Question about HP Media Center M380N PC Desktop
Power suppy PC will not power up. Will not come on. Is there a circuit breaker?
    Problem Solver:
  • 11 Answers
There is sometimes a switch on the back of the power supply. It will be an on/off rocker.
power suppy - 24208592-utljffv4r5pvxchgj5g4ja45-5-0.jpg If turning this switch does not solve the problem, you may need a new power supply.
Posted on Oct 28, 2015
Where is the circuit breaker on a e-machine T5048? The computer will not turn on (no power) I have replaced the power supply and same problem. I am wondering if it is a circuit breaker on the computer of...
There is no circuit breaker.
If you've already replaced the power supply, I'd say the problem lies with the motherboard. It's possible that the power switch is bad, but it's most likely the motherboard.
Feb 07, 2011 | E-Machines T5022 (RBT5022) PC Desktop
I have an eMachines T2200 The power supply started making noise and I shut the system off. The next time I tried to boot up nothing happens. I replaced the power suppy and when I turn it on the cd and dvd...
I would check to see if power is getting to your hard drive, Make sure the white molex's are plugged in.
E-Machines are, unfortunately the worst machines out there. They're up there with Compaq.
You're not going to like what I say but I'd urge you to buy a new one. Chances are it will take an arm and a
leg to fix what your using and for a little bit more money you can have a really nice one for 500 dollars
or less.
Dec 31, 2010 | E-Machines eMachines Desktop PC
Need to reset circuit breaker
  • 1 Turn off the light switches and unplug appliances in the room that has lost power.
  • 2 Find your circuit breaker box and open the cover.
  • 3 Locate the tripped breaker. Circuit breakers are small, usually horizontal switches labeled by the areas of the house they serve (for example, "kitchen," "bathroom" and so on). The tripped circuit breaker will be in the "off" position or in a middle position between "on" and "off."
  • 4 Reset the breaker by moving it to the full "off" position and then back to "on." That may clear an overload and return power to the room. If the breaker re-trips, you may have too many lamps and appliances plugged into the circuit; a damaged cord or plug; a short circuit in a receptacle, switch or fixture; or faulty wiring.
  • 5 Identify and correct the malfunction before resetting the breaker.
  • Please post your feedback and Vote if the problem resolved as per your satisfaction.
    Sep 25, 2010 | Computers & Internet
    Sunroof will not work
    Power is supplied to the Power windows and sunroof through the power window circuit breaker. That circuit breaker is supplied power through the RAP (retained accessory power) Relay, the RAP relay also supplies power to the radio. The RAP relay is also fuse protected by the RAP fuse in the under hood fuse block. The RAP relay is energized by the BCM body control module.
    The RAP relay is responsible for the radio and windows working after the igntion is turned off.
    The first place to check would be the RAP fuse in the under hood fuse block and then the RAP relay in the Body fuse block.
    A list of the BODY relay block located on the left side of the dash to the right of the interior fuse block is below:
    (1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay(1) Park Lamp Relay
    (7) Door Lock Relay
    (1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay (1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay
    Jul 10, 2010 | 2000 Chevrolet Blazer
    Tv will not start after power surge
    Voltage checking and caps inspection will be the first thing to do.
    If you can post the pictures, that will help a lot. Look at the inverter board to see if you are getting 12~18vdc feeding it, also look for caps with leaking/bulging top.
    See some pictures here:
    http://s807.photobucket.com/home/budm/allalbums
    http://en.wikipedia.org/wiki/Capacitor_plague
    Jun 28, 2010 | Sharp LC-19SB14U 19 in. LCD TV
    No power to unit
    power pcb may be prob or main pcb check the suppy inside the machine
    Jun 06, 2010 | Samsung WF448AA Washer
    Computer/Motherboard Issues
    buy a circuit protector for just ur computer and call a electrition
    May 12, 2010 | Gateway 507GR PC Desktop
    No power, just a small clicking sound?
    hi,
    we have a lot of problems with samsung tv's. if you can i would take it back and get another brand. if not do not remove that back it would void your warranty.
    if you take it in for repair it will take about two weeks to fix.
    the only really thing you can try is to unplug it for 5 mins and then plug it back in. this might reset the tv... but do not bet on it.
    good luck :)
    let me know if you need more info?
    Fame !
    Jul 04, 2009 | Samsung SlimFit TX-S3082WH 30" TV
    GT5014 won't boot
    Generally this means there is a problem with the power suppy as it is not giving a correct voltage to the motherboard to start the computer. check your fans on the power supply, make sure they start when you try to start the computer . A power suppy may be purchased and installed fairly easy. and you should spend no more than 50 dollars on the parts.
    Mar 05, 2009 | Gateway GT5014 PC Desktop
    My Computer starts then turns off...
    hi buddy!
    be sure that the power suppy can can handle all the components thier plug. and check the power button if there is no short circuit ok. also try the other power suppy if you encounter the same problem just reply i am willing to help you ok.
    PS:
    pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
    Jun 23, 2008 | Antec TruePower 550 (true550) 550-Watt...
    HP Media Center M380N  PC Desktop Logo
    44 people viewed this question
    Top HP Computers & Internet Experts
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
