Question about Toshiba Computers & Internet
Speccy reporting bad allocation (cpu ram and motherboard)
Satellite a210
4 Suggested Answers
  • 135 Answers
SOURCE: laptop freeze up and shutdown by itself, then can't boot up after
If it is still under warranty, you'd save yourself a lot of time and money if you just send it in for repair. If it isn't, the way to test if the RAM is bad is by trying to use the stick in another laptop or by trying to replace the RAM you currently have with RAM that you know is working (has worked on another computer). If the problem is with the motherboard or CPU, for most people it's better to just sell the laptop AS-IS with a good description on eBay and buy a new laptop.
Posted on Jan 05, 2008
ybchuan
  • 201 Answers
SOURCE: Computer Information
U may always refer to it motherboard to get to know the supported hardware that plug to it. Since u are mention about Intel 945G/GZ/P/PL family motherboard, each type of the motherboard (type G, GZ, P, PL) have their own specification, but the same thing is their are design to support Intel Core 2 Duo. Pentium D or Pentium 4 processor. And all can support DDR2 memory. Here you can refer to the manual of the motherboard for more details e.g. pg17 (availability 2009Nov16): http://www.intel.com/design/chipsets/datashts/307502.htm
YBC (/)
Posted on Nov 16, 2009
BearWeb
  • 357 Answers
SOURCE: ecs desknote a928, 2ghz cpu,
There could be multiple different reasons for this.
Possible Problems and Troubleshooting
1) The RAM (Random Access Memory) may have gone faulty.
2) The Motherboard may have been damaged.
3) The CPU is faulty
4) The Hard Disk is damaged - But then the laptop would still boot to the BIOS and tell you that no Hard Disk is detected so this is not your problem.
5) The ribbon cable from the Motherboard to the screen is damaged - But you said that an external screen doesn't work as well so this is not your problem.
This only leaves the RAM, CPU and Motherboard as possible problems.
Solution
You can buy a chip of RAM from a computer store and open the laptop and replace the RAM and test if it is working. This would be the cheapest way of finding out the problem. If it doesn't work, you will need to take your laptop to a specialist to get them to test if the problem is the CPU or the Motherboard, then you will just need to buy the part that needs to be replaced.
Thank you for using FixYa! Have a great day and please remember to rate this solution.
Best regards,
BearWeb
Posted on Aug 20, 2010
I have a toshiba A210-1AO with AMD Turion64. I turned it off normally and next day it wont start. The power led is on, it does the dvd startup check noise and then nothing. Blank screen. I tried the...
Age and dust accumulation. try blowing the case out or get a vacuum cleaner and clean out all the ports. If this doesn't work, you may have to take it to a computer repair shop to get it cleaned and serviced properly. The heat paste on the processor may have dried out and be causing an overheat.
Apr 12, 2013 | Toshiba Satellite Pro A210-EZ2202X...
Can i upgrade ram size 512MB to 1GB
Hello visit the mainboards homepage here:
http://www.mercury-pc.com/downloads.php
And type in the mainboard number, for downloading the manual.
I would say you can upgrade the ram, older mainboards supports up to 2 gb.
But it depends, how old it is.
Install this program to see what ram type, you have:
http://www.cpuid.com/softwares/cpu-z.html
Or this:
http://www.piriform.com/speccy/download
Good luck
Jul 24, 2012 | Mercury Computers & Internet
What kind of ram do i need
Yes, there is. You can find information about it here:
http://en.wikipedia.org/wiki/DDR_SDRAM
If you want real help, know your motherboard's brand & model so we could check what type of RAM it supports. If you can't find out, download and install speccy or aida64. It could give detailed report about the specs of your pc.
Hope this helps.
Jul 07, 2012 | ZT Group Cisnet PC Desktop
I want motherboard detector software
You can use this litle program to identify your mainboards number
and manufacture.Cpu and ram type.
Download from here: http://www.cpuid.com/softwares/cpu-z.html
And choose the english setup.
Hope this was helpfull.
Mar 14, 2011 | Computers & Internet
What kind of ram is there in the machine N3600
here download this.. it will give you a detailed overview of your pc.. including ram, motherboard, cpu , etc!
http://www.cpuid.com/downloads/cpu-z/1.56-setup-en.exe
akuma_ryu21
dont forget to rate
Jan 23, 2011 | Packard Bell iMedia 6826 (P481000502) PC...
Toshiba satellite a210 was on and working yesterday left it came back to it later it was off no power to it no battery no lights no nothing completely dead , power lead works but will not do a thing.
It could be one of the following:
1. Bad/damaged power jack.
2. Bad motherboard.
Visually inspect the power jack to make sure it is not broken or damaged.
Test voltage on the power jack to make sure it is not damaged.
Sep 26, 2010 | Toshiba Satellite Pro A210-EZ2202X...
RAM PROBLEM
Download CPU-Z then see what it displays as. Vista can show different to what you actually have because it allocates memory to things.
Aug 16, 2009 | Mercury P4VM800M7 Motherboard
My i865PEa-7IF Motherboard with 4gb ram kingstone ddr400, but bios reads 3.5gb. Bios is 103. CPU is P4 630.
It is possible that your system is using shared RAM i.e. some of the System RAM is allocated for Video Card. (ehteshamhusain@gmail.com)
Jul 19, 2009 | AOpen i865PEa-7IF Motherboard
Laptop freeze up and shutdown by itself, then can't boot up after
Jan 05, 2008 | Toshiba Satellite M45-S265 Notebook
Computers & Internet Logo
825 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
