Braemar heater reset
Reset -02 code
5 Suggested Answers
SOURCE: braemar spectrolink comfort controller keeps on
sim lock
Posted on Apr 09, 2010
Look for the error code on the right hand side of the display above the zone section and below the actual temp displayed.... refer to:
http://www.braemar.com.au/PDFDocuments/Section8_ServiceTroubleshoot.pdf
Posted on Jul 22, 2010
SOURCE: HOW TO RESET SECURITY CODE
Hi
I need to reset my security code.
IMEI:352705047621980
Posted on Jan 20, 2011
Terry Corrow
  • 10875 Answers
SOURCE: Whats is error code 02 on braemar spectrolink?
Owner Manuals
Posted on Jul 25, 2015
Braemar manual
trying turning power off at wall switch
Apr 21, 2014 | Heating & Cooling
MY BRAEMAR th5X23E showing reset -05 heater is not working at all
Go to the outside unit and open the door that covers the electrical connections. There will be a reset button on one of the temp switches that needs to be pushed. Now you have to see why it needs a reset.
Mar 21, 2014 | Heating & Cooling
Braemar spectrolink reset error 05
I had the fault code 05 (spectrolink controller) recently on a Braemer TG420 ducted heater. The heater would start and cut out on high temp as the room fan was not starting. I checked under the house and found the cable fitted to the return air thermistor had been chewed. I repaired the section of cabling and restarted the unit and it worked fine. Fault Code 05 is to do with the Thermistor in the return air duct.
Mar 27, 2012 | Heating & Cooling
Braemar spectrolink comfort controller keeps on asking to be reset works ok for a while then goes to reset
Jul 21, 2010 | Honeywell Programmable Thermostat Heater
Cannot reset remote for braemar Ecostar Ducted heatin. Need to reset time and day. Would like to reset programmes also however when i hit the set button as per instructions in little book provided the...
The Braemar heater I have is wired directly to the control unit. The only way to reset the time is to turn of the heater for 5 minutes - the remote display should clear, and turn it back on (takes a minute for remote to come back on) the time will be flashing - use the Up and Down arrows to set the time, and SET button to set the day of week.
Jul 18, 2010 | Heating & Cooling
Might Max 210,000 Mile check engine light is on. Code says 42 (fuel pump) No problems with truck starting or running. Reset with switch and reset by disconnecting neg Batt. Light comes back on.
Not sure what year you have but if its newer than a 96 then the code is for an 02 sensor. Bank1 sensor 3
It will be the sensor after the catalytic converter. It needs to be replaced. The code is a heater code and always it points to a bad 02 sensor.
Jan 04, 2010 | Mitsubishi Mighty Max Cars & Trucks
Panasonic copier DP8530 has a E4-02 code.
hi i am working on panasonic copiers.E4-02 this code shows there is some problem in fuser unit
1.pull out side fuser unit from copier
2.check it is movig easily
3.check all gears
4.check thermostate and thermistor
5.bearings and seals
6.for to reset heater codes press function, orginal size,3.F1 will display press 9 ,06(ram initialize) sub code 04 start .fuser code will bi reset.
was it helpful .not forget to rate me .MIAN AKHLAQ
May 08, 2009 | Panasonic DP-8035 Grayscale Copier
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
