Question about Coast Px25 Led Flashlight 19270 Power Chip Ll7736
My coast px25 wont turn off - Coast Px25 Led Flashlight 19270 Power Chip Ll7736
How to check the fuses on 1997 zx6r
check fuel, check kick stand lean angle switch any CEL. CHECK ENGINE LIGHTS.
Jun 06, 2013 | Motorcycles
Pinging sound only when acclerating. Doesn't do it when at idle or coasting.
if you have the recommended octane fuel in the vehicle the normal reason for pinging ls the timing is advanced too much.mark the distributor to housing position{so you can return it to how it was if the experiment doesnt solve it}then loosen the distributor retaining bolt and turn the dizzy about 4mm clockwise or anti clock{depends on model}lightly tighten bolt and road test.if pinging is worse turn the dizzy the other way.if pinging decreases just keep adjusting till it just dissappears.hope this helps.if it doesnt return the dizzy to original position and look for another problem.you wont hurt anything trying.
Jan 26, 2012 | Cars & Trucks
Light is burned out and turntable wont turn with glass on...should i replace it or should i get it fixed...built in unit above jennaire wall oven
open the bottom you can see the motor and with volt meter check if it get power , if it does get power but wont turn its the motor and it coast 30-60$, it might be the plug that got disconect.
but if you dont get power to the motor wile runing the unit then the problem is the main board and it is not worth to fix it coast more then 1/2 of your unit.
Jan 19, 2011 | Jenn-Air JMC7000 Microwave Oven
I have a led lenser V2 and the end cap switch will no longer turn the light off. Thanks for your help. Sincerely, Bob Mitchell
Bob,
Please contact Coast Products warranty department at 800.426.5858. This light has a lifetime guarantee, and we will take care of the light for you.
Regards,
Rob - Coast Products
Dec 16, 2010 | Led Lenser/Coast/Zweibruder Camping,...
My car wont stay running when Im not on the accelartor when I get to low rpms it just cust off even if coasting to a stop at a light or turning a corner PLEASE HELP!!
SOUND LIKE FAULTY IDLE AIR CONTROL VALVE.VECHICLE IDLING TOO LOW WHICH WILL CAUSE STALL OUT AT STOP LIGHTS AND STOP SIGNS TURNING CORNERS.HAVE VECHICLE CODE SCANNED FOR FAULTY IDLE AIR CONTROL VALVE.
Dec 04, 2010 | 2001 Lincoln Continental
Bike wont kick start or idle , it will coast
first drain the carby, then set your air mixture screw 2 turns out, from the fully turned in position. The starting proceedure is as follows, when the engine is COLD, turn on fuel, pull on the choke fully, and kick the engine over. DO NOT use any throttle, when the engine is cold, and the choke is on. Remember Choke on, NO throttle.
When warm, no choke, and a little throttle when kicking.
May 12, 2010 | 2003 kawasaki KX 125
Why wont my amp turn off
when it was installed they put it on a constant hot you either need to find a ignition hot or install a switch in to the remote wire
Feb 13, 2010 | SNK West Coast Customs WCC-6004 Car Amp
How can i Get the amp fixed and how much would it coast?
vrambo215: fixya has another area which can help you with your amp. if you go back to the home page of fixya you can find specialists in automotive stereo systems and more.
Good Luck.
Feb 09, 2009 | 1990 Lincoln Town Car
Coast Px25 Led Flashlight 19270 Power Chip Ll7736 Logo
71 people viewed this question
Top Coast Camping, Backpacking & Hiking Experts
Andrew Taylor
Andrew Taylor
richie46
ray gallant
Are you a Coast Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
