Question about Maxtra Trimmer 30cc 2-stroke Gas Pole Saw Chainsaws Chain Saw/Pruner
Need Parts I need to purchase the plastic cover over the chain guard and some rubber boots for the gas tank for my Maxtra pole chainsaw. Do you know of any vendors?
How to replace gas vent on huaqvarna 51 chainsaw
Disassembly
The fuel tank vent is located on the right side of the fuel
tank next to the right rear rubber element. With the fuel
tank empty and the fuel hose disconnected at the
carburetor, remove the two rear rubber elements. Separate the rear of the crankcase and the fuel tank enough to expose the fuel tank vent. Working through the fuel filler opening, grasp the fuel tank vent tube with a pair of needle nose pliers. Push the vent out the other side.
For access to the right side rubber elements, first remove the chain brake cover, bar, chain, chain catcher and cover plate.
For access to the left side rubber elements, remove the starter housing.
Assembly
Install the fuel tank vent using a drift the same diameter
as the vent tube. The remainder of assembly is the
reverse of disassembly.
Nov 07, 2014 | Garden
Maxtra chainsaw parts
We added an O-ring to the gas cap, used a Goof-Off cap to replace the bar oil cap, added a flat-washer to hold the plastic saw cover. Since the pole joints slip out of place, he used very short self-tapping screws (made for steel studs) to fasten more permanently. He started the holes with the screws, but then backed them out and shortened them by grinding off 3 threads. Then he tightened them.
Mainly, we just found the problem that solves the start / fuel issues many have had on the Maxtra Pole Saw!!!!!!!! My husband noticed the carburetor seemed giggly. He had removed the air cover and been starting it by pouring a little mixed fuel directly into it, It would run a little bit, then die. I watched the fuel line, and even after pumping it up, it would get air bubbles in the line while it ran, and then drain completely. The fuel line is really short so we both thought it just might not be far enough into the fuel -- but that was not it. He saw the two nuts inside the breather and decided to remove those and the carburetor. A little tricky if you have NO mechanical skill at all, but really pretty easy, take photos if you need to remember how it goes. He found that the manifold piece behind that had 2 bolts holding it and they were VERY loose. This created a horrible air gap. He gently tightened those bolts with a hex bit keeping in mind he did not want to strip them. (Now we wish we had used Lock-Tite). We put it back together, pumped the primer AND IT STARTED ON THE FIRST PULL!!!! First pull, ran continuously, and even idled!!!! We are going to replace the fuel line with a little longer tube tomorrow. This baby will hum now!
Apr 22, 2014 | Maxtra Trimmer 30cc 2-stroke Gas Pole Saw...
Parts
this pole breaks because the gear inside is made of puter and when it gets warm enough it melts or breaks the teeth the only solution is to take it out and find some place that makes them to replace it
Maxtra long pole hedge trimmer has bolt with stripped thread.
same thing happened to me, I had to make another one there made of some kind of puter
Apr 07, 2014 | Maxtra Trimmer 30cc 2-stroke Gas Pole Saw...
My Maxtra 30cc pole pruner starts ok and runs fine for about 5 mins. The revs then begin to race and the engine cuts out
I have seen this issue before, having trouble remembering the fix though. Is there any more info you can give me about the problem?
Apr 14, 2013 | Maxtra Trimmer 30cc 2-stroke Gas Pole Saw...
I have a Jonsered 20"chainsaw.CS2165
The hand guard is secured on the left side with the top l/h starter cover screw part no. 503203419, the right side is held to the brake actuating arm with a 4mm screw part no. 503202512.
Let me know if you need other parts.
Jun 05, 2011 | Garden
Poulin pro chain will not get gas to engine all parts are clean and it has gas
Possible plastic hose running from fuel tank to primer or from fuel tank to carb is broken or cracked. Remove cover to access the carb and inspect hoses for cracks or being broken. Also inside fuel tank the hoses can break off and not be notice from the outside. The hoses can be replaced but not easily. Small engine parts store should have fuel hose.
Nov 26, 2010 | Poulan Pro Chain Saw 46cc 20"
Need locking latch for Remington Electric Chain saw
You've got the one version of the Remington Pole Chain saws that doesn't have a separate parts breakdown online.
However, here's a owners manual for your pole saw and a parts breakdown that can be used for most replacement parts, as the RPS-96 is a similar version of your model.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/RPS96/RPS96_OM.pdf
http://shoppingcart.msservicecompany.com/msservice_net/product_files/RPS96/RPS96_BD.pdf
You might want to contact the factory to verify that the parts are the right ones before ordering them by calling 1-866-672-6040
Hope you find this very helpful and best regards!
Aug 07, 2009 | Garden
Maxtra Trimmer 30cc 2-stroke Gas Pole Saw Chainsaws Chain Saw/Pruner Logo
20 people viewed this question
Top Maxtra Garden Experts
Dennis Key
Dennis Key
john h
Are you a Maxtra Garden Expert? Answer questions, earn points and help others
