Question about ASUS VivoTab RT
Touchscreen problem Touchscreen does not allow other screens to be engaged. A gray cicle shimmers and shakes up and down, left to right, and prevents access to other screens.
How to delete post from Facebook
There should be a little arrow pointing down in the top right corner of the post. Click it and it will give the option to delete the post.
Dec 04, 2015 | Apple iPad Air 9.7" 16 GB Wi-Fi Space Gray...
How do I setup mail on on my iPad running IOS 7?
Click the seTTINGS app,
in the left margin, go to mail, contacts, calendar...
click ADD account.
Then fill in dialog boxes
Sep 04, 2014 | Apple iPad mini with Retina display 7.9"...
Why is my kurio touchscreen not working?
If there is no power button or it does not work pull the battery and wait a minute before you put it back in.
Jul 23, 2014 | Techno Source Kurio Kids Tablet With...
My screen suddenly out of nowhere polarized and changed colors... seems to be functioning otherwise...
It sounds like their is moisture or clamyness inside the tablet. Let it lay in the sun bit with the screen downwards. See if it solves the problem.
Apr 01, 2014 | Samsung Metallic Gray Galaxy Note 10.1in...
Low volume, seems volume button is wired backwards. push on the left side and volume raises
My Android (not an Iolo) has both a touchscreen volume control--as well as a pair of physical volume control sliders--the latter on the right outside edge. I put the tab into a temp car mount: The resulting friction slid the volume down to nil--the the physical sliders, contacting the mount, proved the culprit (despite the touchscreen volume control setting). I proved puzzled at first, cursing the tab.
Mar 17, 2014 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
My Samsung galaxy s3 charging port is broken, my screen is also cracked. Will i have to get my screen fixed in order to get my charging port fixed?
No, charging port can be repaired without having the screen replaced, you might want to consider this though, since they are already in there fixing the power connector they might as well fix the screen and save you the disassembley charge next time. Up to you though
Mar 17, 2014 | Samsung Metallic Gray Galaxy Note 10.1in...
Toughbook cf 19
get sound back on mac air
Aug 25, 2013 | Tablets & eReaders
Problem with the touch screen an stylus
Press the Up + Down buttons at the same time. This will turn off the "Digitizer" function on the tablet and allow the user to use their finger, the stylus, or blunt end of a pen.
Aug 21, 2008 | Itronix Duo-Touch Tablet PC
ASUS VivoTab RT Logo
23 people viewed this question
Top ASUS Tablets & eReaders Experts
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
