Question about Gateway GT5408 PC Desktop
Help with 3 beeps-fan running- cleaned memory - no boot
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Try cleaning and reaseating the CPU. Also try one memory stick at a time in each slot at a time and turn on the computer after each stick reinsertion. If you have another known good memory stick that you can try in there I would suggest that as well.
  • NinaE May 11, 2010
    What error messages when you boot ??
    What operating system (Windows XP, Vista)
    Problem Solver:
  • 18 Answers
3 beeps is a memory problem. That's the BIOS telling you something isn't right. The operating system doesn't matter, this is before the OS. Try like the last reply stated, insert 1 memory stick at a time, and boot the machine trying to eliminate the bad memory stick. It could be an insertion problem also, so re-seat the memory. This should do the trick.
Hope this helps!
Posted on Jun 20, 2009
Why do I get 3 short beeps followed by 3 short beeps
Likely the base memory is at fault, if you can't remove the memory and clean it with alcohol , re-seat and try again, then likely the motherboard is bad,
May 21, 2014 | Acer Aspire Computers & Internet
When i turned on switch dell vostro 230 it give no display and led colour is red
No Display, so does it seem like the computer booted up and is running except that the Display is black? Do you hear fans running, disk drive spinning, blinking lights or beeps?
I'm going to assume that in your case since you mentioned a red light that it is not booting up all the way. Therefore your problem is probably with the memory, the video card or some other motherboard issue.
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 19, 2012 | Computers & Internet
No my pc desnot boot no video but fans running no sounds not beeps
First remove the cover and remove all the power connectors from the smps the hold the 24 pin poerconector and short the green and black wire and see wether the smps fan is working if working remove the memory from the memory slot and clean the surface and insert it into socket and see wether the couputer boots
Sep 02, 2011 | Computers & Internet
GA-MA790GP-DS4H doesn't boot. It gives 14 short
Hello my friend,
There is no way to have 15 beeps error especially short ones so
First try to count the beeps and if are long or short
Jan 29, 2010 | Gigabyte Computers & Internet
My computer at start up beeps 3 times and won`t boot
Try booting up in safe mode. Press power on button and press F8 until you see a list appear. Go in under safe mode and see what the problem is....Hope this helps....
Nov 17, 2009 | Microsoft Windows XP Professional With...
There is no beep sound no display
Try to reseat or replug first your memory. Or clean its connecting terminal with a soft gel eraser, both side. But do this when unit is off and unplugged to wall socket.
Some motherboard do not send beep sound when memory is at fault, and also no monitor display. Usually no boot up. But CPU processor fan and hard disk LED is turn on or running.
If reseating and cleaning doesn't help try to swap another good memory card with same size for sure. Other than that suspect other component. Second in line is video problem and some other component.
Sep 25, 2009 | PC Chips Computers & Internet
Beep codes
1 Long Beep: Memory problem
Explanation: There is a failure of some sort related to the system memory.
Diagnosis: The first bank of memory probably has a failure of some sort; this is usually just a physical problem such as an incorrectly inserted module, but may also mean a bad memory chip in a module. It is possible that there is a failure related to the motherboard or a system device as well.
Phoenix BIOS ERROR BEEP CODES
Phoenix BIOS beep codes are a series of beeps separated by a pause, for example:
beep --- beep beep --- beep --- beep beep would be 1-2-1-2
  • 1-1-4-1 - Cache Error (level 2)
  • 1-2-2-3 - BIOS ROM Checksum
  • 1-3-1-1 - DRAM Refresh Test
  • 1-3-1-3 - Keyboard controller test
  • 1-3-4-1 - RAM Failure on address line xxxx (check memory)
  • 1-3-4-3 - RAM Failure on data bits xxxx of low byte of memory bus
  • 1-4-1-1 - RAM Failure on data bits xxxx of high byte of memory bus
  • 2-1-2-3 - ROM copyright notice
  • 2-2-3-1 - Test for unexpected interrupts
May 14, 2009 | AOpen AX34-U Motherboard
3 beeps and fan running at start up
The three beeps shows the Memory Module Test and that symbolise that the memory module is having a problem and to my knowledge when there is a problem with the memory then you have to open the casing and remove the memory module and clean the slot very well and if slot in back and the memory do the same change the to the second memory slot if it happens there again then you change the Memory module.
ok
rate this solution.
Oct 06, 2008 | Gateway GT5408 PC Desktop
No beeps on boot up with asrock mobo? help plz
While booting BOIS goes for POST check for detecting the all the hardware .
Disconnect all the connection to DVD, HDD, FDD from MOBO.
Rmove all RAM and start the ssytem from testing RAM Serviceability. If you listened a long intermittent beep place a single pices of RAM in MOBO ( repeat test with other RAM also).
Other wise your video card is unserviceable, if you have any addon plugins like NVIDA graphics card you can check
Jun 10, 2008 | Asrock K7S8X-R3 Motherboard
Not booting, i mean even getting past post.
how many beeps..3 long beeps means no memory signal, 3 short beeps and 1 long beep means some pci cards is damage or not working properly.
Oct 21, 2007 | Intel Motherboard
Gateway GT5408 PC Desktop Logo
125 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
