Question about Barbeques Galore Bar-B-Chef Deluxe S/S 31 on Cart -175677 Grill
Need handle brackets for Bar B chef 31 - Barbeques Galore Bar-B-Chef Deluxe S/S 31 on Cart -175677 Grill
2 Suggested Answers
gcken
  • 140 Answers
SOURCE: i need a handle for
E-mail BB galore that the only way you can get parts for there grills
Posted on Aug 09, 2010
Looking for a side box handle , and replacement grates for the bar b chef smoker.
You can buy parts & accessories directly from BBQ's Galore. Just go to their website's home page http://www.bbqgalore.com/ and click on parts and accessories.
Feb 14, 2011 | Barbeques Galore Bar-B-Chef Charcoal...
Magic chef self ignitor top,, how do u get the oven to work.. is it self ignite too. i turn on oven ger a glow in the oven,, dont know the model ,,older stove. good shape. bought house with gas stove...
If the glow bar is glowing and the oven doesn't come on in about 30 - 45 seconds.... it probably is the glow bar that needs to be replaced. BUT it could be the oven valve. Usually it is the glow bar.
The glow bar is wired in series with the oven valve and even if it is glowing it may not be sending the correct voltage through to the oven valve. To change the glowbar... unplug the appliance, unscrew 2 screws holding the metal bracket to the burner and remove the ignitor. You can cut the 2 white wires going to the ignitor and use ceramic wire nuts with the new ignitor.
Tom
Aug 10, 2010 | Magic Chef 31000 Gas Kitchen Range
I need a handle for the smoker door on a bar-b-chef 263350
Aug 09, 2010 | Barbeques Galore Bar-B-Chef Charcoal...
2004 silverado rear brake torque specification, had to replace rotor, need specs for both the set that attaches caliper bracket to knuckle and calipers to bracket, the pads that are required is GMKD792
31 ft lbs for caliper to bracket, then caliper bracket to nuckle is.148 ft lbs for 6400 & 7200 lbs GVWR or
122 ft lbs for 9900 lbs GVWR or
221 ft lbs for 12300 lbs GVWR.
good luck hope this helps.
Dec 21, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
Alternator belt came off had to replace idol pulley now belt is too tight and can;t get it back car.
If you bought the correct idler pulley the part is spring loaded. This is how the belt remains tight.
Look on your old part and you should see a square hole. This is where a rachet or breaker bar should fit. You use this hole and fit the breaker bar into it for a handle. Sometimes you need a pipe over the rachet handle or breaker bar to get leverage. Then you pull or push the idler bracket to get space for the belt to slip on.
Oct 12, 2009 | 1997 Ford Taurus
Fridge doorhandle bracket
Possible the source of the trouble you are having is the bracket might not be available or available separately.
Most parts lists have an exploded drawing showing all the parts and these are an invaluable aid to obtaining the correct spare parts.
I suggest you ask the service department to fax or email a drawing to you.
Mar 28, 2017 | Amana AFD2535DES French Door Refrigerator
Need the correct torque specs for 2004 silverado 1500 calipers
  • Tighten the 2 brake caliper mounting bolts to 108 Nm (80 ft. lbs.) . Caliper Mounting Bracket to Knuckle, Front (15 series) 175 Nm (129 ft. lbs.) Caliper Mounting Bracket to Knuckle, Front (25/35 series) 300 Nm (221 ft. lbs.) Brake Caliper Mounting Bolt Rear (15 series) 42 Nm (31 ft. lbs.) Brake Caliper Mounting Bolt Rear (25/35 series) 108 Nm (80 ft. lbs.) Caliper Mounting Bracket Bolt Rear (JC5/JH5) 200 Nm (148 ft. lbs.) Caliper Mounting Bracket Bolt Rear (JH6) 165 Nm (122 ft. lbs.) Caliper Mounting Bracket Bolt Rear (JH7) 300 Nm (221 ft. lbs.) Caliper Mounting Bracket Bolt Rear (NYS) 200 Nm (148 ft. lbs.)
    hope this helps
  • Mar 28, 2009 | 2004 Chevrolet Silverado
    My frige has two handles, and the bottom handle for the frige was loose and came of, how can i get a new handle for my frige. Its a LG Model GR-642QVP Serial No REFER BAR CODE LABEL A.3850JZ0373A
    Sounds like you have a UK model LG refrigerator. Go to www.lge.com and from there you can select your region and get the phone numbers to call the UK LG Parts Dept. to purchase a new handle. Hope this helps.
    P.S. I work for LG!
    May 27, 2008 | LG Refrigerators
    Barbeques Galore Bar-B-Chef Deluxe S/S 31 on Cart -175677 Grill Logo
    Top Barbeques Galore Grilling Experts
    Paul Carew
    Gary Kenady
    Gary Kenady
    Dan Webster
    Dan Webster
    Are you a Barbeques Galore Grilling Expert? Answer questions, earn points and help others
