Question about Lands Phones
Phone handset ge 2-9220 - Lands Phones
I love my GE Model 28111 Series DECT 6.0 Cordless Handset Speakerphone System. However, I goofed the other day and accidentally left it outside and then it poured. Needless to say, it is totally shot. ...
Your GE phone doesn't have an accessory handset. Unfortunately you cannot replace it with just one handset. If the phone is within warranty, kindly return it to the manufacturer and have it replaced.
Sep 04, 2011 | GE 28111 Cordless Phone
GE handset 28101 will not sync with base-GE 28129
Unplug power cord from the base for ten or fifteen minutes, this is the only user level operation that you can do to try fixing the problem.
If after resetting the base still do not find the handset, then either the base or the handset is faulty.
If the base works fine with a different handset, then it is the handset.
Sep 14, 2008 | Lands Phones
I need a new handset for ge phone model 29451. I don't need the base. Any place I can source this?
The place I normally go to for GE parts says the handset (part number 62A27436) is no longer available. You can try the GE Phones website. Or you can try calling them at 800-448-0329 to see if they can suggest a handset from another model that may work.
Jan 26, 2011 | GE 2945 Phone (29451)
I have a GE cord and cordless speaker model: 26955-GE 900mhz phone which i have had for eight year and I would like to add another cordless phone which GE phone is compatible to what I'm currently using....
If you mean you'd like to add another handset to the base unit on this phone, I'm afraid you can't. This isn't a multi-handset phone and isn't expandable. If you want the kind of system that has the main base unit and several separate handsets, you'll have to start fresh with a new system. They aren't expensive.
Mar 09, 2010 | GEH5450 Cordless Phone
Need a manual for a GE DECT 6.0 3 handset phone system
this should be what you've been looking for
http://www.home-electronics.net/ge/pc/IB/28112EE3_IB.pdf
If it's not the right model here are the other manuals
http://www.home-electronics.net/ge/pc/user-manuals.asp
You will find your model number on the bottom of the Base or Handset Charge Cradle of your phone
Aug 21, 2009 | GE Lands Phones
GE 21028 2.4GHz cordless--restore original handset number?
Do a factory reset on both handsets and on the base.
Jan 13, 2018 | GE Lands Phones
GE 2.4 GHz cordless telephone problem
Hi there, maybe I can help;
Is the phone base plugged into an switched outlet and is the switch off?
Let me know if I helped
Jan 06, 2009 | GE 21008GE2 Dual-Handset Cordless...
Phone charging indicator light
register phone instuction
May 22, 2007 | GE 25861GE3 Phone
Ge cordless model 27831 issues
you have to place the handset 2 in on the main base by 'round 20 seconds so it will be registered by the system
Apr 28, 2007 | GE 27831GE2 Phone
Lands Phones Logo
16 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
