Question about Mitsubishi WS-55809 55" Rear Projection Television
Flashing green light after power failure
Lost power and my TV. Mitsubishi Medallion HDTV , have tried reset button, have unplugged. Can't figure out how to fix the fault, anyone got an idea.
  • 668 Answers
Sounds like the DM is causing the problem.
They used two styles of DM's. A older one that is aprox 7yrs old that they do not support any more. If it is a younger one, it has 4 capasitors
in it that need to be replaced. They changed the value of them to prevent them from failing again. I believe they are 16V 1500uf.
Hope this helps,
Skyassoc
Posted on Jun 20, 2009
Hdtv flashing green light for timer tv wont turn on
If the TV is a few years old the flashing green light means the bulb need to be replaced. That's why the TV will not show a picture. Check your owners manual on how to replace.
Mar 20, 2013 | Mitsubishi LT55164 Unisen Medallion 55...
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi TV won't turn on green light flashing
Bad capacitor syndrome. Search 'bad caps' and model and you will find on goog.
Apr 17, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi TV green flashing timer light after power outage.
You will need to cahnge the capacitors on the DM board, very common problem. The V21 V19 DM repair kit at the following link contains the replacement capacitors and detailed instructions. Its listed under the repair kits catagory at the following link.
http://servicemanuals.vstore.ca/
Aug 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My tv won't turn on, the timer keeps flashing
http://www.jyerdon.com/tv/
If it`s a 65513 mitsu, this will fix the flashing green light, most of the time, e-mail me with any questions, good luck
buranc@bellsouth.net
Dec 28, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Light flashing and tv won't turn on
Hi there, I have a Mitsubishi HDTV 1080 and when I tried to turn it on the tv this morning it wouldn't turn on and the power light is flashing green. I pushed in the reset button but it just keeps flashing and still won't turn on.
Oct 05, 2008 | Mitsubishi WS-55513 55" Rear Projection...
I have 65" medallion HDTV and it will not turn on. It has a green flashing light, and I have tried to reset it several times.
Hold the power button down for 10 seconds ans release it; should turn on; also verify the voltage setting for your country....
Sep 23, 2008 | Mitsubishi Televison & Video
Mitsubishi 1080 HD Medallion
If the LED doesnt light. Check the fuses. the fuse many be blown. Unplug the set before you check the fuse.
Jun 14, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
173 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
