Question about Kitchen Ranges
Moffat fiesta stove where only the two back burners work, help
3 Suggested Answers
SOURCE: 1952 Moffat Bake Stove
I have a working 1952 moffat stove with warming oven if interested
Posted on Aug 28, 2010
SOURCE: I have a older model
I have a Moffat Westwood range and the oven doesn,t work. the fuses are good. Is this a problem with the timer settings?
Posted on Jul 18, 2011
Have a 1962 Moffat Fiesta and having a problem getting the burners back in after cleaning. Can you help?
Are we standing there by your shoulder . NO I guess not , sorry we do not do house calls
Jan 14, 2018 | Fiesta Grilling
How can I remove door?
Hi Tammy:
Many of the older stoves used a similar door hinge system.
When the door is fully opened it can be removed in the following way.
It's much easier with two people.
With one person on each side, lift near the hinge (closest to the stove) then pull away from the stove and at the same time, lift the handle end of the door.
There is a tab and a notch on the hinge arm that has to slide past the retainer.
To re-install, the hinge has to be set for the "door open position".
Slide the hinge arms into the slot so that the tab and slot engage in the correct positions.
Hope this helps.
Cheerfuls. .
Apr 02, 2016 | Moffat Ovens
Burner says hot.. wont go off, moffat stove
Hello;
My name is Peter. I am a retired field service appliance technician.
I assume you have an electric oven.
You have a defective individual burner control.
1.) Pull your oven out so you can get behind it.
2.) Unplug your oven.
3.) Remove the upper back metal cover.
4.) At the top in the center is your main oven control board. On the left are two burner controls and on the right are two burner controls.
5.) Inspect the burner controls for burn marks or melted wires.
6.) Finding the bad control unit, pull the control nob off the front.
7.) Unscrew the burner control in the front.
8.) Remove the connectors on the burner control.
9.) With the burner control in hand. re-attach the upper metal back panel on your stove.
10.) Pug in the stove and push back in place.
11.) On the burner control that you just removed note the part number. Search on the internet for best price.
12.) Continue to use your oven without the burner control.
13.) Install the new burner control when received. Remember to un-plug.
May 15, 2015 | Kitchen Ranges
Moffat Stove with a self-cleaning oven. I would like to know how to clean the oven using the "self cleaning" feature
hi there! I have a moffat stove and hopefully these instructions help you.
First clear out the racks in your oven. Take them out and remove any excess chunks at the bottom.
Then close your oven door and lock it by pulling the lock latch.
Now looking at your oven knobs [not your burner knobs] turn both of them so they are both on the arrow knob [your oven knobs should have small pictures on them and both should have arrows]
Now you need to set the time so in the middle of your oven their should be a timer and one start and stop timer on top of each other. Both timers go in increments of half an hour. So if you are starting your self cleaner at 3 move the dial to 3 or if you are starting at 3:30 move the dial to one tick after 3. Once you set your start timer, you need to set your stop timer.
Setting your stop timer, it is recommended to set it for 3-5 hours. I set mine for 4 hours. So then set stop timer to time you want the cleaning to be. If you set your start timer at 3:30 put your stop timer at 7:30.
The oven will start cleaning according to the time you set. The oven will get very hot. I recommend to not used the burners as the temperature goes to 500 degrees! You will smell an odor and that is your oven cleaning.... Hope this helps...
Sep 13, 2010 | Ovens
Oct 27, 2009 | Kitchen Ranges
Oven Door
I have spilt water inside the glass of my Fridgaire stove and wondering how to take the glass off the front so I can clean inside it.
Jun 02, 2008 | Ovens
Kitchen Ranges Logo
29 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
