Brivis nc4 wall controller wont turn on
The wall controller starts then turns itself off. It now does not start at all. There are no messages or codes coming up when it was displaying.
2 Suggested Answers
SOURCE: Brivis Ducted Heating system. No display
I have an identical issue with my Brivis.
Did you get a solution?
Mine can be running, then goes blank and says searching. it will eventually come back.
Just wondering if you had to replace the 14100?
Cheers
James
Posted on Jun 01, 2010
Brivis me20e fan speed adjustable?
all u do is turn the wall controller to the off position. then press the clock button then hold buttons 2 and 4 down at the same time. let it load for 10 sec then turn the knob all the way untill it sais 1500 that is max fan speed then push the off on button to exit it. dont adjust any other values in here tho just the first one
Apr 20, 2014 | Heating & Cooling
Brivis evaporative working OK, used as fan only to bring cool air into house. Switched off and went to turn on again 2 weeks later, no response. Screen of controller blank, will not turn on? Where do I...
Hi, if the unit has a remote control,check the batteries and replace if required. Unplug unit from wall socket and check the filter in the unit where the cold air comes out, the cover lifts upwards. Clean filter by using a vacuum cleaner and reinsert. Plug and switch on power at source. Hope this helps.
Oct 20, 2013 | Heating & Cooling
Brivis wombat 2P 20
love to know how you went , i have a similar problem with the same unit.....
May 29, 2013 | Heating & Cooling
How to turn on the brivis buffalo 52
Refer the user manual given below to setup your Brivis Buffalo 52 and start operating it:
Brivis_Manual
May 28, 2012 | Heating & Cooling
Had a power outage a while ago for 24hrs, so I went around and turned everything off and once the power came back on I went and turn the heating back on at the mains switch. Now it is coming up with...
Pull the controller off the wall, press 3+5 buttons down, then replace on wall while still pushing buttons in.... a group of 5-6 bars will appear, then when it says type in address -turn dial to 1. this will re set it.
Dec 24, 2010 | Heating & Cooling
Brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
May 12, 2009 | Heating & Cooling
Honetweel heater control unit failing
you would have to study the wirring diagram etc but any gas heater control should work, you just have to know how to hook it up as the ignition etc is all incorporated in the control
May 03, 2009 | Honeywell Programmable Thermostat Heater
Brivis central heating problem code ''busy 40 H1
Hi, i recently had the same problem with mine and found that the inside adapter was unplugged. I plugged it back in and all is working find, so if anyone has the "Busy Hi 40" message on the control box the check the adapter :)
Apr 19, 2009 | Heating & Cooling
Brivis Heater help
These Brivis guys and girls are a rip-off. They are only out to take your money. Then can easily ask you to do just as mentioned above. And pronto all works in 3 minutes to be precise.
It is just the power supply reset required due to a fult being detected, either caused by a very low setting on the controller less than 16 degs. or a higher than 25 degs. setting causing overheating when the damper outlets are mostly closed.
So, put the power supply to heater off first, reset the heater panel, press the button again to shaow EMS on and then set the heater to the required temp. after turning on to the heating mode. That simple! That is if it is the error 71 HI.
Jun 01, 2008 | Heating & Cooling
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
