Vulcan ducted heatingThe unit (Cx90) shutdown on summer period, and I just bought over and tried to ignite the pilot as instruction at the back of panel. The problem is, it fully control by wall control inside the house and no ignition button beside the pilot gas valve. Furthermore, I can find any pilot light that i can light up. It is new to me. Any idea to light it up? the fan is working fine when turn to cool. Turn to Heat, the fan stop.
  • 86 Answers
SOURCE: vulcan cx90 ducted heater
240 volt wiring required.
Posted on Mar 17, 2008
SOURCE: Vulcan CX Central ducted heating. RE:
The control panel gets its power from the central heating unit's power point. Try turning the power off outside at the powerpoint next to the ducted heating unit and try turning it on again after a few seconds, see if it resets
Posted on Jul 21, 2008
SOURCE: Stadt Ducted Heater ignition problems
Could be a number of things
Sounds like it the gas valve. If the gas Valve isn't opening or is burnt out then no gas will flow through it.
Also it the pilot is blocked then you wont get and gas coming through to light it up.
I am forever replacing gas valves on the buffalo series units and have found this to be quite a common problem on older units.
Posted on Aug 21, 2008
pierre1811
  • 144 Answers
SOURCE: Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Posted on Jan 29, 2009
heatman101
  • 43501 Answers
SOURCE: I have a Vermont Castings
From what you are showing and saying I would say that you have a bad gas valve... Your test B is the most telling in that it pulls the MV's down when you close the wall switch, but the gas valve does not open...this tells me that it is trying but the valve is not opening...
Now... the next problem will be to find that valve... from doing a very quick search, I believe that it is an OEM valve and probably will only be available from the manufacturer or a dealer...
So I would contact your dealer or Vermont castings and try to secure a new gas valve.
If it were a thermocouple problem the pilot would not stay lit...
One other test would be to bypass the wall switch and jumper the gas valve directly to make sure the wall switch is not the problem...
heatman101
Posted on Nov 07, 2010
Vulcan express gas continuous flow/model # 230010N0/serial # 66669/ Date 19-08-98. I can hear and smell gas when trying to ignite the pilot light and the igniter spark, "sparks", but pilot light...
VULCAN water heater continnous model number 23001ono. im looking for a brass nut that sits on with a very small hole, with a number on it (25)
Mar 10, 2011 | Heating & Cooling
Pilot lights but won't stay on in my older style vulcan space heater. thermo couple was replaced last year.any ideas that i could try thanks
Most common cause of pilot light problems is air movement. If your space heater exhausts gas through the roof, ensure the cap is on and level. If not, outside air movement will blow out the pilot. If you do not have an exhaust gas duct, check that the unit is positioned so that it does not blow air back onto itself from walls, furniture, etc, and ensure no other devices that move air are aimed towards the unit. The unit also needs to be placed away from central ducting, including return vents.
Hope this helps!
Aug 09, 2010 | Vulcan AUW230A Heater
My Vulcan CX90 ducted heater works fine other than the base of the ducted heating unit is coroded and needs replacing. This the part that the unit sits on which connects to the return air and outlet pipe....
80 Series Burner Base. PART 1318011
Here is the complete listing
www.reece.com.au/new/pdf/products/Reece_Gas_Reference.pdf
The problem is that this part number is not available on net for sale.
May 23, 2010 | Heating & Cooling
We have a Vulcan Ultra high efficiency gas ducted heating
Gas ducted central heater won't switch on all of a sudden
Nov 04, 2009 | Vulcan AUW230A Heater
Wiring diagram required
Just wondering if you h
Apr 19, 2009 | Washing Machines
Vulcan CX Central ducted heating. RE: Following a power outage the control panel does not respond, I have checked the pilot light and it is still on. I need to know how to reset the time and get it to...
Jul 06, 2008 | Heating & Cooling
Vulcan space heater lighting instructions
turn the round knob to left "the ignitation" spot, then push down the button to light the pilot.
May 07, 2008 | Ovens
Vulcan cx90 ducted heater
Mar 06, 2008 | Heating & Cooling
Vulcan CX ducted heating
sounds like the thermocouple (that sensors the heat) may be faulty.
you will need a licensed gas fitter for repairs
Feb 19, 2008 | Heating & Cooling
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
