,
    Nothing happens, no light comes on, washer does not start. Check circuit breaker, OK, but switched it off any way and on again, but no go when pressing start button. So went out to purchase a new one. Determine to get it going as I was having family over for Labor Day, press all buttons at random, including the lock out/heat dry button and voila , was able to get machine going! Cancel my purchase of a Borsch, $708, free shipping and installation included. But after reading this lock out feature and possible problems that others had, am happy that I am able to use my washer, but for how much longer? Definitely will not replace control panel or board, just happy that it had behaved for more then 7 years!
    Prodigy:
    An expert who has answered 500 questions.
  • Kenmore Expert
  • 646 Answers
You may have a bad control console.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Posted on Mar 04, 2015
SOURCE: Kenmore Ultra Wash Dishwasher: Lock On Button Issue
Have to hold the Air Dry button down til your finger hurts. Release button and the light will go off. The "4 second press" in the manual is incorrect!
Posted on Jun 24, 2008
eagle338
  • 4889 Answers
SOURCE: kenmore dishwasher touchpads
Yes you can surely do it yourself..its just unplugging a few wires remove the old one and just install the new one..
I couldn't find the model number you have specified, but you can give these guys a call and specify ask for a new touchpad for kenmore 16372. They will ship it out for you.. I advise you call their toll free number that you can find on their site so that you can get it done real quick.. http://www.laundryparts.com/sunshop/index.php?action=category&id=bestsellers
Posted on Mar 14, 2008
SOURCE: Kenmore 665 Dishwasher Not Draining
After the first try of our dishwasher the water didn't completely drain. Ever since the same level of water hasn't drained from the dishwasher.
Posted on Jun 17, 2008
rylee_smith
  • 8619 Answers
SOURCE: kenmore 665 dishwasher will not drain
Hi
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Please do rate the solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Posted on Apr 08, 2009
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
How to off on kenmore 665 dishwasher mode or reset the panel
Check user manual or call manufacturer. The unit is not timing out.
Mar 08, 2015 | Kenmore Dishwashers
Kenmore ultra wash model 665 has lock on light. Does not respond to no heat dry four seconds.
Press and hold the heated dry button for 5 seconds and see if that will unlock the control panel. If not then try to flip the circuit breaker off for a minute and see if it resets. If nothing resets, then you just need to replace the control board because it's shorted.
Good luck.
Draven at www.ApplianceRepairLesson.com
Mar 04, 2011 | Kenmore Dishwashers
How can I get my lock on light off and turn my ultra dish washer on all buttons are disabled it is kenmore 665 15819
If the model number is correct, press and hold the "NO HEAT DRY" button for 4 seconds to lock or unlock the controls.
Aug 23, 2010 | Kenmore 15899 Built-in Dishwasher
My kenmore dishwasher 665-15817 has a blinking ''Lock On'' button
- To clear the flashing light you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Jun 06, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Dishwasher 665 15777990
It sounds like the child lock is on. Is the light on when the door is closed and nothing is pressed? If so hold the lock button until the light turns off. If you do not have a lock button, try the heated dry button or consult the manual to find out which button toggles the child lock.
Good luck.
Feb 21, 2009 | Kenmore Dishwashers
Lock on light flashing
I finally decided to calm down and use my head and managed to solve the problem. I read the instructions that are on the top of the dishwasher door. ( Smart move on my part HUH!) It said that when the door lock light is on everything is disabled. Hold the air/dry button down for 4 seconds and the lock light will go out. Guess what, IT WORKED. Here is what I learned from this. Always read all instructions. I spent $9.95 for an answer that was right in front of me. Humans can be so dumb I am!!!!
Jan 28, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Lock Light Blinking
silly question but did you try holding the control lock button(perhaps its the heated dry button) in for 3 secs???? sonds as if the CONTROL LOCK has benn activated( child lockout)
Jan 14, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore dishwasher lock light
you tried holding hte "control lock " buttonn for 3-5 secs and it still didnt unlock??? if thats the case your problably gonna need to replace te console/ touchpad
Nov 30, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
MAYTAG DISHWASHER STUCK WITH LIGHT BLINKING
Try holding down "Heated Dry" for about five seconds, until the light switches off. You should be good to go.
Oct 20, 2007 | Kenmore 15129 Built-in Dishwasher
Dishwashers Logo
156 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
