Question about Janome Sewing Machines
Mb4 has error message carriage will move them makes grinding sound
My xl400 singer embroidery carriage has stopped working. Will not move at all when machine is turned on. Also keep getting msg error about hoop size but no hoop attached.
The switch for "sew" or "embroidery" must first be in the "embroidery" position.
Make sure the connections are very firmly pushed in.
If it still isn't functional it may require some small motors to be replaced. The motors are what makes the hoop move.
Sep 28, 2016 | Singer Futura Xl-400 All-In-One Sewing And...
The carriage on my empisal knitmaster 360 won't run smoothly. Can you help please
sound like it has a timing fault the are like a car engine and have to be set like one to run perfect better to have it checked out just in case or it might make thing a lot more costly
Jan 22, 2015 | Sewing Machines
My janome mb4 won'tt open designs I send from my computer. I have had machine for a year and never had this problem
Make sure you r sending design in correct format from memory mb4 reads only .jef format
Jan 20, 2015 | Janome Sewing Machines
Janome mb4 embroidery machine-when carriage resets it goes all the way to the right
It sounds like your x-axis sensor is either broken or malfunctioning. When the machine initializes, this sensor tells the machine when it has reached the furthest point in it's range of motion. If it is not working properly, the carriage will extend past it's normal range, and stop when it physically cannot move any further. After a specified amount of time the x-axis motor shuts off, and an error message will appear. For a certain diagnosis and repair, it would be best to take your machine in to a Janome dealer.
Mar 15, 2014 | Janome MB4 Four Needle Embroidery Machine
Janometroubleshooting
checks that the strip wire and strip wire sensor, this worked well.
(the strip threads is the small spring by which you spend the thread to thread)
Jan 04, 2014 | Janome MB4 Four Needle Embroidery Machine
Embroidery machine is making grinding noise and carriage doesn't move. Then, screen says malfuntion, turn machine off.
Just because the hoop holder has been moved during transportation. Shut down the machine, manually bring hoop holder in central position in both X and Y, it will restart.
Apr 20, 2012 | Brother PE770 Computerized Sewing Machine
Futura ce-200 "parked" in wrong position.
I think you might have damaged the embroidary arm.
Contact these people for some advice.
Gezina sewing machine
(012) 335 0636
Feb 27, 2009 | Singer CE-200 Quantum Futura Computerized...
Error 1 message will not leave
Hi - first, check your manual to see if the error is described somewhere. Follow the instructions. If the manual tells you to take the machine in for repair, try a couple things first.
Often when your needle starts to shudder, the thread is caught on something somewhere along the sewing path. Turn off your machine, change your needle, take all of the thread out of the machine and rethread it. Then remove your bobbin to make sure that there is nothing stuck in the bobbin case, or in the area where you insert your bobbin into the machine. Look around the sewing area to see if something looks out of place.
After you insert a new needle and rethreaded your machine, and before you turn the machine back one, try using the wheel to make a few stitches manually. Watch your sewing thread to make sure it is feeding evenly. If the needle does not move up and down correctly, or if you hear a grinding or bumping sound, you probably need to take the machine to be repaired. Otherwise, turn your machine back on. If the error message is gone, try sewing slowly for several inches - if all seems well, increase the speed a little at a time. If anything seems off to you while you sew - stop sewing immediately and look very carefully to see if you can find a problem.
Dec 20, 2008 | Kenmore 19365 Computerized Sewing Machine
Stepping motor error on embroidery machine
Hi again and welcome back to FixYa.
It is nice of you to remember. To your concern, possibilities are:
  • if the grinding noise is coming from the bobbin case area, then pls ensure that nothing is stuck/caught there, it would only take a small foreign object to trigger the problem; or
  • verify that the embroidery carriage in its parked/original position;
  • there would be a sensor/switch that tells the computer that the embroidery carriage is back. Pls check that if the carriage is back and see if you can check the sensor/switch;
  • worst case scenario is that the controller's circuit board is faulty. In some case, it could just be the wires or connection leading to the controller board.
Good luck and Thank you for using FixYa again. Happy Holidays.
Dec 07, 2008 | Sewing Machines
Janome mb4
Loud chirping noises indicate a need for lubrication or something is rubbing against your carriage.
sewman7
May 18, 2008 | Sewing Machines
Sewing Machines Logo
41 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
